Question about Microwave Ovens
GE Jvm1442wa 001 surface light does not work. I haved replaced the bulbs
MicrowaveSvc
  • 9047 Answers
SOURCE: GE Microwave Spacemaker oven, Model JVM240
That would almost certainly be a problem on the control circuit board. If the bulbs happen to short / blow out or if they are removed or installed while the microwave is still plugged in, there is often an arc which causes damage to the board. We repair regularly these boards for such problems for $32.50 nationwide.
Posted on Dec 25, 2006
MicrowaveSvc
  • 9047 Answers
SOURCE: GE Profile Spacemaker microwave surface lights
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 16, 2008
jsrock516
  • 5911 Answers
SOURCE: surface and night light bulbs
If the model number you have this listed under is correct, the bulb you need is part #AP2029997, made by GE. You can also purchase these bulbs at any hardware store. They are the half sized small base, 40 watt bulbs. If you can't find 40 watt, make sure you use a lower wattage rating. If you have questions, or if the model number is incorrect, please let me know. I hope this helps you.
Posted on May 04, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: Need to replace the surface light in GE JVM1490BD 003
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Or you can find helpful exploded view diagrams and order parts by entering your full model number here.
You must not touch halogen types with your bare skin, as the oils will shorten the bulb life.
Posted on Jun 28, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: ge jvm1650sh01 surface light doesnt work/ vent
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly with your brand, full model number and symptoms.
William E. Miller
prototech@usa.net
Posted on May 06, 2010
All three lights on my microwave ge model 1800 do not work. Is there a common fuse or something
suggest you go back to 10 amp globes and check that the fuse is good
Jan 01, 2015 | GE Microwave Ovens
Changed the light bulbs in my ge jvm315 and know the surface light will not turn off ?
This sounds like the control board also called a smart board in some models has to be replaced.
May 02, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Over the range Danby Model dom16a1wdb surface light replacement
a screw at the back side when removed get access to the bulb.Usually 40Watts bulb with1/2 " threaded
Mar 28, 2014 | GE JVM1790SK Convection/Microwave Oven
Replacing surface light
That's on page 33 of the owner's manual. If you've misplaced yours, it's archived online here.
Cooktop Light/
Night Light
Replace the burned-out
bulb with a 40-watt
incandescent bulb
(WB36X10003), available
from your GE supplier.
1 To replace the bulb(s),
first disconnect the power
at the main fuse or circuit
breaker panel or pull the
plug.
2 Remove the screw from
light cover and lower
the cover.
3 Be sure the bulb(s) to be
replaced are cool before
removing. After breaking
the adhesive seal, remove
the bulb by gently turning.
4 Replace the screw.
Connect electrical power
to the oven.
Oven Light
bulb with a 40-watt
incandescent bulb
1 To replace the oven light,
plug.
2 Remove the top grille by
taking out the 2 screws
that hold it in place.
3 Next, remove the screw
located above the door
near the center of the
oven that secures the
light housing.
to the oven.
May 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
One surface light bulb on GE Profile microwave keeps burning out
I have the same problem. The left one burns out within a couple of hours use, the other one lasts a couple of months and is then gone. This pattern has repeated over 8 years. I replace them every now and then and then just go without until I get the urge again to fix it. Maybe smaller lower wattage lamps are worth trying...
Jun 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Surface and night light bulbs
May 04, 2009 | GE JVM1650 1000 Watts Microwave Oven
Surface light "nightlight" will not work
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Sometimes this will also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
Feb 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave Surface Lights
The control circuits for the cooktop lights and the hood fan are spearate. The problem is indeed with the control unit. It's usually caused by either the filaments shorting when the lamp blows or by removing or installing the bulbs while the oven is still plugged into the power line. We regularly repair these nationwide for $32.50. Details of our service, as well as *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Feb 21, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Dec 23, 2006 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
