Question about Hayward SAND FILTER, PRO SERIES
I have a Dream Line sand pump and label on top fell off. Can not tell where to set valve for backwash, rinse,waste or recirculate are? thank you for your time and help.
It is model number S170TSCPE.
    New Friend:
  • 77 Answers
Filter position is with notch on handle seated and pointing to the pressure gauge.
Working clockwise - Waste; closed; backwash; recirculate; rinse;
Posted on May 11, 2013
4 Suggested Answers
  • 3 Answers
SOURCE: multi-valves on hayward sand filter mixed up
Key Cover Assy needs new spider gasket. If it is a newer model the gasket is made into the key cover and it will have to be replaced
Posted on May 02, 2009
SOURCE: sand in my waste water
O-rings or gasket are replaced to stop leaks, so that wouldn't have helped you.
It could be one of two things; either the white PCV-like pipe in the filter tank is cracked OR some of the laterals at the very bottom of the tank, under the sand, has melted. A whole new underdrain assembly is usually $70.
Posted on Sep 05, 2009
  • 14548 Answers
SOURCE: My sand filter has great flow for awhile, and then
one of the internal pipes broke or rotted away put in bypass mode and unbolt top slide out unit head repair or replace damage pipe
Posted on May 06, 2010
Label positions for pantera P21 sand filter
12:00 Filter.
1:00 Rinse.
3:15 Recirculate.
4:30 Backwash
7:00 Closed
10:30 Waste
Nov 29, 2014 | Pool & Spa
Vista pro 711 blows water out waist on filter setting what am i doing wrong
Hi. Have you disassembled the multiport valve recently? If so, then the diverter and or handle was improperly aligned.
If all other functions work as they should (waste, backwash, recirculate,rinse or closed then there is an issue with a worn diverter (or spider gasket) or the diverter valve stem is hanging up slightly. valve top would need to be disassembled and lubed.
hope this helps.
Jun 18, 2014 | Hayward SAND FILTER, PRO SERIES
I cannot read the diagram on top of my hayward sand tank filter pro-series s244t filter,close,waste which way
go to westport pools.com and see if you can find a picture of it or go to hayward filters..
Jan 06, 2014 | Hayward SAND FILTER, PRO SERIES
Hayward sand filter
Reference your pressure gauge as the 12:00 position. Going clockwise-
12:00 is Filter, normal running position
2:00 is Waste, water goes from pool and exits the waste line, bypassing filter.
4:00 is Closed, used only when servicing equipment
6:00 is Backwash, reverses water through the filter and goes out the waste line.
8:00 is Recirculate, water bypasses filter and returns to pool.
10:00 is Rinse, water goes through filter and exits to waste line, used briefly after backwashing to clear sediment from filter.
Note that the "pointer," not the handle that you grab, indicates which setting you are on.
May 19, 2013 | Pool & Spa
How to use backwash to waste
When the filter get clogged the pressure in the filter increases and there is less water flow returning to the pool.
If your filter is a sand filter, when you turn the valve to backwash and turn on the pump it reverses the water flow in the sand filter to flush the dirt out of the filter to waste. Look at the window openning in the waste pipe and keep the backwashing goinging until you see clear water.
Then turn off the pump and move the control valve to Rinse, turn on the pump for a few minutes, this returns the water flow back to normal but the water goes to waste to make sure the sand filter is clean.
Turn off the pump and move the control valve to filter and turn on the pump. This mode is the normal operating mode and the pressure gauge in the sand filter will show a drop in pressure.
Some pressure gauge shows a red section to indicate when backwashing should be carried out.
May 02, 2012 | Hayward Pool & Spa
I need to know what all the settings are like bacwash filter on the valve system
FILTER is the valve position when the system is in the normal filtering mode.
When you backwash the filter you first need to turn off the pump, place in BACKWASH position, and run the motor for 45 seconds (or until the backwash water is clear). Turn off pump and run in the FILTER position for 15 seconds. Repeat twice more.
The RINSE position is to clear any dirt in initial start-up cleaning, plus resetting filter bed after backwashing.
The WASTE
position is for vacuuming directly to waste, lowering pool level, or draining the pool.
The CLOSED position is for shutting off all flow through the valve.
The RECIRCULATE position allows water to flow from the pump through the valve and directly to the pool.
You will probably only to use the FILTER, BACKWASH and maybe the RINSE valve position. The RINSE position is not as important as indicated by the fact that many backwash valves don't have a RINSE position.
I hope this helps.
Sep 05, 2011 | Hayward SAND FILTER, PRO SERIES
Sticker wore off on the filter. which button backwashes? the pool is about to overflow.
b> VALVE SETTING FUNCTIONS OF VALVE POSITIONS FLOW DIRECTION THROUGH VALVE FILTER PUMP - TOP - THROUGH FILTER - BOTTOM - RETURN For normal filtration and vacuuming pool through filter. BACKWASH b> PUMP - BOTTOM - THROUGH FILTER - TOP - WASTE For reversing flow for cleaning filter. RINSE b> PUMP - TOP - THROUGH FILTER - BOTTOM - WASTE For initial start-up cleaning, plus resetting filter bed after backwashing. WASTE b> PUMP - WASTE For vacuuming directly to waste, lowering pool level/draining pool. CLOSED b> NO CIRCULATION PAST PUMP PORT For shutting off all flow to filter and pool. RECIRCULATE b> PUMP - RETURN For bypassing filter, but circulating pool water. May be plumbed for "off-system" pool water access. Ideal for Jet-Air® fittings. WINTER b> VALVE NOT IN USE
Ifthis answer does not fix your problem, please comment with additional detailsprior to rating the answer. Positive feedback is appreciated once your problemis solved! Thank you.
Aug 28, 2011 | Hayward SAND FILTER, PRO SERIES
I was backwashing the pool and put it back to filter and it will not ****. Thanks Rob
After your pool filters on the "backwash" setting, you should move it to the "rinse" setting. With the pump off, set valve to rinse. Start pump and operate for about 1/2 to 1 minute. This ensures that all dirty water from backwashing is rinsed out of the filter to waste, preventing possible return to the pool. Stop pump, set valve to "filter", and start pump for normal filtering. If it still won't start, check for restrictions in the intake and discharge lines.
Oct 06, 2010 | Hayward SAND FILTER, PRO SERIES
Pentair filter
I am sure that you already have an answer to this, but IF you can not read the valve label sticker, call the Pentair Customer Support 1-800 number. They will send you out a new label, free of charge.
For referrence, the waste position is ALWAYS over the waste port on the valve.
Jun 14, 2009 | Pentair Meteor Above-ground 22" Sand...
Multi-valves on hayward sand filter mixed up
Apr 27, 2009 | Hayward Pro Series 18" Above Ground Pool...
Hayward SAND FILTER, PRO SERIES Logo
345 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
