Question about Philips 50PFP5332D 50 in. Plasma Television
Hissing noise Our Phillips 50" made a fizzle,hissing and turned off, and will not power on??? We had the Y- main board replaced about 2 years ago.
SOURCE: plugged in no power
www.scribd.com/.../Philips-Training-Manual-TV-Plasma-Display-Panel-Chasis-FTV1-9 -
www.scribd.com/.../Philips-DPTV400-TV-Projection-Training-Manual
Above is a service training manual, to give you an idea of how it all works. To do ANY work, one MUST obtain a Service manual for your exact make and model.
This is a classic switchmode power supply, shutting down to avoid a fire, explosion, or both. This set had developed a problem, that is so severe that the set must be shut down, This set should be removed from the Power, and in my professional recommendation, you should get a "Quote" for repair, from, a Philips, Approved Service Center, this point is very important for a good result, Always contact, their local, "Head Office" Now, when you get the information you want, then you can decide as to repair of replacement. The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand.
Posted on Jul 31, 2010
joeymille916
  • 143 Answers
SOURCE: Philips widescreen flat TV model #50PF9966-37 50"
From what I'm seeing online, the bulbs in the Ambilight may be the culprit. I also read that a firmware upgrade could fix the issue too. There was also a recall of some TV's with that issue, so I would check with Philips about your model and serial number and see if your TV was included in the recall. If you raise enough cain and threaten to never buy from them again, they may get your set fixed for you... even if the warranty is up!
Good luck and please post feedback!
Posted on Oct 10, 2010
Testimonial: "Thanks for the help. I will be calling customer service Monday morning. I will update after the call. Thanks again...."
ladywinn
  • 5138 Answers
SOURCE: I have a Phillips FLATTV model 42PFL7662D/ 05 I
Have you removed the back and Looked on Power Supply board for Bad Capacitors they will be vented ,swollen or puffed up on Top? Encompass Parts Distribution has parts for this model
you can Visit their website 1-800-638-3328
Posted on Oct 15, 2010
SOURCE: I have a Phillips FLATTV model ... Problem with
Try with that...
http://www.filestube.com/3c4e959f7e53ba6703e9,g/PHILIPS-42PFL7932-LC420WU5-V2-CIRC.html
Symptom:
Sound but no picture.
Cure:
Master or Slave inverter is defective.
It can be that the driver IC is defective or MOSF
inverter transformers, or 470uF 35V C
Replace driver IC BD9897FS or MOSFET's.
996500046243 IC BD9897FS
996500046242 Mosfet FDD8447L
996500046241 Zener KDZ100V
Posted on Jan 17, 2011
eagle338
  • 4889 Answers
SOURCE: my 42pf7220a phillips hdtv lost
This is not a problem with either of the two boards you have mentioned. The loss of picture in a plasma is caused by faulty sustain boards. In most Philips plasmas I have seen, both the X-sus and Y-sus boards have to be replaced to solve this. The cost is about 150$ for both boards
Posted on Feb 03, 2011
Engine makes hissing noise. Valve cover or just a gasket?
Soounds like it to me.... But to be sure, knowing the make, model & year of the car would be a huge help!
Jul 23, 2016 | Cars & Trucks
Have a phiips tv had it in storage for over a year turned it on an the screen working perfectly but there a hising noise coming from the back of it do no what it is... Its a big bk tv not flat screen box...
hissing noise will be from high voltage regulator, i would suggest to do following:
1. switch tv off
2. remove plug from the wall
3. using air blower (compressor attachment - not leaf one!) blow the dust, especially from high voltage box section
4. connect the tv and switch on
if tv still issue hissing noise - follow 1 and 2 then:
3. remove back cover
4. use air blower again...
5. re-install back cover
6. reconnect tv and switch on
if hissing noise persist - check for blown capacitors on high voltage, replace if necessary, they have nasty tendency to pop if they are too long in storage, especially if tehy were overheated or frozen.
hope this will help you solve the problem, do not forget to vote...
Jan 27, 2015 | Televison & Video
When i turn on my samsung plasma it makes a hissing noise like stakick?? sound like an old tv when you disconnect the feed .When It started it would last 1 minute 2 monthes later it takes 20 minutes to...
This problems is the cases by the power supply board is dying.That the board,where the power a/c cord plug into it.Try website like Ebay.com to buy a refurbish power supply board for the replacement.After u replaced it with a different power supply board,tv will work normal again.
Nov 17, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
I have a Phillips FLATTV model ... Problem with the Philips Flat Panel Televisions I have a Phillips FLATTV model 42PFL7662D/ 05 I have no picture, the audio is OK, I have had a hissing noise for about 2...
Try with that...
Symptom:
Cure:
Oct 18, 2010 | Philips Televison & Video
No Power - hissing but no picture
Power supply capacitors are the most likely culprit. Look for bad solder connections as well.
Oct 07, 2009 | Polaroid FLM-3201 Television
Speakers have hissing noise coming out of them
Hook a graphic equalizer between the piano and speakers, and turn down all sliders above 8 kHz. Since the highest note of a piano is 4186 Hz (4.186 kHz), you'll still hear all the notes but cut the hiss. If the hiss is coming from the speaker's power amplifier (in which case the equalizer won't help), turn down the speaker volume and turn up the piano volume. Live instruments generally need some doctoring to sound good through high-quality stereo equipment, as they only produce a limited range of frequencies whereas good speakers reproduce a lot more - including hiss.
Dec 25, 2008 | Onkyo GX-D90 Main / Stereo Speaker
Hissing noise in house
To solve this you are going to need to start eliminating things. You say you hearing is good, well just make sure next time you hear the hissing put your fingers in your ears to make sure it goes away. If it doesn't then it is internal i.e you have tinitus.
Next start turning things off at the mains. Your hifi can't hiss if it has no power, so try turning it off at the mains by unplugging it. If it is not your HiFi then start turning other things in your house off. Till you stop it.
Regards,
Andrew
Sep 13, 2008 | Audio Players & Recorders
Power Problem
The hissing noise on your speakers is because of arcing. Do not try to operate repeatedly or you may do severe damage. The most likely culprit is the inverter board but you will have to disassemble the monitor to find out. Any loose connection that results in an arc will create noise on speakers. Hissing is usually a result of the high frequency/ voltage output small enough amperage to not blow your power supply If it were a DC arc you would just get a one time pop.
Jan 02, 2008 | HP Pavilion F1703 17" LCD Monitor
Crackle noise and hissing - panasonic
solder all around the flyback area if this not resolve the problem replace the flyback
Nov 26, 2006 | Panasonic CT-32D12D 32" TV
Philips 50PFP5332D 50 in. Plasma Television Logo
64 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
