Question about Generac 13,000 Watt / 13,000 Watt Home Standby Generator
Generac Generator 40kw mode l004748-0 Starter engages after running
Hi I just bought a used generator and installed it, after starting the first time the starter wants to engage again, I have checked power on the 15 and 16 wire from the voltage Reg and I have 158 vac ,I also see no hertz on the meter ,what voltage should I have and should there be Hertz on the meter,Thanks for any advise
  • Generac Master
  • 15,557 Answers
Are you sure about that model number?
Posted on May 06, 2013
2 Suggested Answers
SOURCE: Generac generator remote start
si tiene transfer automatico solo poner un swicht en hilo 1N para cortar senal de entrada al generador del utility power que sensa la presencia de voltage en caso de falta arranca el generador en forma de prueba
Posted on Jun 20, 2010
I have a 20kw generac standby generator, where the starter tries to engage after the generator starts up and is running. Only has 316 running hours. Installed new starter in 2016.
The starter pinion drive gear is sticking.... its the smaller gear on the shaft that moves up and down to engage the flywheel gear and start the motor. Carefully put a LITTLE hi temp grease on the shift splines (curved ones) and see how much that helps. The gear is not staying "retracted"..if this doesn't help.. the spring that pushes the gear back down may not be strong enough...(you could always fix both)
Jun 21, 2017 | Generac Electrical Supplies
Why does it crank and almost start on 1st try?
Generac Generator Troubleshooting - YouTube
? 1:39
https://www.youtube.com/watch?v=AKN2dc59cxY
Dec 20, 2013 - Uploaded by Appliance Princess
I want to learn about Generac generator troubleshooting. ... I have a 16 kW propane fueled standby air-cooled generator. ... I have a brand new generac 20K guardian Evolution and the first time my power went out my generac ...
Generac Power Systems - ConsumerAffairs.com
www.consumeraffairs.com > Homeowners > Utilities
Rating: 1.3 - ‎26 votes
Hey, Generac, make a change and start making generators that work, don't cost .....Standby generators are not supposed to be used as a primary power source ... and three months ago, I spent $4,000 to have a Guardian generator installed at ...
Generac standby generator - Propane - wont start?? - DoItYourself ...
www.doityourself.com/.../487838-generac-standby-generator-propane-w...
Feb 4, 2013 - I have a Generac 4LM41A standby generator that I need help introubleshooting and repairing. It is about 12 years old and hasn't been used ...
141 GENERAC complaints and reviews @ P'ed Consumer
Dec 12, 2015 | Generac GUARDIAN Standby Generator 10 kW/9...
Generac 17kw standby generator, starter will not engage into engine, just spins
If it spins and will not engage it needs removing and the bendix gear on the starter is probably worn or damaged
Aug 05, 2013 | Generac 100 Amp 120/240-Volt Transfer...
Generac 40kw single phase generator starter engages after 30sec of running
For the over voltage there is an adjustment on the control board.
Should be tested with a load something plugged in.
The hertz might just come on when under load and adjusted too.
If you need more give a model number and whether it is 13kw or 40kw.
May 05, 2013 | Generac 13,000 Watt / 13,000 Watt Home...
How to start a gas generator (should the choke be in or out, to the right or the left before starting
Most Generac generators have a lever for the choke that pulls out. So if the generator is being started for the first use or cold you should choke when starting . Let it run for 30-45 sec. then push it in . Once the engine has been run or warm you dont need to choke every time when starting .
Nov 04, 2010 | Generac Power Systems Generac 0057890 3250...
Dec 19, 2009 | Generac 13,000 Watt / 13,000 Watt Home...
Generac EPS-15 attempts to engage the starter while running
I work on these everyday. You most likely have a bad rotor or stater if the starter engages while running and no output. The no out put is making the generator think its not running causing it to try and start. If its not that then its the control board or voltage regulator.
Apr 07, 2009 | Generac 13,000 Watt / 13,000 Watt Home...
Start runs shutsdown
Typically caused by the fuel line (LP or Natural Gas) having a lot of air in it. Was your generator just installed, or was there any work done to the gas line of the building / generator? Consult local gas contractor / propane dealer / gas company for assistance in purging the fuel line.
A low battery can also cause this as well as the generator is not able to come up to starting speed quick enough. Try placing a stand alone battery charger on the generator and charge the battery. Also check the air filter as well.
OverCrank condition occurs when generator tries to start itself, or be manually started, and the starter spends too much time turning.
This can also indicate failure of the control board. This will need the expertise of generac technician. Call 1-888-GENERAC (1-888-436-3722)
M-F 7am-6pm Central
Mar 29, 2009 | Generac 13,000 Watt / 13,000 Watt Home...
Generac 13,000 Watt  / 13,000 Watt  Home Standby Generator Logo
116 people viewed this question
Top Generac Electrical Supplies Experts
 Kenneth
Kenneth
Ottoniel
JOHN LAPIER
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
