Question about Alpine MRD-M300 Car Audio Amplifier
My amp not workin
Hi, when i try to play ma amp it comes on but it does not play i checked every thing then my friend sayed i prolly burned the channel. how do i fix it are how much will it bee ? were can i send i t to be fixed ? thanks
  • hylife2008 Nov 15, 2008
    My amp turns on but the protection light work go off.. What could it be?? Ive tried more and different ground. It worked when I went in the store and didnt work when I came out and i would really like it to work..
    Problem Solver:
  • 4 Answers
Try using some sand paper where you have the ground, grounded, it that doesnt work i would say one of the transistors inside broke off. to know if that happened shake it a little to see if you have any rattle if so you or someone you know who can solder and get it put back on
Posted on Jan 21, 2009
Or make sure your ground wire is grounded properly.it's very important!
Posted on Sep 09, 2008
  • 4 Answers
If the amp doesn't play anything but comes on you probably don't have an input signal try to get a different input signal
Posted on Aug 22, 2007
SOURCE:
My 04 Camry xle will load the cd's but will not play. Is it junk?
Check the CD's. When these are copies, burned in a computer, your player could have problems playing them. Not all players can play self burned CD's. An original CD has a metallic reflective layer, with a high contrast on reflectivity. The self burned CD's only have a dye, where a laser changes the colour on the same places as the pits are on a real CD. But the dye gives less contrast. When on the player is no logo, compatible with CD-R, you can't expect it will play these. When it won't play real CD's, perhaps you could try a cleaning CD and try playing a CD again.
For that you can buy a cleaning CD, with a soft brush. dust and a coating from smoke can be removed. If the laser is defect, not aligned or not calibrated, don't try to cure that.
The brush on the CD looks like this:
Feb 25, 2015 | 2004 Toyota Camry
I cant hear any voices on dvds played throught the dvd system just the bass and background music its all plugged in correctly and set on clear help!
please double check your wiring again as if you cross the polaritys (+ and -) you put the audio signal out of phase, thus casing cancellaion of things such as voices.
+ to +
- to -
NOT
+ to -
Jan 07, 2011 | Technics SC-DV290 System
Amp burned out but fuses still good?
this is caused by inproper wiring from the speakers/subs to the amplifier.. an amp will still put out power to subs and speakers when it's wired improperly but it won't last for very long doing it... 6 months is longer than usual....
Dec 05, 2009 | MA Audio M1900XE Car Amp
Dvd burns disc then says wrong disc when played in dvd player or it will not fully burn and says burn error tried various brands and different burn speeds
Hi my name is Roety,
I can help you with your issue ,
After burning you need to finalize the discs in the disc menu , then the player will read them
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Oct 20, 2009 | Computers & Internet
I have a volfenhag zx-8400 amp. i dont have a manual. whats the proper way of conecting amp? its mounted on my speaker box, which is ported, 12' volfenhag 2500 watts. on the side of amp it had voltage...
The voltage prolly says like 100Mv-2v, it doesn't really matter, just know that that the lower you turn it the harder it bangs. The X-over depends on where your box is tuned, crank the knob down too about 40htz and you'll prolly be good, just don't turn it lower than your box's tuned frequency. And your rca's go to line input. And there shouldn't be a problem with mounting your amp vertically, you prolly just had a bad connection. Hope this helps if you have more questions please ask...
Sep 21, 2009 | Volfenhag ZX-8400 Car Audio Amplifier
I think ma kicker kx1200.1 amp is blown or ma kicker L7 are gone
that would be the amp. sorry to say. when a wire crosses over, it sends a shock through the amp, there are a few things to try just to see if you fried the amp. the first thing to try is to move your ground to a different location. second thing to look at would be the fuses. alot of times the fuses will blow at the slightest shock. the amp will still turn on if you have an amp with 2 fuses, it just wont be getting all the power it needs, which could be causing your problem. also, it is worth the hour and a half to mount everything down in your vehicle. you might check the kicker website, because i have herd rumors that kicker offers a lifetime warranty on almost all of their products. best of luck, and i hope you didnt fry your amp.
Apr 09, 2009 | Kicker KX1200.1 Car Audio Amplifier
Ma audio hk 4000d
you have definately blown a output channel, or power supply. Send it in for warranty.
Jan 09, 2009 | MA Audio HK4000D Car Audio Amplifier
Protection light
either you are playing too loud or you have a malfunctioning protection light. does your amp seem to get excessively hot, as long as it doesnt, then your problem is prolly just the light itself...
May 11, 2008 | Car Audio & Video
CORRECTING FRENCH TEXT
Hi..try this go to tools in microsoft word 2007.....now you can have two things here.........first check which language is selected as your primary language......if english then select french from the list provided...........secondly here you can find an option saying """""" do not check spelling or grammar"""""""" if it is checked , then uncheck it.
Try these .....hope your problem will be solved.
Apr 14, 2008 | Microsoft Office Standard for PC
Alpine MRD-M300 Car Audio Amplifier Logo
99 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Robert Salgado
Robert Salgado
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
