Question about Intel D975XBX Motherboard
Serial port com com1 - Intel D975XBX Motherboard
  • Intel Master
  • 3,799 Answers
Ask a question, please.
Posted on May 09, 2013
How do I open COM1 in Windows 7 Pro?
Com1 is the Communication Port. A serial Port located on the computer and usually 9 pins.
Feb 18, 2014 | Computers & Internet
Zm400 cannot use com1
Use a null modem serial cable . Match computer com1 serial port settings with printer serial port settings.
Nov 04, 2013 | Zebra ZM400 Direct Thermal-Thermal...
Communication port is not working properly
COM1 and COM2 refer to a computer's communications, or serial, ports. COM1 ports are often used on older PCs to connect network devices, digital cameras and mice. Faulty drivers software that enables the hardware to communicate with the operating system or incorrect hardware configuration can influence COM1 behavior. In rare cases, the expansion card that adds the serial ports to the PC can fail, rendering both COM1 and COM2 ports useless. To repair a COM1 port, you must determine what is preventing the port from working before attempting a solution.
Click "Start." Go to "Control Panel" and then click "Hardware & Sound." Select "Device Manager" from the submenu. Expand "Ports (COM & LPT)." Double-click "COM1." Review Device Status on the General tab to check for problems with the software driver. If the message "The Device Is Working Properly" appears, click "OK" to close the window; otherwise, look up the error message on Microsoft Support. Follow the directions in the Knowledge Base to correct the issue. Press "Alt" and "V" to open View. Scroll to "Resources by Type." Press "Enter." Double-click "Interrupt Request (IRQ)" to see a list of devices. Double-click "Communications Port (COM1)." Check the term to the left of COM1 to see if the card uses an ISA or PCI interface. If the card uses a PCI interface, it can use the same IRQ as another PCI device without producing a hardware conflict. If the device is ISA, it needs its own IRQ. Go to the "Resources" tab. If "No Conflicts" appears in the Conflicting Device List, close the window; otherwise, uncheck "Use Automatic Settings." Click the drop-down menu and select each configuration until the port no longer interferes with another device. If conflicts occur with each configuration, double-click "IRQ"; you may need to try different configurations before Windows gives you permission to edit the interrupt request. Click the up or down arrow to change the IRQ until the message "No Devices Are Conflicting" appears in the Conflict Information field. Click "OK" to close each window. Click "Yes" when prompted. Connect a device to the COM1 port to test the port. If the device doesn't respond, shut down the computer and then unplug the power cable. Disconnect all devices from the back of the PC. Remove the case cover and touch the computer's chassis. Set the computer on its side so that the PCI and ISA cards sit at a 90-degree angle to the floor. Find the serial ports on the back of the PC. Look on the opposite side of the case to find the associated card. Shine a flashlight onto the card and make sure that the copper contacts are not visible. If you can see the contacts, reseat the card in its slot so that it's fully installed to the motherboard. Reassemble the case and boot into Windows to test the COM1 port. If the port still fails to work, you may need to replace the serial port card.
Jan 16, 2013 | Computers & Internet
Which port should I use for my printer: com 4 serial port com 6 serial port com 8 serial port usb virtual printer port
depends how your printer connect
if you realy are connecting an old serial printer com1 or com2 should be fine as long as you do not have a mouse or a modem on them ...
if USB any port is fine
if parralel printer you are only likely to have one...
Mar 18, 2011 | Computers & Internet
I have the same printer, and xp on my pc, but how do i connect them? my laptop does not have a serial conection. i tried to use a usb/serial converter and i installed the xp driver from minolta website,...
You need to make sure you have selected the correct COM port whin you try to print. Depending on the type of USB to serial converter, the COM port it assigns can change just by moving it to another USB port. Right-click on My Computer and select MANAGE. Select Device Manager from the list. Click on the (+) next to PORTS and double-click on your USB-SERIAL device COM port. Somewhere in the Properties window you should be able to see the assigned COM port (COM1, COM2, etc.). If possible, set the COM port to COM1 or COM2 for greatest compatibility with older software. Then when you print, make sure your printer driver is also set to the same COM port.
Mar 05, 2011 | Office Equipment & Supplies
Usb/serial adapter not working
check the com port of the appliaction, it is based on com1 only then you will need to make changes to the com4 to com1 follow these steps
open device manager
choose com4 and then right click for properties
choose port settings
choose advance
change the port number from 4 to 1
that will be all you can now give it a shot again
Jan 01, 2010 | Bernina Artista 180
Problem with serial connection with AMD motherboard
Software that accesses serial ports usually allow you to specify WHICH port you want to connect via.
Your new board should have COM1 and possibly COM2... but perhaps your old setup was running from COM3?
Connect the Casio to COM1, and check the software you are using... set that to "look" at COM1 also. That should work!
Apr 20, 2009 | Casio Serial RS-232 Cable (CELL-300)
Com 1 port
Yes. com1 Should be labled Serial Port on the PC.
Feb 09, 2009 | E-Machines etower 500is PC Desktop
USB port
Hi-
Make sure you are using a direct cable, not an adapter( usb to serial or vice versa) if you are using a serial cable, make sure your printer is the only one using the com1 port, this should be free...
check and go to command prompt- click on start then on RUN put in cmd then press enter, on black window type dir >com1 then press enter. it should print if its free. other wise go to device manager, delete com1 or uninstall then reboot computer so that it will reinstall the com1 driver back to computer.
keep me posted
Aug 17, 2008 | Toshiba e-Studio163 Copier
How do I get com1-3-5 back on my computer after a complete re-load of w98se
dear friend
if yr card is working condication then u have to han ge slote of yr card. and if u want to chand com poer serise number then got to device manager then go to serila port which u want to change then select port properitis then got port setting then advance u seen a TAD CALL SERIAL NUMBER then selicket which number u want u have to select all serial number.
thanks to using fixya.
jo_chinmay
Apr 02, 2008 | Intel Motherboard
Intel D975XBX Motherboard Logo
21 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
