Acer aspire t671 wont boot up
My 5yr old Acer aspire T671 wont boot up, the power light and the red one comes on but screen still blank, (i did get the beeping and took out the ram's and put them back and now i don't get the beeping but still got the problem) can someone help please thx :P
  • 27,725 Answers
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty
http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
Testing & replacing the PC's power supply
http://www.youtube.com/watch?v=hbNxhvm0czs
One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect/ boot up a computer hard drive
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards
Remove the memory modules from their slots.
Take the opportunity to clean the slots on the motherboards and the memory module connectors.
Use compressed air to blow dust away and clean contacts with a soft cloth.
Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components.
Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r
Allow the pins to dry.
They will air dry in a matter of minutes.
If reseating the memory did not resolve the issue try swapping the location of the memory.
If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
Check the memory module and memory slot contacts.
They are either copper tin or gold.
The colour will tell you which they are.
Mixing tin and gold can result in corrosion that prevents proper contact.
Look for any sign of physical damage to the memory module, memory slots or the motherboard.
Reseat the memory modules.
You should hear an audible click when they are in place.
Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard.
The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible.
Could be a problem with the Hard Drive or the Hard drives PCB
http://www.onepcbsolution.com/
http://www.youtube.com/watch?v=du0Qd_3wFWM
There is a connection problem such as a bad cable
for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a
secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide
this will be the first to fail
Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty.
or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Posted on May 05, 2013
3 Suggested Answers
MATRIX_MMX
  • 209 Answers
SOURCE: acer aspire not booting up
Dear f1at3r1c
Righteo then, you should be starting by resetting your BIOS, and you can do this by removing the outer casing o the PC tower. Once yoiu have done this you then need to find the jumper that clears the CMOS/ BIOS. Now if you are somewhat unsure of what a jumper switch is, it just consists of a smallplatic cap which covers two metal conductive pins on the motherboard. There is usually a pin which is not covered.
Now once you have found the CMOS/ BIOS jumper setting, you will need to first remove the motherboard battery. The battery is nothing more than a glorified watch battery of the CR2032 type, and it will be silver in colour and obviously round in shape (typical cell battery).
Once you have removed the battery, you will need to then clear the CMOS/ BIOS and this is done by moving that jumper switch into the clear position. The pin that is exposed will need to be covered withthe plastic jumper, and the pin on the opposite side will need to be exposed. Leave the jumper in the clear position for about 10-20 seconds or so, and then replace it back to the original position. (doing this discharges all of the electricity in the BIOS/ CMOS chip). Once you have done this, you put the battery back in place and then start the machine, then you are good to go. Start the machine and enter the BIOS as you planned to do. You might want to consider ormatting your hard disk and re-installing windows or whatever operating system you have, and this is eeasy enough, just change the boot sequence to boot from your CD/ DVD drive first, the your hard drive second. Once its loaded up, re-enter the BIOS and reset it back to HDD first.
Now f this has not worked, then you have an oooopsie (this is my saying of oh ***T, oops, something has malfunctioned. Its more than likely to be hardware driven, so take out your hard drive first and try to boot, if it lets you bios, then you found your fault. Try this with all devices until you either find the fault, or you have narrowed this to your processor/ motherboard.
Now im sure this will solve your problem, but there is one thng you should need to know about, and it is how to identify the correct jumper. This will have either any of the following markings written on the motherboard very close to the where the jumper is. You may need glasses/ magnifyer lens in order to read the lettering, but it should say one of the following things.
CLRCMOS
CLCMOS
CLRBIOS
CMOSRST
RESET
CMOSRT
BIOSRST
CMOSCLR
CLEAR
could also be under J1, JUMPER1
Now im sure that this is the fixya for you, but if this still does not work, then please get hold of me, and i will provide you with more info.
I wish you all the best, and hope you manage to solve this issue sortly
kind regards
yours sincerely
Oz
Posted on May 11, 2008
bronk50
  • 27725 Answers
SOURCE: My aspire T671 won't boot passed the acer splash
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue then select restart if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred
you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work
hope this helps you
Posted on Feb 25, 2012
Where is my back up battery in my acer T671
You'll need to disassemble the laptop to see the motherboard. Is your main battery charged? May have a blown diode on the power input.
Sep 03, 2014 | Acer hi.3670c.001 - Aspire T671...
Forgot password to go back to factory settings even the hint not help me
What operator system are you using XP , win8 if winXP press Alt-Ctrl-Delete all together (same time) while re starting your pc it should give you Use and pass word in the user box type Administrator password leave blank that should let you in... tekgods.com
Apr 21, 2013 | Acer Aspire T671 Drivers Recovery Restore...
hope this helps you
Feb 24, 2012 | Acer Computers & Internet
Ms-7326; i would like to receive a manual for the ms-7326 mainboard.
User manual you can find on Acer site, under:
Aspire T671 Aspire Desktop
Service manual:
http://elektrotanya.com/msi_ms-7326_rev_2.0.pdf/download.html
(Get manual link)
Sep 02, 2010 | Computers & Internet
Acer aspire T671-F872 what are the drivers for the soundcard (type unnown)
Use a program to tell you evrything you need to know.
I use PC Wizard,
It is an advanced system information program
Jul 23, 2010 | Acer (54.AA806.001) Sound Card
I have an acer t671 tower. it recognises a speaker but the sound does not come out
your sound drivers may not be correct.
Do you have a volume icon in your task bar.
If not then go to control panel then sounds and audio device.See in there if you have the option to show icon in task bar.If the colour is faded and you can't change the options then it probably is a sound driver problem So you will need to reinstall your driver
Jan 10, 2009 | Acer Aspire™ T180 PC Desktop
A crashed acer aspire t671-tb7z
Try pressing F12 on boot-up. I'd recommend getting another PC as I have had multiple problems with this one. Or at least make sure you back up work regularly
May 05, 2008 | Computers & Internet
Computers & Internet Logo
183 people viewed this question
David Payne
David Payne
