Question about Hoover Nextra HNL 3166 Z Front Load Washer
Not clearing the powder or conditioner drawers
Neither the powder or the conditioner drawer is having the water fill cycle through them. Water is only being directed to the third compartment in the drawer. I have cleaned everything and reinstalled but still the same. Is it a problem with the water feed solenoid s or a programming board?
5 Suggested Answers
SOURCE: water not getting to powder dept
SMALL SPRING HAD COME LEVER THAT IS CONNECTED TO WATER RELEASE VALVE , RECONNECTED SPRING AND EVERYTHING SEEMS TO BE WORKING OK .
Posted on Oct 09, 2008
woodchuck789
  • 4070 Answers
SOURCE: fabric conditioner still in compartment after wash
Most washers recommend dilluting the softener with water when you put it in the compartment. It can build up and completely block it. I've had to manually remove it with anything I could find to reach it and since I've started dilluting it have had not problem.
Posted on Aug 27, 2009
Testimonial: "Advice worked a treat. "
pugh_a
  • 7 Answers
SOURCE: water filling the drawer but not going into the
Yes there is a blockage in the drawer.Try removing the lid after unplugging the power,and you may be able to reach down the front and squeeze the dispenser hose a few times may break up the soap.
Adrian
Posted on Sep 05, 2009
beltronic205
  • 1474 Answers
SOURCE: the conditioner compartment is always full of
It should clip off , hold down mid lever and pull out you should be able to see the lever...
Posted on Apr 08, 2010
Washing powder compartment fills up with water
It's probably just caked with powder or conditioner and needs cleaned. Your handbook gives instructions on how to remove the drawer. Alternatively the dispenser to drum inlet hose may be blocked and some hot water may clear that.
Jul 13, 2014 | Hotpoint Aquarius WMA42 Front Load Washer
I have taken apart the dispenser drawer and all its hoses and housing to clean any residue but the machine will not dispense the fabirc softener. Washing powder is fine not problem but fabric softener...
I hope you do not mind me saying this but, although you have cleaned the softener drawer, the siphoning tube is often overlooked because it is difficult to access.
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
If all is clear it could be that the water dispensing is not filling the softener tray itself. It is possible to check by selecting (final?) rinse and pulling the drawer out very slightly until you can see and hear the water running in. If it isn't it's a call-out ;-0(
Good luck,
John C
Mar 20, 2011 | Washing Machines
I have a LG front loader Washer, and after a complete wash cycle, the detergent cup is filled with clear water.
This is a common problem with many machines and I suspect that the detergent drawer needs a thorough clean!
Remove the complete drawer. To do this you will have to do one of the following-
  • push down the lip/catch at the middle rear and pull the drawer out (that's how our Bosch one is removed)
  • release the catch underneath or
  • lift upwards on the tray as it is coming out to clear the lip underneath.
One of these should enable you remove it
(I am having to guess some of the following!)
Once out identify which tray is for the conditioner- the others are simply 'chutes' and open-ended.
It will normally have some sort of cover on it which you must remove to expose the little stuck up pipe/tube. This is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
I hope this is your problem and solution!
Good luck,
John C
Feb 20, 2011 | LG Washing Machines
Water pours out through the powder drawer when machine is started
Although you do not say which model it is, this is a common problem with many machines. If the powder channel is clean and clear I suspect that it is the conditioner/softener tray which is causing water to overflow from the drawer so it needs a thorough clean- but clean them all!
Following is my 'generic/standard' document,copied and pasted ;-0)
Good luck,
John C
Feb 14, 2011 | Hotpoint Washing Machines
Fabric softener drawer filling with water
lift out the blue part of the conditioner compartment and you'll see attached a tube at the end.
clean this out completely.
also check the tube in the compartment is clear.
poke a cotton bud down it to clear it.
if you want to check to see if its worked take the drawer out(blue button at back of drawer) put the blue grid back in the dispenser and fill the compartment up under the tap ,hold the drawer level.
as it gets full you should see water start to flow out the back ,turn the tap off and if its worked the compartment will slowly empty.
these were a big problem for hotpoint and concentrated conditioners will block it regularly.
Jan 17, 2010 | Samsung Washing Machines
My Washing Machine is emptying the Fabric conditioner too early
Washing Machine has started to empty the Fabric Conditioner high water or blokage in draw
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 05, 2009 | Washing Machines
Detergent drawer filled with water
remove the drawer and clean the siphon it sounds as if it is blocked up either with powder or concentrated fabric softener. this should fill up with water and then empty itself due to gravity. the siphon should look like an upside down cup on a cylinder.
Jul 23, 2009 | Kenmore Elite 45986 Front Load Washer
Fabric conditioner not taken or not dispensed.
take out the drawer that the powder and conditioner goes in. the conditioner spout to allow the liquid to empty from the drawer will be blocked with a mixture of powder and conditioner. clear it thru with a sharp screwdriver or similar and wash under the tap. replace back in place should empty fine then. hope this helps.
Apr 12, 2009 | Washing Machines
WD 63
Remove dispenser drawer from m/c, and thoroughly clean it and all accessories.Clean all residual build up of undesolved powder and conditioner in drawer compartment..
If it still leaks, then remove top cover, locate large black hose at bottom of dispenser, and give it a good squeeze to clear any possible blockage in the hose itself..
If still no better, could be due to exceptionally high water preesure forcing the water out of the drawer.
Turn cold water valve down a little to reduce pressure.
Plz rate my solution.
Thanks.
Jan 09, 2009 | Hotpoint Aquarius WD63 Front Load...
Washing machine wont fill with water-hoover performance 1100
check that the water inlet pipe is not blocked. it does have a filtewhich can get blocked with lime scale.
Dec 27, 2008 | Washing Machines
Hoover Nextra HNL 3166 Z Front Load Washer Logo
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
