Question about Garden
How do i put a belt back on my Aries 934 riding mower
A belt came off of pully to make mower move .Is there an easy way to put it back on .it is hard to reach
  • 376 Answers
SOURCE: Replacing the Drive Belt on a Poulan Riding Mower
Without an impact, it's will be more difficult. The only way to get back-up on the bolt is to remove the screen over the flywheel on top and put a socket on the flywheel nut
Posted on May 28, 2009
bargainbin2
  • 123 Answers
SOURCE: need a diagram on how to put a drive belt back on
It is a hard one to put on co look at the picture carefully there are two pulleys one that one side of the deck that are trickey.
Posted on Sep 01, 2009
SOURCE: Murray Riding Mower will not move forward or back
my murray Riding Mower will not move forward or backward
Posted on Sep 03, 2009
  • 299 Answers
SOURCE: Craftsman riding mower won't move.
yes it is a bad belt unless it is a hydro-stat(no clutch) you need to look under the mower and see if the belt is on correctly
Posted on Sep 30, 2009
mickey813
  • 472 Answers
SOURCE: We have a Weatern Auto Wizard Riding Lawnmower.
19c5756.gifHOPE THIS HELPS LET ME KNOW
Posted on Nov 19, 2009
How do I change the belt on my Poulan riding mower 733-864?
lower the mower deck down all the way. look at the belt routing so you remember how it goes back on. pull the belt off the engine pully first then off of the other pullys and install the new belt.
Sep 09, 2014 | Poulan Garden
Tip
A bad eletrical
if ypu have a garden tracktor you can jump it if your eletrical is bad
1 HOW unplug all wires from mower 2 remove blade deck and use the pullie belt to start
put belt on the pullie weel an put as hard as you can
on Feb 27, 2010 | Garden
Drive belt for 46" mower deck jumps off
The tentioner could not be applying the right preasure. Make share it is not sticking and that it is moving free.
Jun 22, 2013 | Craftsman Garden
How do I put the drive belt back on my yard man automatic riding lawn mower?
The v side of the belt goes in the v of the pullies and the flat side of the belt rides on the flat pullies. It looks like the flat idle pully is bent out of alinement. The one showing in video with no belt on it that is the last pully the belt runs on before returning to engine. The belt comes from the engine to a spring loaded flat pully, to v pully on right of mower ,to v pully on left, to flat idle pully // that looks to be bent // then back to engine. Put belt on all pullies saving the spring loaded pully for last.
Apr 09, 2013 | Garden
I bought a montgomery ward riding mower 1980's. it worked fine while testing. So i purchased it, i got half my own lawn mowed then started to smell a burning rubber smell, stopped and looked around. didnt...
Pulley bearings sieze up all the time. They are universal and easy to change, but you could probably take the old one apart and just clean and grease it as well. Just make some wood ramps so you can get under neath to work on it. Might be best to change the belt by this point.
Clutch is not likely an issue since it was working at the beginning you were not really using it much while you were mowing.
Oct 10, 2010 | Garden
When in gear, the brakes won't stop my mower. Also, it's very difficult to shift out of gear once the mower is in gear (forward and reverse).
drive belt is not getting slack on trans pully when pedal is pushed down.check all belt guides on outside of pullys .also check for worn pullys if v in pully is not flat may cause belt to hang up may want to try to adj brake rod that moves pully that slakens belt .hope this helps
Aug 14, 2010 | Garden
I HAVE A JOHN DEERE L118 RIDING MOWER AND TODAY WITHOUT ANY WARNING THE MOWER JUST STOPPED MOVING.I HAVE NO LEAKS OUT OF THE TRANSMISSION AND THE BELT IS NOT THAT LOOSE. THE LINKAGE IS ALL GOOD AND TIGHT....
yes,,, they just go bang,,if its striped the drive key they just stop,
have a look at the pully ends if you can turn one with out nothing moveing the key has striped take off the pully and replace the woodruff key,,easy to fix some times?,
Aug 08, 2010 | John Deere Garden
How do replace the tensioner pulley on a 2.2 engine 4 cyl. 1998 chevy cavelier .
there are two bolts located behind the pully on the mounting bracket arm, (you have to use a 1/2 inch drive bar in the idler pully to move it so you can see the bolts) That will help you with locating the bolts, while you are moving the pully you might as well take the belt off to save time, After you remove the old idler pully install the new one, use your 1/2 drive bar on the pully to put your belt back on. Pretty simple job, good luck!
Jan 08, 2010 | 1998 Chevrolet Cavalier
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
