TV/VCR combo needs fixing.
A symphonic SC309D will play the sound of a VHS but will not display the picture, any advice or help on fixing this issue would be much appreciated.
  • 3 Answers
Check if it is in game mode, if so turn off.
Posted on May 05, 2013
  • 579 Answers
SOURCE: stuck tape in vhs/tv combo
Unplug the TVCR, take the cover off, find the motor (probably on the right side of the mechanism) and turn its shaft with your fingers until you have run the tape back out. Now plug it back in and try it again with a scarificial tape. If it continues to fail, replace all the rubber belts in the mechanism.
Hope ya fix it!
Posted on Jan 08, 2008
sharcnet
  • 2130 Answers
SOURCE: Sony VCR
I'm not sure how old your unit is but over time, the rubber parts in a VCR become cracked, glazed and begin to slip.
There is a rubber wheel about the diameter of a nickel that is called the pincher wheel and does exactly what its called.
It pinches or compresses the tape against a shiny metal spindle called a capstan. The capstan spindle is connected to a motor. The pincher wheel rests against the turning capstan with the tape in between the wheel and capstan.
The pincher wheel can become glazed and coated with a brown oxide that has worn off of the tape. This causes the tape to slip and it can spool out into the VCR.
There is another wheel called an idler tire. It lays flat and pivots between the sending reel and pickup reel. Its used during play, fast forward & rewind. This wheel too can become glazed and worn causing slipping. If your unit won't play, fast forward or rewind, most likely the idler tire is the culprit.
There are also belts that can also become glazed and worn. These belts are used along with motors in the tape load/eject mechanism and capstan drive. If the belts slip, the tape may not load or eject properly and the capstan might not be turning properly.
When I owned my repair shop, one solution was we to remove the belts and/or tires and apply a re-grip solution on the rubber with a cotton swab, while roughly rubbing the the entire rubber surface back & forth with the swab. The re-grip solution actually eats away the top surface of the rubber leaving the rubber surface course and causing it to grip better.
Another solution was to just replace all of the rubber tires and belts. These parts including the re-grip solution may be ordered through www.mcmelectronics.com
Please let me know if I may be of further assistance to you.
- Jim
Posted on Feb 26, 2008
VOTIT
  • 2071 Answers
SOURCE: JVC HR S8000U S-VHS VCR switch from stereo to mono during playing.
it is a tape head problem it is already near to run out,replace it with a new one,so it will back to normal..
hope this may help;
Posted on Aug 05, 2008
  • 275 Answers
SOURCE: VCR to TV setup needed
Doreen, it is a simple job. At the back of the VCR you will find two sockets mentioned Video Out and Audio Out. Put the yellow plug in Video Out of VCR and the other end of this cable will have another yellow plug, which you put in the Video IN (PUT) of the TV. Take the White plug of the cable and put it in AUDIO OUT of the VCR and put the other end in RED AUDIO IN(PUT) of the TV, (Older VCRs like yours did not have stereo sound capability, and so there is only ONE Audio OUT from the VCR. )
Now, put a tape in the VCR and hit PLAY. Switch onthe TV and select AV1 or AV2. You should be able to get Picture and sound.
Posted on Nov 28, 2008
  • 103 Answers
SOURCE: I need a user manual for my symphonic vhs vcr
you can get your help here ......
Symphonic SL2860 VHS VCR Aux input
Posted on Apr 07, 2009
VCS422. The VHS will play with a tape, but not from the TV. The display just as four horizontal dashes. Thanks.
I would suggest you replace your AV cables.
After a few years the cables can go bad.
If this doesn't fix the issue, try playing the tape in another VCR.
If that works, it's probably time to replace your VCR with a VCR/DVD combo player.
Mar 13, 2011 | Zenith VCS442 VHS VCR
Symphonic vhs tv turns off i hear the vcr after that it turns off
The vcr sistem is out of time and the microprocessor don´t detect the tape is out,you need to change the motor belt charge,good luck
Mar 16, 2009 | Symphonic SC3813 13 in. TV/VCR Combo
Ac power Symphonic sc309D blows fuse- Dc power ok
The most likely problem is a shorted diode, I suggest replacing them even if they do not test shorted while not under load. If it is not the diode rectifiers, there is probably a resister in the power supply that is shorted, remember also that it can also be both. Lastly, it can be a capacitor within the power supply.
I Wish You Well
Dec 03, 2008 | Symphonic SC309D 9 in. TV/VCR Combo
Symphonics vhs/tv combo
thats usually means the flyback or the horizontal output transistor is shorted. i would replace the flyback thats most likely the cause. If you need me to post a link of where you can get a replacement flyback with instructions how to reoplace it. please let me know
May 23, 2008 | Symphonic SC3813 13 in. TV/VCR Combo
Connecting a DVD plyer
connect to the A/V jacks on the front, go to the TV menu and select front A/V as your video source.
hope this helps
Jan 08, 2008 | Symphonic SC309D 9 in. TV/VCR Combo
Powers off on its own/ will not load VCR tape
i'm having the same problem. please let me know if you've found a solution.
Dec 14, 2007 | Symphonic SC309D 9 in. TV/VCR Combo
VHS problem, any help?
It sounds to me like you have a problem with the reel sensors not detecting movement of the tape through the VCR. This could also be caused by a defective voltage regulator(s) that powers the sensors. This model was made by symphonic/funai (1-800-242-7158), and it is not likely worth repairing.
Dec 30, 2006 | Sylvania SSC719C 19 in. TV/VCR/DVD Combo
Televison & Video Logo
79 people viewed this question
Top Televison & Video Experts
Electro Med Services...
