Question about Refrigerators
Refrigerator amana
Replace roller 10450701
  • 575 Answers
Always look at the new part to see where mounting is possible.
support the appliance for easier replacement of wheel.
If one side is bad I replace both to avoid doing twice.
Then remove the screws and replace.
good luck
Posted on May 06, 2013
Amana TEA600L dryer motor will not start or hesitates
Motor replacement needed.You can oil em with zoomoil but you would need to make some holes over the motor bearing wells on either end of the motor. The motor is fairly simple to replace:
Feb 24, 2013 | Amana Dryers
The assembly that holds the drawers in the refrigerator has broken. I need replacements.
You can buy them from Amana directly. Go to their website
http://www.amana.com/ and loacte your service / spares centre
The parts list diagrams can be found at the following Amana Support link
http://shop.amana.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10242314.pdf
Oct 21, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
I have an Amana ALE643RBW drum needs manual assistance to tumble
If you remove the back panel you will be able see the drum rollers. There's a good chance they may be worn out. As long as you are replacing the rollers I would suggest replacing the belt at the same time.
Typically when the rollers wear out, the drum drops ever so slightly and the drum wears on the front and rear drum to cabinet seals.The added drag can cause a slow drum and squealing noises.
Good luck, let me know if there is anything further you need.
Regards,
Aug 18, 2009 | Amana ALE643RB Electric Dryer
How to replace the rear wheel on Amana 22.1 cu.ft refrigerator
Remove anything in the unit that could spill or tip over. Raise the front leveling legs to allow unit to roll. Slide the unit out from the wall. Place something between the refrigerator and the wall to protect surfaces. ***Make sure you have someone to assist with this next part. Tilt unit to the side and lean it against the wall to raise up the roller to be replaced. There is a metal base that supports the rollers, compressor, condenser and fan motor. You will see a heavy duty metal pin that goes through the roller. Bend down the metal tab in the base to remove roller pin. Replace the roller, reinstall bin and bend the tab back up. Carefully set the refrigerator back down on all four rollers. push back in place and screw down the front leveling legs.
May 02, 2009 | Amana ATB2132ARQ 33" Top Freezer...
Using rollers to pull fridge out for cleaning
Hi: Simple. Every Amana refrigerator I've seen in the last 15-20 years have brakes. In front of your wheels is a rubber disc that screws down to stop the fridge from rolling forward when you open it. You have to screw them back up a little to make it roll. If you look at your grill you will see that it is flat all the way across except for the ends they protrude forward at the ends. They usually cover the brakes. Work at the grill to find the clips that hold it in place. It will snap off. The reason for putting you through that; is the energy efficiecy, The seals work so well that you would pull the fridge forward when opening. That should work, Jeff
Nov 26, 2008 | Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ...
Compressor change
this is not a diy job. after replacing compressor, you have to vacuum down the system ie remove all air and measure the amount of refrigerant injected into the system. you need special gear for this
Sep 12, 2008 | Amana Refrigerators
Amana side-by-side refrigerator/freezer
raise the front legs/rollers so unit is tipped back slightly.its ok if it opens as long as it closes.
Aug 07, 2008 | Amana SCRATCH&DENT 25 Cu. Ft. French Doors...
Broken amana refrigerator wheels
Usually the roller for the rear of the fridge has an axle that is just a pin that will slide out(need a model # to know for sure) and the weight of the fridge holds the pin in place.
Dec 05, 2007 | Refrigerators
Refrigerators Logo
32 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
