Question about Hayward SUPERPUMP 2.0 HP, 115/230V
C48k2n143b1 Need to know the proper capacitor
    Top Expert:
  • Hayward Master
  • 4,292 Answers
Takes it out and go to a electrical store
Posted on Mar 05, 2016
How much HP has the pool PUMP C48K2N143B1 and how much it cost brand new if still available
the motor details will be on a plate attached to the motor body
if it becomes necessary to replace the pump unit , talk with a pool/ spa shop or large hardware store as pump prices vary according to manufacturer
Jul 13, 2016 | Pool & Spa
I have a new C48K2N143B1 that I'm replacing the same model that has quit. It came configured for 230 and I switched the tab for 120. Wired everything the same as the old motor and it keeps tripping the...
make sure you have clean source voltage coming in like a knicked wire touching the case, also make sure you dont have the hot wire leads touching the frame or something else
Jun 19, 2014 | Hayward 3/4hp Super Pump Inground Pool...
Hayward c48k2n143b1 capactor
the ,motor is lock up ? or u are correct may be the start capacitor remove the old one and look for UF-rating (124,160 ) CHECK yourself
Jun 08, 2013 | Pool & Spa
Samsung t240 - discharging capacitors?
The main 400v capacitor is the one to watch out for. If you carefully handle the power supply board and avoid the area around the power plug you should be good. To properly discharge the capacitor you would need to use a very large resistor and wire to short out the capacitor but if you do it the wrong way you can damage the board beyond repair. Below is a picture of the T240 power supply board with the 400v capacitor circled in red. If you need to get the other capacitors that need to be replaced on the board, which is the most common problem then you can get a parts it here:http://www.ccl-la.com/catalog/product_info.php?products_id=205
I hope this helps,
BuddyMc
Sep 20, 2012 | Samsung SyncMaster T240 24 inch LCD...
Where can I find directions on how to replace the capacitors in the Akai LCT3201AD. I can order the parts, just need to know how to do it. Thanks!
hi, to replace the capacitors need to take the board out, by removing the screws and disconnecting the wires braids. You need bread, tin and absorbs tin. You should take the tin from the legs of the capacitors, until it can release the capacitors outside the board. Next, you put the new capacitors in place. Should pay attention to put the capacitors, by proper polarity of plus or minus. It is important to be precise with the value of capacity and try to put a capacitor with a value of slightly higher voltage, temperature resistant to 105 degrees.
Mar 15, 2011 | Akai LCT3201AD 32 in. LCD Television
I have a 1 hp hayward super pump. the model # of the motor is C48K2n143B1. I need to replace the motor only. is it a big deal?
If you've never done it before, it can be a bid deal. You will need to get the exact replacement motor (1hp square flange), a shaft seal, impeller wrench, and be prepared to replace o-rings and rewire the new motor. If you're not comfortable dealing with electrical/mechanical, you're better off getting a service tech to help you out.
Sep 15, 2010 | Hayward 3/4hp Super Pump Inground Pool...
I have a Hayward Max-Flo Pump model no. C48K2N143B1!!
To the motor housing. This will be a green screw on the top of the wire box in the back of the motor. It will be inside the wire box but on the outside edge of the housing.
Jul 18, 2010 | Hayward 3/4hp Super Pump Inground Pool...
Hayward SUPERPUMP 2.0 HP, 115/230V Logo
121 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
