Hi, I have a GE micriwave/Convetion model PVM1790DR1BB when trying to microwave the timer and the light work but no other sounds. It will not heat a glass of water or spark with a metallic objet in the oven. What could be some potential problems?
SOURCE: GE Spacemaker Microwave JVM165OWB005--No more heat!
If you look at consumer affairs.com, there are many problems like this with GE microwaves. Not a good track record, experiencing problems with mine as well.
SOURCE: Whirlpool Gold Microwave Model GH7155XHS
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
SOURCE: Microwave turns on, but no heat or turntable movement
The problem is that the magnatron is not getting power. Chance is that if could be a bolwn fuse inside the unit. If the fuse don't fix it then that leaves the charging diode, capacitor or the magnatron, or high voltage xformer of which without technical epertize I would not recomend attempting to replace. good luck
SOURCE: everything works except the cooking part/no heating/turntable not turning, help!
you may have gotten a power surge and that can cause some funny things to happen, 1st is there power to the oven, 2nd if so there may be an internal fuse protector built in to the oven, check with the manual for anything of that sort listed. if not you may have to take it in and have it repaired by a pro. there is a lot of voltage in these ovens and unless you know what you are doing a person could get hurt
SOURCE: GE XL 1800 microwave light and fan operate but no heat
With the symptoms you
have, I would most strongly suspect a shorted high voltage rectifier
diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
The diode is a fairly
cheap fix, and your magnetron is still under the part warranty, but you would have to pay labor.
know
decide to look into it, we have critical safety information and
disassembly information at our site, and our link is at our listing here on FixYa.
There
should be a "mini-manual" (tech sheet) hidden inside the unit
behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting, testing, and locating components.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
Here are some links you
or someone you know can use for test help, but read their safety
warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's
probably okay)
http://www.gallawa.com/microtech/mag_test.html
If it's within the magnetron portion of the warranty (5-9 years)
but out of the original full warranty (1 year), G.E. will cover the part cost, but not the cost to visit you or
the labor charge to do the work.
If it's within the mag warranty,
G.E. should send you the magnetron to do it yourself. Call them at
888-239-6832 with your model, serial, and manufacturing date.
If nothing else, you
can save about $50-75 if you remove it from the wall and take it to a
GE-authorized servicer.
You can find a
GE-authorized servicer by calling GE Appliance
Service at 1-800-848-7620 or here.
Accessing some components for testing and possible replacement will require you to remove the oven from the wall.
If
so, the installation instructions are very handy, and it's best to have
two people since the microwave can be heavy and awkward.
You can download GE
owner's manuals and installation instructions here.
We're happy
to help you with free advice and we'd appreciate your thoughtful rating
of our answer.
