Sony PlayStation Portable  Console
Problem for Sony PlayStation Portable (PSP) Console
PSP Sees to be charging, but won't stay on.
By darkheart on Aug 10, 2007
Hi, my psp charges, even allows me to check battery levels. Bt after a fe minutes, sometimes more, sometimes less, it just freezes and shuts down. It let's me turn it on again, and all the audio and video works, but it just keeps shutting down. It's not hibernating, because this happens right in the middle of games. Is my battery shot? Or is my PSP bricked?
Comments:
Aug 10, 2007
- I should have mentioned this before, but even when I have it plugged in to AC power, it does the same thing. I will try changing the battery, but it doesn't make sense that a bad battery would do this. It says my battery is at 100% and has more than 6 hours of time. And I still leave the AC plug in and it shuts down.
Same Problem
Feb 26, 2008
-   i have the same problem for example im playing nba live 08 and i just finished a game then when i go to exit,it just freezes then shuts down-   jr1jtg
Solution #1
posted on Aug 12, 2007
Somewhat Helpful)
nliwilson
Rank: Wiz
Rating: 83%, 199 votes
What ansfarid is trying to say is that with a problem like this the first thing to try is a firmware update, you can do this online with your PSP or with a very recent game, this can be a problem if you are using a "home-brew" firmware or if indeed the latest firmware is the problem.
However it sounds more likely that either your UMD drive or battery contacts or possibly both need cleaning. The PSP will crash out on disk read errors so try cleaning the drive and your disks first, even if they look completely clean.
You can clean the laser of your UMD drive with an alcohol-free CD wipe wrapped around a cotton bud (q-tip) but the most effective way is to blow it out with an air duster (available from any hardware or good electronics supply store).
Cleaning UMD's is a different matter, it is possible to tern the centre of the disk with one finger whilst holding an alcohol-free CD wipe to the disk surface with another but you can also purchase UMD cleaning tools from most large game retailers that make the job a lot easier.
cleaning the battery contacts is much more straightforward, just remove the battery and use a lint free cloth or our old friend the alcohol-free CD wipe to clean the contacts both on the battery and in the PSP, if you use a CD wipe make sure all contacts are dry before re-seating the battery.
As always message back if non of this helps or you need any further advice.
Was this helpful?
Yes
No
Solution #2
posted on Aug 10, 2007
Somewhat Helpful)
Raheeeeb
Rank: Master
Rating: 81%, 61 votes
Change your battery
Was this helpful?
Yes
No
Solution #3
posted on Aug 11, 2007
Not Helpful)
ansfarid
Rank: Guru  Sony Expert
Rating: 89%, 202 votes
You better try your PSP by upgrading the software because there may be some errors had occured in your PSP OS software.
Comments:
Aug 14, 2007
- Your problem can occurs if there is any disturbance in the movement of lens in it's gear shaft or the white nylon gear which is moving this shaft. you can use white grease on this shaft as well as nylon gear also for the smooth movement of LENS and your problem should be solved.
Was this helpful?
Yes
No
Popular Solutions for Sony PlayStation Portable
Questions and Unsolved Problems for Sony PlayStation Portable
Do you recommend Sony PlayStation Portable (PSP) Console?
Answer
Answer
why the memory get erased suddenely from my psp ( from memory stick
Answer
how do i import a playlist from my itunes to my sons psp go?????
Answer
when i got my psp i tuned it on,then i tuned it off,i then took out the battery to see it.After that... (More)
Answer
The joystick moves around fine, but the character in the game moves around slowly.
Answer
i have created a folder in my psp games folder and called it update but when i press x to start the... (More)
Describe your Video Game Consoles problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Video Game... Experts
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
