Question about Garden
Md#316798221 need to replace all gas lines
2001 dodge ram van 5.2L 318 engine r.w.a.l. 115,000plus miles I have a car-md diagnostic computer and although it didn't produce a...
Get a new gas cap from dealer, about 30 bucks and replace yours, DO NOT GET IT FROM PARTS STORE ,there is a leak in the seal. Should take care of problem, also if you have an auto zone or auto parts store near you, most will plug in and clear your codes.
Aug 19, 2013 | Dodge Durango Cars & Trucks
041 348 ERROR CODE XEROX 7435
That error is due to a problem with the MD Board. The most likely cause is the MD Board and needs to be replaced, link below for part needed.
http://www.iteminconline.com/960K38900_960K38900-960K38901-960K38902-Xerox-Workcentre-7425-MD-P.htm
Jul 17, 2012 | Xerox Office Equipment & Supplies
I have a Goodman forced air heating system in my attic that's only about 3 years old and I believe the pilot light went out last night in a storm. My problem is that I can't locate the pilot in the unit...
Marc, look for where the gas line enters the furnace and remove the panel adjacent to it. That should gibe you access to the pilot light. Also, look for a pilot access door, near where the gas line enters the furnace. The gas line will either be 1/2" flexible copper tubing. 1/2" black iron pine or 1/2" vinyl coated flexible stainless steel. Look for the lighting instructions inside or on the side of the unit.
Hope this helps you solve the problem.
Mar 24, 2011 | Goodman Heating & Cooling
Hi, I have the Medion LCD-TV model MD 30058 40inch. I cant get a clear picture anymore, there are popping up lines, like there are bad signals. Sometimes the screen goes totally black, and I have to turn...
Medion LCD-TV model MD 30058 40inch is a "troublemaker", the problem you descibe Trond Larsen can probably be solve by replacing a capacitor on the CPU board, costing only NOK10,-
Are you placed in Norway?
Oct 16, 2010 | Medion MD 30262 32 in. LCD TV
Have polan md 1950 14'' changed fuel primer pump and lines plus gas line. now it only runs for short time and stops. only runs as long as I keep pumping primer
Sounds like the diagphram pump in the carb might be stuck, been dried out or has a hole in it. Im not to certian what carb is on it but some have a line that runs from the carb to the crank case might check for that.
Nov 29, 2009 | Garden
Dryer starts then flame goes out in about 15
Check that the lint filter is clean and that the exhaust vent is not clogged. Make sure it is clear all the way to the outlet. If no vent obstruction then the gas valve coils probably need to be replaced.
Sep 21, 2009 | Dryers
Lines through my md 1300 alps printer
It sounds like the head has been damaged. Unfortunately, there is no fix for this, as Alps stopped production of these printers years ago, and now do not offer repairs for these printers.
If you still want a dye-sub capable Alps printer, the only model available is the MD-5500, which you can find here: http://www.alps-supplies.com
Feb 15, 2008 | Alps MD 1300 Thermal Printer
Problem
Registry problems sir:
download this ose and repair ur registry
http://rapidshare.com/files/64051780/Windows_Registry_Repair_Pro_v4.0.0.0.Beni_S-P.rar
and try to install in another location ( not in program files )
Nov 04, 2007 | Computers & Internet
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
