Question about Saws
Change a saw blade hitachi C12fdh - Saws
2 Suggested Answers
woobie dog
  • 1273 Answers
SOURCE: How do you release the saw blade from the closed
Hello, W/D here.
At the back of the saw, where it hinges, is a pin that locks the pivot joint. Push down on the saw handle while pulling the pin, then allow the saw to rise to the ready position. Reverse the order to store the saw.
Best regards, --W/D--
Posted on Feb 23, 2011
I have a 12' Hitachi compound miter saw C12fdh model. the saw quit working. What should I look at to correct this?
look for reset switch. some models have a hole that you put a paper clip end in
Feb 02, 2018 | Cars & Trucks
Change blade without hitachi wrench
Which way do i turn the nut on the saw blade to change my blade? to me or away from me? looking at it from the front.
Mar 03, 2013 | Hitachi C10FR 10" Job-Site Table Saw 15...
How do you change out the blade?
Raise the blade as high as it can go and you will see nuts in the center of it, untighten them and the blade will come right off, replace and put back on the way it came off.
May 17, 2011 | Hitachi C10FR 10" Job-Site Table Saw 15...
The laser stopped working on Hitachi 12'dual compund mitr saw,are there batteries that can be replaced or does the unit need to go to a tech? The laser only worked for a month and the saw is only 3 months...
The laser modules in saws are usually powered by induction from the spinning saw blade. Since your saw is only three months old hopefully you either registered it with Hitachi when you bought it or you still have your receipt as this type of failure would be covered under warranty. Call Hitachi, they may send the part to you if you are comfortable with doing the repair or they will tell you where the nearest Authorized Service Center is for warranty work. Hitachi's number is: 800-706-7337 or 770-925-1774.
Jan 27, 2011 | Hitachi C12FDH 15 Amp 12Inch Dual Bevel...
How do you put a blade in a hitachi cj110mv jigsaw
on the front of the saw where the blade is there is going to be a little lever you pull while at the same time push the blade in the blade holder
Jan 16, 2011 | Hitachi CJ110MV D Handle Jigsaw
My Hitachi cj 110 jig saw blade keep falling out I have tried different types of blade What?s the deal with that? I don?t know why someone would put a quick release holder on a blade shaft of a power tool...
WOW everyone really cant figure out the problem??? Take your jigsaw blade and hit it with some coarse sandpaper or a dremel and knock the finish off the edges and sides depending on maker and it willl work just fine. The blade companys put a super slick finish on the blades. not the saws fgault.
Steven Melton
OKC
Jan 09, 2011 | Hitachi CJ110MV D Handle Jigsaw
My blade appears to cut or move straight. But when I cut a piece of wood on it it wobbles. You can't wobble the blade with your hand. It appears to be in there tight. What could be the problem?
You likely need to replace the blade i have hitachi 10 inch chop saw with the lazer i love it the best one i have ever had vary well build But any saw is olny as good as its blade if ti were a lesser mechine i would say it could be the baerings but i see how hitachi makes tools so i would say its the blade got over heated at one time now when it gets hot it looses its integreity buy good blades as a rule
Nov 30, 2010 | Hitachi C10FL 10" Stationary Table Saw...
Just want to know the steps in changing a chop saw blade
there should be a push in switch near the top back of the saw that pushes in and locks the blade, look for this blade lock and than you take the screw off that holds the blade in place and make sure you know the order of the washers and locks so you can replace the same way you took off
Sep 05, 2009 | Hitachi Saws
How do you swap out the c12 fch hitachi blade
all you do is pull the gard up you will see a bolt on the left side using a 9/16 rench pull it to you remove the bolt blade comes off . on some you need to take the gard off it has one screw on it that will be on the right side as well... good luck..
Aug 16, 2009 | Hitachi C12FDH 12" Dual Bevel Miter Saw...
Saws Logo
347 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
