Question about HP Office Equipment & Supplies
Error 8 8 101 0
I am trying to scan a document, and every time I do, an error message appears. The text reads, "The HP scanning application is currently in use or unavailable. Close all open programs and try scanning again." I tried closing all of my open programs, and I still got the same error message. What do I do?
4 Suggested Answers
mattballew
  • 89 Answers
SOURCE: hp photosmart c8180 scans a
is this a reoccurring problem? If not then restart your computer and it should be fine.
Posted on Nov 25, 2008
  • 39 Answers
SOURCE: Scanner says in use when nothing is printing
These instructions will fix the majority of scanner2_bing.gif problems and networking problems using ethernet:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01849855&lc=en&dlc=ro&cc=ro&product=3643612&rule=4124&lang=ro
The key is to assign a static ip address for the printer. The install problems of trying to get the HP printer to be found will go away. You can then use the scanner. Also...it is crucial that when connecting other laptop's and PC's on the same network that you use the hp printer'rs host name to find the printer on the network. I find that the IP address can and usually fails to find the hp on the network. Mostly likely you cannot search the network for a hp printer until you go the route of find the hp network printer with the host name of the printer. You will also need your install disk when installing on other networl laptop's and PC's since windows xp and Vista machines don't have the drivers in the list. You will need to point the add printer gui driver to the disk and look for autorun.inf
file. After selecting that file...you can then see your drivers
Posted on May 21, 2010
SOURCE: when i try to scan any document im gitting the application is currently in use or unavailable , close any open programs and try again later . so please help me out to solve this pro.
buy a new printer but make sure it is not a HP. certain to resolve your problem.
Posted on Jun 10, 2012
Change scanned doc. to go to word not pdf
Depends on the document. If there are images and the type is handwritten. First scan the type as OCR scan so it scans only the text, a new window should appear for editing...nothings perfect...
Then scan the page with the images as a whole as doc file. Hope this helps, not all scanners are built the same, just have to read the instructions and features before buying.
Another way to scan to word is right from the MS Word Application. View the video to learn how.
Jan 13, 2015 | HP Deskjet 3510 e-All-in-One Printer
I have a problem after scanning, I cannot bring the document up in MS Word to edit. The document arrives on my computer screen but I can not edit it
You need OCR software installed in your PC
go to www.hp.com then type OCR application then download it in your pc
OCR Application File name: s.gif 23902_hpcom_OCR_120_003.exe [1/1, 54.84M]
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&dlc=en&lc=en&softwareitem=oj-72836-2&jumpid=reg_R1002_USEN
Text Cannot Be Edited After It Is Scanned to a Word Processing Program
Issue After scanning into a word-processing program, the text in the original is not editable. Workaround The process of changing text from an image to editable text is called optical character recognition (OCR). Text should automatically be converted in the OCR process when the Send To destination is a word-processing program. If it does not, check the items in the following list:
  • Select Editable Text as the image type in Scan Settings . In Windows XP, this setting is automatically selected if Scan Document is selected in the Director program.
  • Scan at a resolution of at least 300 dots per inch (dpi) for correct OCR conversion. Check the default resolutions in the Scan Settings on the Resolution tab.
  • If portions of the scan are cut off, turn off the Auto Crop feature in the Scan Settings on the Scanning tab by clicking to clear the check mark.
  • Tables, text boxes, and spreadsheets might not be editable. The border around them makes the OCR program read them as images. Readiris OCR, which is included with the HP Officejet G and K series, can recognize these images. Instead of selecting the word-processing program in the Send To list, send the scan to Readiris. Use the Table Drawing tool on the right side of the window to change the type of image to a table, and then use the OCR. The text inside of the box should now be editable.
    NOTE: Handwritten messages might not be captured by the OCR process.
Your's Truly,
Christian from HP
Say "Thanks" by clicking the thumb icon in the post that helped you.
Please click "YES" in solution that solves your problem as "was this helpful?"
(Although I am employed by HP, I am speaking for myself and not for HP)
Apr 10, 2011 | HP PSC 1315 All-In-One InkJet Printer
How do you scan an item to the computer
Use the scan features
Scanning is the process of converting text and pictures into an electronic format for
your computer. You can scan just about anything: photos, magazine articles, text
documents, and even 3D objects, as long as you are careful not to scratch the glass
on your HP All-in-One.
You can use the scanning features of your HP All-in-One to do the following:
● Scan text from an article into your word processor and quote it in a report.
● Print business cards and brochures by scanning a logo and using it in your
publishing software.
● Send photos to friends and relatives by scanning your favorite prints and
including them in e-mail messages.
● Create a photographic inventory of your house or office, or archive treasured
photos in an electronic scrapbook.
To use the scan features, your HP All-in-One and computer must be connected and
turned on. The HP All-in-One software must also be installed and running on your
computer prior to scanning. To verify that the HP All-in-One software is running on a
Windows computer, look for the HP Digital Imaging Monitor in the system tray at the
lower right side of the screen, near the time. On a Mac, the HP All-in-One software is
always running.
Note Closing the HP Windows system tray icon can cause your HP All-in-
One to lose some of its scan functionality and result in the No Connection
error message. If this happens, you can restore full functionality by restarting
your computer or by starting the HP Image Zone software.
For information on how to scan from the computer, and how to adjust, resize, rotate,
crop, and sharpen your scans, see the onscreen HP Image Zone Help that came with
your software.
This chapter contains information on: sending a scan to and from different
destinations, and adjusting the preview image.
Scan to an application
You can scan originals placed on the glass directly from the control panel.
1. Load the original face down on the right front corner of the glass.
2. Press Start Scan on the control panel.
A preview image of the scan appears in the HP Document Viewer window on
the computer, where you can edit it.
For more information on editing a preview image, see the onscreen HP Image
Zone Help
that came with your software.
3. Make any edits to the preview image in the HP Scan window. When you have
finished, click Accept.
The HP All-in-One sends the scan to the HP Image Zone software, which
automatically opens and displays the image.
User Guide 31
Scan
The HP Image Zone has many tools that you can use to edit your scanned image.
You can improve the overall image quality by adjusting the brightness, sharpness,
color tone, or saturation. You can also crop, straighten, rotate, or resize the image.
When the scanned image looks just the way you want it, you can open it in another
application, send it through e-mail, save it to a file, or print it. For more
information on using the HP Image Zone, see the onscreen HP Image Zone Help.
Aug 30, 2010 | HP PSC 1510 All-In-One InkJet Printer
If I scan a blank application to be completed after its scanned in order to print the completed application, I can't find a way to add and or edit text on it.
if you scan a document it will be a photograph   editing a document is done in a text application like word or notepad   the two are completely different things   i use text bridge  or Paperport Professional  it will read the text off of the scanner bed and convert to a text document   it may make some errors but will still save much time rewriting the document  add the saved text to word and change the font and spacing to try to duplicate the original document  save it  then edit it to your hearts desire
Nov 06, 2009 | HP Compaq Presario SR1303wm PC Desktop
Hp scanjet 8250. I want to set my scanner to default to PDF when I am trying to email. That is the way we do most of our scanning and right now it defaults to RTF.
Have you considered simply scanning from within Adobe Acrobat or similar software that produces .pdf and then use the email feature within Acrobat?
As I look over the HP User Manual, I can't see any method to set the default output. It simply says...
Use the E-MAIL button() to scan documents or pictures and insert them in an e-mail message as an attachment. You must have an Internet connection and a supported e-mail application.
1. Place the original face down on the scanner glass or face up in the ADF. If you are scanning two-sided originals from an ADF, slide the DUPLEX switch to two-sided mode.
2.Press the E-MAIL button().A message appears asking if the original is a document or a picture.
3.Select Document or Picture, and click OK.Note:A preview image will not appear when scanning from the ADF. To change this preview setting, see the HP Photo & Imaging software Help.
4. Select the final scan area (the area inside the dotted lines) in the preview image.
5. Make adjustments to the preview image if needed.
6. Click Accept.The final scan area is scanned and your e-mail application is opened. The scanned image is added as an attachment to the e-mail message.
7. The Save As dialog box appears. Type a file name and choose a file type, and click OK.
8. Complete the e-mail as usual.
Aug 07, 2009 | HP Office Equipment & Supplies
Scanning Problems
I would first make sure that you have latest driver update. MS Word is very particular about how it reads things back in. I would try saving the scan as a text file or PDF instead and then open them in Word. Hope this helps!
If this solution was helpful to you, will you please rate the solution? Thanks!
Aug 13, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Cannot edit scanned document
its like this, the OCR or the SOftware installed in your computer is limited. If you're trying to scan a document which has a picture or with text that uses different fonts like monotype, or those that are not usually being use for normal documents, usually it wouldnt detect and it become distorted. Anyways, here are the steps that i want you to follow.
1. Open solution center. (click start, go to all programs, go to HP, then click on SOLUTION CENTER). or you can see SOlution Center on your Desktop.
2. Click on Scan Documents, then the Scan documents setting will open. Change the settings to these.
* SCAN TO: Microsoft Word.
3. Then, hit scan.
4. After scanning, the folder My Scans will open automatically, just go ahead and open the scanned document.
5. From there, you can start editing the text.
..remember, the scan a document is limited, it will not read all types of fonts. if the document is using a "times new roman" or "arial" the scanned document appears to be almost the same with the original. But, if the scanned document contains pictures or stylish fonts, that would make the document distorted.
Please let me know if you still have clarifications.
Thank you.
adonscott
May 01, 2008 | HP Officejet 5610 All-In-One InkJet...
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
