Question about Garden
Low pressure - Garden
  • 15,557 Answers
What is the make and model number?
Posted on May 06, 2013
  • 1 more comment
  • Ben Heron May 07, 2013
    Sorry, it's a Makita HW140, seehttp://www.makitauk.com/products/front/?... Now the water just dribbles through at mains pressure. Looks like it's shot?
  • Brad Brown May 08, 2013
    Does the electric motor come on? Is there a belt that connects the motor to the pump? How do you connect it to the water mains?
  • Ben Heron May 12, 2013
    Yes, the motor comes on - it's nice and loud. No belt. It's connected to the mains with a standard 1/2 inch fitting.
Low diastolic pressure for what reason
That paper coined a new term, "isolated diastolic hypotension," which refers to a low diastolic blood pressure (less than 60 mm Hg) and a normal systolic pressure (above 100 mm Hg). Older adults who fit those conditions are at increased risk for developing new-onset heart failure, the researchers found.17 May 2015
UAB - The UAB Mix - Diastolic blood pressure: How low is too low?
https://www.uab.edu/mix/stories/diastolic-blood-pressure-how-low-is-too-low Low diastolic pressure for what reason Google Search
Dec 13, 2016 | Health & Beauty
What does low oil pressure on 2008 Chevy Impala 3.5 V6 LS
Do you mean what causes low oil pressure? This is a very reliable engine for the most part. If the oil light is on or gauge is reading low, have the oil pressure sensor inspected for failure. These sensors do go bad.
Jan 27, 2016 | Cars & Trucks
What is a po532 code on a 2008 hhr ss
DTC P0532: Air Conditioning A/C Refrigerant Pressure Sensor Circuit Low Voltage.
The engine control module (ECM) monitors the high side refrigerant pressure through the A/C refrigerant pressure sensor. The ECM supplies a 5-volt reference and a low reference to the sensor. Changes in the A/C refrigerant pressure cause the sensor signal to the ECM to vary. When the pressure is high, the signal voltage is high. When the pressure is low, the signal voltage is low. When pressure is high, the ECM commands the cooling fans on. When pressure is too high or too low, the ECM will not allow the A/C compressor clutch to engage. P0532 Chevrolet Refrigerant Pressure Sensor Circuit Low Input
Oct 03, 2014 | 2008 Chevrolet HHR SS
My low pressure fuel pump on my e270cdi cut out under high load conditions.no pressure from the rear.all fault codes tell me the rail pressure is to low
Fuel pump relay is in cavity A in the rear SAM ( Signal Acquisition Module.) on the left hand side of the trunk behind a door.
When did you check the voltage..... you must read it while cranking or you will get a zero voltage reading.. The low pressure tank pump builds pressure to the high pressure pump and then shuts down until a pressure drop is sensed in the low pressure line and it then starts up again.
If rail pressure is too low, it often is the high pressure pump in the engine or the relief valve in the fuel rail. The tank pump is low pressure just to stop the tandem pump from cavitating by sucking too hard.
Mercedes can check the rail pressure and do an injector pressure drop to rule out a leaking injector.
If the tank pump is bad it will require replacement.
Oct 20, 2013 | Mercedes-Benz Cars & Trucks
Heat pump kicks out for "Low pressure switch open." Indicated by the leds on the defrost control board Happens 2 times and then shuts down for " Low pressure lockout"
Have you checked the pressures? if you have is it just the suction pressure low or are both the suction & the head pressure low? you could have multiple things cause that ex. low in freon, restriction, bad low pressure switch, bad board. If you don't know what your doing call a service tech. the LOW pressure lockout is a safety to prevent damage to your compressor.
Oct 15, 2013 | Ruud Defrost Control Board 47-102684-08...
Just want to make sure that the a/c low pressure line is located high is the a/c low pressure located in the back of engine compartment and high for easy access
Typically the the low pressure/suction line is a bigger pipe/tube, as far as location it depends on the car. The bigger AC line is almost 99 percent of the low pressure. Usually on the cap it will say most of the times to there is a different hydraulic fitting for the low and high side. Most cars I have seen have a little tag that will say suction or low pressure line, and or discharge high pressure.
If you are re charging the gas, always use the low pressure side of the system.
Aug 23, 2013 | 1988 Cadillac Seville
Low water pressure
Copy following link for low pressure troubleshoot.
Requires water pressure gauge on water heater drain valve
http://waterheatertimer.org/Low-hot-water-pressure.html
Apr 21, 2013 | Water Heaters
Low oil cause low oil pressure
No, the oil level nothing to do with the pressure.
If you have low pressure, check the sender unit, check the pressure with a mechanical gauge, if still low, check the pump
Mar 28, 2013 | Cars & Trucks
Low presure oil
first thing check is the engine oil level.if oil level okay check oil pressure should be for the 4.2 engine oil pressure should be 12 psi @ 1200 rpm for the 5.3 oil pressure should be 18 psi @ 2000 rpm if oil pressure good problem in the oil pressure sending unit. if oil pressure is low problem faulty oil pump or worn crankshaft bearings if oil pressure low engine will have rod knock.make sure you are using correct oil viscosity if oil too thick you will have low oil pressure oil too thin you will loose oil pressure.
Nov 26, 2012 | 2004 GMC Envoy
96 Tahoe no Cold Air
YOU NEED 28 PSI ON LOW SIDE AND ABOUT 190 ON HIGH SIDE.YOUR REFRIGERANT IS LOW THAT WHY COMPRESSOR CYCLING ON AND OFF.
Jul 22, 2009 | 1996 Chevrolet Tahoe
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
