Question about Garmin GPS
Garmin 5208 overheating and abnormal shutdown
5208 chart plotter overheating and shutting down.
SOURCE: Garmin 320 shuts down
I suggest you take it to the store. Probably an internal errorr
Posted on Jul 05, 2008
Maanita
  • 1142 Answers
SOURCE: Ais and 1920c Furuno chart plotter
n the system setup, under “UNITS” I set BEARING to “MAG” (magnetic). This will cause the unit to display course / bearing information in relation to the Magnetic North and match magnetic compass readings. It is not the same as True North! One has to be careful with this setting. There are a number of areas where the earth's magnetic field is locally disturbed, sometimes very significantly. Your GPS may not account for it. - again, under “UNITS” I set “METRIC”.
Posted on Sep 02, 2008
  • 43 Answers
SOURCE: The chart plotter worked perfect for 5 yeas,
I think you have a C- Map card (black colour)clean the contacts with a contactcleaner if it not works try the card somewhere else
The C-Map card have problems that they work for a while and than stops inside the card a some memorychips and they losing contact
Posted on Oct 22, 2009
pabloloco
  • 2335 Answers
SOURCE: GPS operation freeze up
Upgrading the system software of your GPSMAP 545s will most likely fix your freezing up problem.
I hope that helps.
Posted on Jan 31, 2010
SOURCE: My Raymarine C80 CHart plotter won't load.
Check to see if this is a power issue by connecting to shore power and fully charging your batteries overnight with instruments off. While still connected to shore power, with batteries fully charged, turn on C80 navigation system. If the loading screen comes on and does not reset, then try holding down the button immediately to the right of the red power button for at least 3 seconds to see if the system re-boots.
Posted on Apr 28, 2010
Testimonial: "Factory reset solved the problem. Soft key next to power button worked a treat!"
Raymarine dsm300 Circuit breaker keeps tripping g when connected to chartplotter
either the cord to the chart plotter is faulty or the chart plotter itself is dead short
have an electrician do an insulation test and circuit test on the cord and plotter unit
Jan 08, 2017 | Raymarine Boating
Is their a internal battery in sitex colormax 11
Yes. There is a battery backup to store memory. Read all about the Sitex Colormax chart plotters here:
http://www.si-tex.com/product_manuals/Chart-Plotters-3-08.pdf
Apr 28, 2014 | SI-TEX COLORMAX 11 GPS Receiver
My hp designjet 500 doesn't recognize the I/O Card
By I/O card I assume you are referring to your JetDirect or the optional HP/GL2 formatter board, your EIO devices?
If you have them installed and the plotter does not recognize them.
Shut down the plotter then remove the power cord from the plotter or the wall and wait 5 mins.
Remove ALL EIO devices (JetDirect / formatter).
Plug the plotter back in and restart the plotter.
Test functions of the plotter.
Shut down the plotter and then add back only the JetDirect.
Start the plotter and check the function, and check if the menu will allow you to setup the JetDirect.
If successful, shutdown again and reinstall the Formatter Card (if you use one).
Test functions and check the I/O setup in the menu.
The idea in a nutshell, remove the cards and add them back one at a time to see which one if any is bad and causing the I/O to shut off.
If this does not help, you may need to replace the plotters Electronics module
Aug 16, 2012 | HP DesignJet 500 InkJet Printer
How do I shut off my computer? L670 series
Normal shutdown: Click on Start button (lower left corner on most PC screens), and then select shutdown.
Abnormal shutdown: If computer is "frozen" and you can't click on Start button, press and hold the power on/off button until the computer shuts down.
Jan 24, 2011 | Toshiba Computers & Internet
Apr 13, 2010 | Raymarine C80 GPS Receiver
I hope that helps.
May 31, 2009 | Garmin GPSMAP 545s GPS Receiver
Garmin chart plotter not booting up.
Hi again,
Appreciate the update. Incidentally, most batteries for this purpose are Lithium 3 volts, coin size. Often, battery removal also performs a reset if not replaced immediately.
Though my money is really on the firmware.
Cheers.
Jun 27, 2008 | Garmin eTrex GPS Receiver
Mar 02, 2008 | Garmin StreetPilot C320 (010-00401-00) GPS...
GPS Logo
65 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
