Precor 954i TV
How do you set up the TV?
    Top Expert:
  • Televison & ... Master
  • 74,106 Answers
Click here to download the user manual. It has all details.
Posted on May 06, 2013
Can I adjust the stride length?
Precor EFX 546 Version 1 Elliptical Trainer (Refurbished)
www.amazon.com > ... > Elliptical Trainers
Amazon.com, Inc.
Rating: 4.3 - ‎9 reviews
Working out on an elliptical can burn as many calories as working out on a treadmill. ...allowing you to go forward and backward, as well as adjust stride length to target ...The Precor EFX 546 allows you to stride smoothly while holding the ...
EFX® 546i Elliptical Fitness Crosstrainer™ ' Precor
www.precor.com/en-us/.../efx-546i-elliptical-fitness-crosstrainer-33
With the unique Precor CrossRamp® technology, users can alter the path of the EFX®546i between 13 and 40 degrees in both forward and reverse stride motions, cross ...Excellent stability and freedom of movement for users of all sizes.
FAQ - Precor
Dec 28, 2015 | Precor 546 Elliptical
My treadmill precor 954i showing stuck key. So what solution for this problem???
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
This is normally caused by a stuck key on your keypad. To resolve this issue, you must replace the keypad.
The following link may help, but you will need your serial number to find the correct item.
Repair Parts for Precor C954i Treadmills 120VAC 240VAC SPORTSMITH net
Nov 13, 2015 | Precor Exercise & Fitness
I recently bought a used Precor 954i it worked fine then when i brought it home and wired it in with a 20amp breaker and 240 volt im getting error 29 as soon as i turn the machine on any ideas?
Precor Error 29, Excessive AC Input Current Probable Cause 1. The running belt and/or deck are badly worn.
2. Bad lower PCA.
3. Drive motor is shorted or de-magnetized causing a high power demand.
Corrective Action
  1. Check the amp draw using a clamp on AC volt-amp meter during loaded and no load conditions and compare values to a similar treadmill that is known to have a good running belt and deck. Replace the belt and/or deck if necessary. Don't forget, some units have a double sided deck which means it may be flipped over rather than replaced if it has an unused side.
  2. Test unit with a known good lower PCA. Replace lower PCA if necessary.
  3. Test unit with a known good drive motor. Replace drive motor if necessary.
Precor Error Code 29 Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Sep 22, 2015 | Precor 954i Experience Series Treadmill...
How do you fix an error code 30 on a precor 954i?
Precor Error 30, 31, 32 and 33, Communications Error Probable Cause 1. Bad interconnect cable between upper PCA and lower PCA.
2. Interconnect cable is mistakenly plugged into the CSAFE connector at the upper PCA.
3. Elliptical 5.17 equipped with old software version 1.01 in upper and lower PCA.
4. Upper and lower PCAs have mismatched software.
5. Another component plugged onto the PCA is overloading the +5VDC power supply.
6. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
  1. Test unit with a know good interconnect cable or test the interconnect cable for continuity. Replace interconnect cable if necessary.
  2. Disconnect the interconnect cable from the CSAFE connector and attach to the proper position on the upper PCA.3.
  3. Replace the upper and lower software of the 5.17 elliptical with the most current versions.4.
  4. If one of the PCAs is found to have software version 1.01, replace it with the most current software version.
  5. Disconnect all components from the upper and lower PCA leaving the data cable connecting between the upper and lower PCAs and the AC power going to the lower PCA. If the unit shows any error other than the error 3x, reconnect components one at a time. Reset power between each newly connected component until the error 3x reappears. Whichever component was last connected when the error 3x reappears, is the cause for the error. Replace the faulty component.
  6. Test unit with a known good lower PCA. Replace the lower PCA if necessary.
  7. Test unit with a known good upper PCA. Replace the upper PCA if necessary.
Precor Error Code 30 31 32 33
Jun 30, 2014 | Precor Exercise & Fitness
954i will not power up
Verify voltage to the MCB. If it gets power, and 2 MCBs do not light up the console, check the wiring to the console. If that looks good then it sounds like you need an upper.
Apr 03, 2014 | Precor 954i Experence Series Treadmill...
Error 29 message coming up on screen
see the error code and fix it. God bless you
Error 29, Excessive AC Input Current, this mean that some elements inside of the treadmills is consuming more AC currente, like transformer, main motor.
see the block diagram attached.
Nov 28, 2012 | Precor 954i Treadmill Refurbished. 115...
Precor 954i the stop button is stuck
try to tight the RIbbon CAble inside for keypads, and tight the upper cable vs lower cable.
2) Adjust the REED swtich, test it, clean it, see the diagram, and tight very well the plug-
God bless you
Nov 15, 2012 | Precor Exercise & Fitness
Power keeps cutting out when clients are running on it.
When a running belt has excessive wear, it creates a lot of friction which causes the drive motor to work harder. When the drive motor works harder it will start overheating. If the belt is not lubricated periodically, it will ruin the deck, the drive motor, and cause other electrical problems such as tripping the breaker [after a while, the circuit breaker on the treadmill will need to be replaced.
It is suggested to lubricate the belt every month. At this point, you may need to replace both your deck and your running belt.
With your model and serial number, you can visit our website and view the products we have available for your particular machine.
Precor Parts for 952i 954 954i 956 956i Treadmills SPORTSMITH net
Apr 16, 2011 | Precor C956i Treadmills with HR /...
Error 45 on Precor EFX 546 Elliptical
Precor Error 45, Lift Moving in Wrong Direction Probable Cause 1. Lift motor hysteresis.
2. Lower PCA is bad.
Corrective Action 1. The error would usually occur when the lift was already in motion (usually downward) when a lift command in the opposite direction (upward) was made. Some lift motors used in production exhibited a very long turnaround time and the lift motor would still be moving in the original commanded direction while the control system was trying to move the lift in the opposite commanded direction. If the error continues to re-occur, replace the lift motor.
2. It is a rare condition, however if the lift moves in the opposite direction commanded, replace the lower PCA.
Precor Error Code 45
Jul 19, 2009 | Precor EFX 546i Elliptical Version 4
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
