Question about Brother GX6750 Typewriter
HOW DO I GET STARTED
CAN'T GET IT TO START THE WHEEL STOPS AND MAKES NOISES
  • 46 Answers
It sounds like a jam. Check to make sure the ribbon and correction tape are not jamming the printwheel. Make sure the printwheel is not bent or damaged in anyway. Make sure the ribbon and correction tape guides have not been bent. If that doesn't fix it, you will probably have to have it serviced.
Posted on Oct 24, 2013
Loud thumping from under drivers side that started with a squeal.
16 costly car noises - Bankrate.com
www.bankrate.com/finance/money.../16-costly-car-noises-1.asp...
BankrateYou should not ignore certain thumping, banging, clicking and squealing sounds. These sounds often rear their heads or intensify whenever the driver takes ... Hissing or sizzling under the hood: Heard when the engine is first shut off, .... my rear right wheel makes a loud bang when switching from park to drive/reverse.
Sounds coming from drivers side front wheel - AnandTech Forums
forums.anandtech.com > Social > The Garage
AnandTech
Dec 1, 2009 - 21 posts - ‎10 authors
Sounds coming from drivers side front wheel The Garage. ... slightly left, I get a slight metalish-squealing sound coming from the drivers side front wheel area. ... but before I start the wild and expensive goose chase of bringing it to mechanics I ..... Those twoloud clunks when turning hard right give it away.
Ford Explorer Questions - Thumping from front end - CarGurus
www.cargurus.com > Questions > Ford > Explorer
CarGurusDec 22, 2009 - Thumping from front end - I have a hard thumping noise coming from ... without problem then I'll take a turn or something and it will start. ... I just recentlystarted having a rubbing and thumping and squeaking noise in the right front sidewhen driving ... Thumping sound coming from under the truck 4 answers.
Car Noises: Consumer Reports - Consumer Reports Online
www.consumerreports.org/cro/...noises/.../index.htm
Consumer Reports
Feb 03, 2016 | Cars & Trucks
My vehicle makes noises when i accelerate
98% sure you have an axle problem. Might be wheel bearings depending on the sound. Bad axles will make a loud clicking noise, (click click click in rapid succession, espically while turning or under accleration) while wheel bearings will make a growling sounds.
Dec 09, 2013 | 1995 Nissan Quest
2000 Subaru Impreza Sedan; Couple different noises
the screaching noise is 1 of your belts needs to be tightened. noise from the right front tire sounds like a bad sturt or ball joint and that needs to looked at
Jan 07, 2013 | 2000 Subaru Impreza
My 1999 ml 320 steering wheel spins all they way around 360 degrees and it makes a straining noises when it turns. and it's very loose. help
Check your power steering fluid. Screeching will come from the fluid being too low and would affect the steering. It will also burn out the pump if you don't keep it full.
Oct 05, 2012 | 2001 Mercedes-Benz ML 320
My 1998 grand cherokee makes a very loud noise from the muffler, it sounds like a gun shot, shakes and then stops
Didn't you go for a road test with the mechanic along
Why didn't the repair shop resolve?
Sep 19, 2012 | 1998 Jeep Grand Cherokee
The screen color started flashing funny. I turned the TV off. When I turned it back on, it makes a horrible groaning almost grinding noise, on and off, then finally stops trying to do what ever it's trying...
This tv have a colors wheel,it dying,now it dead.Colors flashes black&white and grinding noises,the colors wheel was spinning off of it motor axis and rubbing it sides wall.The colors wheel,now require changing to make the tv work again.The colors wheel it pretty hard to replaced,because it require take out many machanicals parts even can get to the colors wheel to replaced it.Best it to hire a tv tech. to do the job.If u never done or change anythings,that require take out alots and many machanicals parts before.
Oct 20, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Clicking noises and no recognition on computer
The read mechanism is stuck that is it is unable to move to the next section on the magnetic platen disk inside the hard drive \
It has come to the end - of - Life and need replacement.
To recover your data before it completely dies is to put the drive into a usb case and connect it to the computer that has a large capacity drive and backup the drive contents. You will have reload Windows to the new drive.
Apr 06, 2010 | Western Digital My Book Essential Edition...
My Kenmore Soft Heat Dryer starts, then stops.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
fsh
Dec 10, 2008 | Kenmore 74602 Gas Dryer
Brother GX6750 Typewriter Logo
48 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
