Question about Dell 5100cn Laser Printer
No color printing
Changed black in cartridge to new bland cartridge. All cartridges in properly and have ink. Printer stopped printing in color right after new cartridge was installed. Dell cartridge, not after market. Any help would be GREATLY appreciated.
  • Dell Master
  • 32,281 Answers
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Posted on May 06, 2013
  • George May 09, 2013
    Hi Chris, Thank you for your assistance. It's not an inkjet it's a Laser Printer, the 5100cn.
SOURCE: Dell 962
Just found this partial fix: "Try removing the color cartridge and try printing with the color cartridge out. If it gives you a message that the cartridge is missing, it will still allow you to print by clicking "continue". And from there, it will allow you to print black. I think it really is a problem with your color cartridge." From searching the net, this seems to be a major problem with no solution from Dell!
Posted on Feb 28, 2007
  • 13 Answers
SOURCE: Printer will not print with color cartridge in
go to dell AIO center
click maintain/troubleshoot on the top
under trouble aio problems - click ink levels
click maintenace tabs
and then clean print cartridges and align print cartridges. then try printing a test page.
if this does not work, remove the cartridges and install them again.
let me know how it goes
Posted on Dec 28, 2007
SOURCE: Black stopped printing out. Dell 922 all-in-one ink jet.
HI thanks for that and i will try it.
Posted on Jan 15, 2008
1alexh
  • 484 Answers
SOURCE: my Dell AIO printer keeps blinking right ink cartridge incorrect.Exclamation light keeps blinking too.
Try going to the Dell site and searching for that printer model. Then see if you need to have both ink cartridges populated and filled with ink, to make it work.
You might also clean the contacts on the ink cartridges, to make sure the printer knows you have both cartridges in the printer, even though they're not both filled with ink.
It just might require both to be filled, before it will print for you.
See what Dell says.
Good luck.
-a.
Posted on May 22, 2009
SOURCE: dell 926 photo printer will not print black ink.
I'm am having the exact same problem with a new Dell 926!
Posted on Feb 16, 2010
I have the Dell AIO 926 and i have an Error Message. Error 1203 Consult User's Guide I cannot print, what do i do?
error 1203's error name is print head short which indicates a short circuit in the print head has occurred. solution to this problem is to disconnect and then reconnect the printer power cable. Reinstall the ink cartridges.For more information, see Replacing Ink Cartridges.
  • Turn on your printer.
  • Lift the printer unit, and then position the scanner support between the tabs to hold it open.
  • The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  • Press down on the ink cartridge lever to raise each ink cartridge lid.
    Remove the old ink cartridges.
  • Store the cartridges in an air-tight container, such as the storage unit you received with your photo cartridge, or dispose of them properly.
  • If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
    NOTE: The following illustration shows a black cartridge and a color cartridge (used for normal printing). For photo printing, use a photo cartridge and a color cartridge.
    Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier, and the color ink cartridge is secure in the right ink cartridge carrier.
    Snap each lid closed.
    Hold the printer unit up, push the scanner support back to unlock it, and then lower the printer unit until it is completely closed.
  • Jun 05, 2011 | Office Equipment & Supplies
    I changed two colour ink cartridges on my Canon iP4200 printer. Now it won't print colour. The pattern check does not print any colour.
    You might want to double check to make sure that your printer takes two color cartridges? If I remember correctly, the Pixma takes one black and one color cartridge? If you put a color cartridge in the black ink assembly that would cause it to stop printing.
    Double check and make sure that you have one black cartridge in the correct place and one color on the other side.
    Apr 22, 2011 | Canon PIXMA iP4200 InkJet Photo Printer
    How do I install the printer cartrige? I do not have the booklet...
    1. Turn on your printer.
    2. Open the front cover.
    1. Press the tabs on the cartridge lids, then lift the lids.
    1. Remove the old ink cartridges.
    1. Store the cartridges in an air-tight container or dispose of them properly.
    2. If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
    NOTE: You can use your printer with one cartridge (color or black) at a time. To extend the life of your color cartridge and improve printing speed, install both a color cartridge and a black cartridge at the same time.
    1. Insert the new ink cartridges. Make sure the color ink cartridge is secure in the left ink cartridge carrier and the black ink cartridge is secure in the right ink cartridge carrier.
    1. Snap each lid closed.
    1. Close the front cover. The front cover must be closed to start a print job.
    1. Open the Dell Printer Solution Center by clicking Start® Programs or All Programs® Dell Printers® Dell Photo Printer 720® Dell Printer Solution Center.
    2. Click the Maintenance tab.
    3. Click Install a new print cartridge.
    4. Click Next.
    5. Select the type of cartridge you installed.
    NOTE: Specify whether the cartridge is a new cartridge or an old cartridge (one that has been used before). If an old cartridge is incorrectly identified as New Cartridge in the Dell Printer Solution Center, ink levels may be incorrect.
    1. Click Next.
    Dec 17, 2010 | Dell Inkjet 720 Printer
    Bland and color cartridges have been refilled but
    Ink level counter (program) didn't read actually ink at ink tank. Brand new cartridge ink level counter 100% (full), and ink 100% (about 10 ml). After may printing, ink will dry out, and ink level counter reach zero (ink out). Printer will not allow print anymore, even have refilled, because ink level read "ink out". For canon type, you just to release ink level counter, and counter just stop, but printer will allow to print. Press stop/reset button for about 30 second.
    Mar 15, 2010 | Canon PIXMA MP190 All-In-One InkJet...
    Printer only won't print in black
    My printer did that a few months ago. I tried everything to get it printing black but in the end I had to take the ink cartridge back and return a new one. Some ink cartridges dry out when they are being shipped if not stored in proper conditions.
    Mar 14, 2010 | HP Officejet 6500 Wireless All-in-One...
    Black won't print. Changed all ink cartridges,
    It may need a new purge assembly, if it doesn't clean both sides properly either color or black will quit. You might try a new printhead first, QY6-0064-000 around $40.00
    Jul 01, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
    Cartridge problem
    Basically, you placed a black ink cartridge [30] into the compartment for the color one [31]?
    Make sure you have a black ink cartridge in the left compartment, and a color one in the right one. I don't even think it would properly fit if they were in the wrong slots. They should "click" into place, confirming that they're installed properly.
    Sep 08, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
    Colored Ink problem
    Make sure the printer settings are set properly to print in color on the PC. Even if there is a color cartridge, if the PC only tells it to print black ink it's not going to use the color cartridge.
    Jun 08, 2007 | Lexmark Color Z35 InkJet
    Use of black ink
    My husband answered this for me- it takes different colors to make black, therefore it uses some of the color ink
    Jan 16, 2007 | Canon Pixma iP6600D InkJet Photo Printer
    Printer will not print black, but will not let me replace black cartridge
    The Epson FAQ lists several techniques for resolving this problem. http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=14374&infoType=Overview There is also an animation on how to replace the ink cartridges. http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=HowTo&oid=14374&prodoid=11473
    Oct 14, 2006 | Epson Stylus 880 InkJet Color Printer
    Dell 5100cn Laser Printer Logo
    35 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    Electro Med Services...
    color wheel light...
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
