Question about TOYOTA SIENNA MINI VAN 98-03 SLIDING SIDE OUTER DOOR HANDLE TO1521115
Lack of power
I am losing pwr esp when on up hill grade
    Master:
  • 548 Answers
Check fuel lines filters
Posted on Nov 05, 2013
2001 mazed tribute runs good no power to go up hills ?
Search Results
    Bogging - lack of power going up hills ' SHO Forum
    www.shoforum.com/index.php?threads/bogging-lack...power...up-hills...
    Oct 17, 2006 - I just ran into my first problem - The car runs fantastic on flats, going downhill,... ... No problem pulling up that hill at slow speed - plenty of power. It's only when out on a ... Anyone got a handle on a good used torque converter?
    why do i lose power on hills - CarGurus
    www.cargurus.com > Questions > GMC > Sierra 1500
    CarGurusOct 17, 2013 - I lose power on hills change the fuel pump and checked timing changed catalytic ... The TPS will make the ECU "go nuts" as it says...I'm here. ... has no power going up hill with small boat on, on flat ground runs good 1 answer.
    2000 toyota corolla lx aut. 4cyl. car looses power no power ...
    www.cargurus.com > Questions > Toyota > Corolla
    CarGurus
Mar 28, 2015 | 2001 Mazda Tribute
Noise in engine sound like it is coming from top engine when raving it up ratteling noise. Engine runs fine
Noise could be lack of oil or wrong grade of gasoline.
Check your oil level.
If the noise is worse when the engine is working harder, like going up a hill, you should try higher grade of fuel, like premium.
Hope this helps.
Mar 19, 2015 | Cars & Trucks
Why does it lose power going up hill and fine on level ground
if the transmission dont slip that means the engine lacks power.
(torque)
this can be from forgetting to do tune ups>? every 60k miles. or per the operators guide, some cars need spark plugs every 30k did you RTM read the manual yet>? please do.
in order of likely (not physics)
bad spark (misfire) induced low power.
bad fueling lean
bad fueling too rich. (more misfire spark plugs turn black (tips)
bad engine. (compression loss)
the rare CAT melted, (inside) and getter worse.
to solve a riddle we do tests. simple tests with simple tools.
do you want to guess or test. it's your call.
Jun 27, 2014 | 2003 Hyundai Santa Fe
YQ50 loses power when going up any sort of hill
Hi, Anonymous for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
2008 50cc Super Battle The Scooter Review
2 stroke scooter engine suddenly lacks power when going up hill
Yamaha YQ50 Service Manual
OEM parts for Yamaha
YAMAHA AEROX YQ50 Owner Manual
Feb 05, 2014 | 2006 Yamaha yQ 50 Aerox R
No power when going up hill
Read the engine light on the OBDII then post the code if your code reader doesnt have the explanation of the code ,although i would suspect a faulty O2 sensor not giving the right fuel ratio but ? iam always wrong here when i guess things
May 20, 2013 | Kia Sorento Cars & Trucks
Toyota townace 3c turbo engine lacks power on the hill . What is the areas to check?
weight, speed, and grade of hill could be determing factors....did you have problems with this hill before, in this vehicle?
Dec 07, 2011 | Acer Aspire 15.6 LCD, Dual-Core, 4GB RAM,...
2001 accent loses power on hills and sometimes backfires, replaced the mass airflow valve and both o2 sensors what else could be wrong. getting the p2032 code when card is read
p 2032 that the result of lack of power, the air flow was a good start but not the problem solution.loosing power on a hill your engine starves for fuel.by the way does the front timing cover have a noisy t belt.
Apr 21, 2011 | Hyundai Accent Cars & Trucks
Mazda 323 fuel injection1994 accelerator problem
Try changing the fuel filter. If it clogs up the engine won't get the fuel it needs to run at wide throttle openings, the engine will ****** the timing, and you'll lose power. With less throttle the filter can flow well enough for the engine to run properly.
May 16, 2010 | 1994 Mazda 323
1993 Mercedes 300D loses power up hills.
it could be a turbo problem but i dont think its the transmission or it wouldnt be shifting.it almost has to be the turbo.
Jan 13, 2009 | 1993 Mercedes-Benz Mercedes Benz 300 Class
Losing power up one particular long hill
If there are no lights or ECU codes, esp the water temp sensor, then the usual remedies are to use injector cleaner, and clean the throttle body, check for water in the fuel filter (and the fuel tank). Make sure the engine oil level is full, and so on. I assume a hill outside Sydney doesn't get enough altitude to be an issue, unlike a hill outside of say Denver, CO that goes up near 10,000ft above sea level where you should expect a significant power loss.
Sep 09, 2008 | 1991 Subaru Legacy
TOYOTA SIENNA MINI VAN 98-03 SLIDING SIDE OUTER DOOR HANDLE TO1521115 Logo
59 people viewed this question
Top Depo Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Depo Vehicle Part and Accessory Expert? Answer questions, earn points and help others
