Question about Pioneer Car Audio & Video
AVH-6300BT not play youtube
When connect with Iphone4s with its cable no VDO out
  • Kris Ryu May 07, 2013
    Previously, I have connected my device with Iphone4s with played on youtube app, everything went well. But now after I connected to the device again there is no picture or VDO on the device it is only sound .
I have a pioneer Avh-x5600bhs and am trying to play audio on a DVD. Some songs play, but I get two error messages. 02-99 and 02-a9. Any ideas? Thanks
Your manual should say what kind of format it playes, and this link is good explanation ,also some burnt dvd do not play cause the player does not have the proper driver of internal decoder .
https://www.youtube.com/watch?v=cnDI10ksHyI
Feb 23, 2015 | Pioneer Car Audio & Video
Not getting any sound from my i-pod Pioneer AVH-P4050DVD
I had the same problem with my Pioneer AVH-P4050DVD
Radio and CD worked fine
DVD would play and I could hear the audio but no video
USB and iPod. It would connect and I could brouse, select and play songs but I would not get any audio even though I could see the track playing, finnishing and moving on to the next one (very frustrating).
Front Aux (Aux 1). I could turn this port on to audio, select it and plus an audio sorce in but no audio would come out.
The solution..
The Pioneer AVH-P4050DVD is odd and different from most other pioneeres in that it has two earth leads that both need to be grounded (2 in addition to the handbreak wire). I had insalled my unit using a toyota - pioneer wireing adaptor I bought from Repco. This adaptor only grounded the wire coming from the corner of the plug (opposite the battery wire). The second earth is located becide the first earth, opposite the ignition wire. If you google pioneer 16 pin wiring diagram it might call this pin BGSENS (pin 13 in the attached photo). With the wireing harness I had this pin was not connected to anything. Once I grounded the second earth (soldered directly to the first earth) everything worked.
Good luck. Hope that helps.
Jan 11, 2013 | Car Audio & Video
I have an Avh-p4100 and the IU200V cable. My DVD was playing the videos, but now it simply doesn´t play videos anymore. The cable´s plug is right conected back the DVD, and in the initial menu,...
Try resetting the unit using a pen. While powered on, click the reset button and this should resolve your problem. If it doesn't the problem maybe related to parking brake cable not being connected properly.
Mar 04, 2010 | Pioneer AVH-P4100DVD Car DVD Player
How do i play video from usb on a Pioneer AVH-P4000DVD?
You can NOT view video using USB on this unit. Video has to come from the AV inputs (RCA connections) or from an IPOD connection. Sorry.
Jun 30, 2009 | Pioneer AVH-P4000DVD Monitor
Ipod problems on my pioneer avh
To be working the ipod need to be hook up with the cable cd-1200 (not sold with the avh)and to be plug to the ipod plug on the back of the radio..if you plug the ipod on the usb it wont do..the cable is around 30 $ ..it is the good way to play your ipod ..but if you have a ipod touch 2 generation like i have it wont charge ..if you have any other ipod it will be charging when in use..
Mar 04, 2009 | Pioneer AVH-P4000DVD Monitor
Vdo does'nt play
Sometimes your TV might might have the problem, check your TV.
Did you connect the AV cables properly, check if it is connected properly.
if problem still persist, please check your TV AV components
Jul 30, 2008 | Sony PlayStation 2 (PS2) Console
Help
DId you check to see if the parking brake cable ha been connected correctly?
You may have to have the bypass installed or check the cable and ground
Jul 07, 2008 | Pioneer AVH-P7480DVD Car DVD Player
Video ipod
you have to get an iPod cable that gives you RCA outputs. Just connect the RCA outputs from the iPod to the AUX inputs on the unit. I believe that should do it. Ebay sells the iPod cables, and most electronics stores should as well
Dec 22, 2007 | Pioneer AVH-P5700DVD Car DVD Player
Car Audio & Video Logo
27 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
