I have a hotpoint wt741 washing machine and came up error f-05 I cleaned the filter out no joy. Then drained and put washing on fast spin which it did then pumped the washer full of water again help?
    New Friend:
    Problem Solver:
  • 6 Answers
YOU COULD TRY CHANGING THE PRESSURE SWITCH.THIS IS A ROUND PLASTIC ITEM WITH A PLASTIC PIPE RUNNING OUT OF THE BOTTOM OF IT.EASILY ACCESSIBLE BY REMOVING THE LID
Posted on Jun 26, 2013
SOURCE: error code F-05 water not leaving washing machine
F05 flashes due to electric oven control failure. The solution is to replace the electronic oven control (also called EOC or clock).
Posted on Dec 12, 2008
SOURCE: error message f-01 on hotpoint ultima wt741 washing machine
F01 is a motor faulty normally caused by the module,but sometimes thewiring to the motor plug that works loose as its to tight,give them alla good wiggle make sure there all in!
check this link for other error codes of hotpoint machines
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
Posted on Dec 15, 2008
barkencoa
  • 3463 Answers
SOURCE: HI F 05 IS FLASHING ON MY WASHING MANCHINE
You will probably need to clean the pump filter.
To access the pump filter,remove the lower plastic panel at front of washer, there you will see the filter, unscrew the cover anti-clockwise, remove filter and clean.
This should clear the fault.
If it does not , let me know, and i can can tell you other things to look for.
Please rate my fixya solution.
Thanks.
Posted on Jan 31, 2009
57 varieties
  • 1653 Answers
SOURCE: Hotpoint WF840 W machine still full of water error code F 05.
Do the following.
  1. Switch off the machine and disconnect the mains power.
  2. Remove the access panel on the lower right front of the machine.
3. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that depending on the machine type you may get a lot of water coming out of the filter when you remove it if the machine has not drained successfully. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray. It may take a few minutes to empty but it will save a small flood.
4. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
5. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
6. Reconnect the power and switch the machine on.
If the problem persists then do the following.
7. Switch off the machine and disconnect the mains power.
8. Check the electrical connections at the pump and make sure it is operational.
9. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
10. Makes sure the pump appears clear and that the impeller looks in good condition.
11. Reconnect the hoses and then reconnect power and switch the machine on.
12. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
Posted on Oct 23, 2009
barkencoa
  • 3463 Answers
SOURCE: hotpoint ultima F-05 errorr appears on machine
Error F05 indicates pressure switch jammed on full.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve the problem.
Posted on Jan 10, 2010
My washer hotpoint wt741 is flashing up f05 and wont rinse water out
An F-05 error message means that the pressure switch is jammed on empty or a problem with pump.
The fault is associated with drain out (pump blocked or restricted in some way).
Try this out:
Small panel at rear of machine reveals the pump,
Pull of the two pipes (Plastic clips hard to get off, Slide them sideways),
Remove wire and unclip pump from base of machine by lifting locking tab and sliding to the left,
Pump can then easily be cleaned.
Mar 06, 2010 | Hotpoint Washing Machines
Hotpoint aquarius is not spinning or draining..f-05 is flashing on and off...
Error code F05 indicates pressure switch jammed on full.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum
Remove and clean filter inide hose.
Refit and test.
Please rate my solution.
Thankyou.
Jan 31, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint wt741 1400 spin-f-05 flashing on display board not empting or finishing wash?
Error code F05 means pressure switch jammed on full
Remove large black hose on bottom of tub.
Remove hose onto pump, and check for blockage or obstrucrtion here as well.
PLease rate my solution.
Thankyou.
Jan 17, 2010 | Washing Machines
Hotpoint ultima F-05 errorr appears on machine
Jan 10, 2010 | Hotpoint Ultima WF860 Front Load Washer
The water wont drain from my machine from the wash
What you need to do is check the pump is getting a feed to it
Select a spin cycle, and with a test meter, test for voltage across the pump terminals, if you are getting a feed, and the pump is working ok, then you obviously have a blockage beyond the pump.
If no voltage then could be a broken wire, or a faulty programmer/board.
ONLY CHECK FOR VOLTAGE IF YOU ARE COMPETENT TO DO SO, as it takes no prisoners.
Hope this helps.
Dec 07, 2009 | Hotpoint WMA54 Front Load Washer
Thanks.
Jan 31, 2009 | Hotpoint Ultima WF860 Front Load Washer
IVE CLEANED OUT THE PUMP AT THE FRONT OF MY HOTPOINT WT741......
F05 - Pressure switch jammed on full - Check pump for blockages.
There could be something still blocking the drain pump.Calling a tech for this purpose might pull in a lot of money which could be wastage as it is something that can be fixed by yourself.Provide me with the model number and will get the internal diagrams of the washer so that some disassembling might help out.Also check the filter as you say it is a little broken.Run the washer without the filter and any clothes;only with hot water for that might clear a little more.
Good luck.Please do rate my answer.And also I hope some comments with the model number.
Jan 17, 2009 | Washing Machines
F-05 error code Hotpoint WT746
how do i fix error f-05 on my washing machine
Apr 02, 2008 | Washing Machines
Hotpoint ultima wt741
washing machine WT741 ultima all light are flashing and it won't do anything else
Nov 12, 2007 | Washing Machines
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
