Question about Car Audio & Video
Turn off automatic headlights
When I turn my headlights off during the day, my subs dont work. Theres no power going to it when I turn the headlights off. I have no clue why it would do that. Any suggestions??
  • Car Audio & ... Master
  • 17,093 Answers
Whoever wired it, connected it to the headlight circuit.
Posted on May 06, 2013
My 2001 s10 drivers side low beam headlight seems to work on automatic during the day , but not work at night on auto or switch on ?
The daytime lights run off the highbeam circuit on reduced voltage. If the lowbeam is not operational, take a look at the plug at the headlight and inspect for looseness. If tight, inspect for a constant ground and a 12v power supply with the headlights turned on low beam at the headlight connector. repair a necessary
Jul 18, 2015 | Cars & Trucks
1998 Lumina lights don't work at night!The lights work during the day but not at night. Does anyone know how to fix it?
Theres a sensor in the middle of the dash by the front windshield that detects sunlight and triggers the automatic headlights. The main headlights and daytime running lights might be on a different circuit, in which case they daytime running lamps would turn off at night and the main headlights would turn on, indicating the main headlights arent working and the daytime running lamps are working as intended.
I would check all the fuses related to headlights, check the bulbs and check the switch, then last the light sensor on the dash.
Jan 08, 2014 | 1998 Chevrolet Lumina
My 2000 Toyota Corolla headlights will not turn on during the night, and stay on during the day
Your Corolla has daytime running lights (DRLs). A photocell determines whether it is day or night. Your DRLs turn on automatically in daytime without you operating the light control ("headlight") switch. Your DRLs are actually your headlights on low beam. At night, the photocell senses it is dark and disables the DRLs. When you set the light control ("headlight") switch to HEAD, the head relay closes and the headlights should turn on. Since they don't, I suggest opening the engine room junction block and checking the 40A MAIN fuse and the 10A LEFT HEAD (UPPER) and RIGHT HEAD (UPPER) fuses. In engine room relay block 5, check the 10A LH-LWR HEAD and RH-LWR HEAD fuses. Replace any blown fuses and the headlights should be working normally again
Sep 29, 2012 | 2000 Toyota Corolla
Headlight sensor
I have seen the sensor fall out of the dash housing. When you put it back it should be good again.
Jun 10, 2017 | 2006 Buick Terraza
Headlights only work when car is in gear
If you are stating the headlights only work while in gear (during the day or night) then they are your daytime running lights. Don;t know if you vehicle has automatic headlights or a manual switch. If you are stating you turn the headlights on and they only illuminate while in gear then there are other issues. Let me know
Aug 16, 2010 | 2006 Pontiac Torrent
Headlights wont turn off
the first thing to check is the headlight switch, they will go bad and keep lights on,also i dont know how long youve own this truck but theres and auto setting on switch and the lights come on even with the swith off at dusk,and also there are driving lights that are on all the time,if you turn key off and they stay on for more than 2 mins, then check the switch,if you mean there on every time you start it ,even during the day, then the sensor on the dash may be bad or you may have something cover it and it thinks its dark out and turning on the lights.
Jun 01, 2010 | 1999 GMC Denali
Turn signal doesn't work when headlights on
It sound like you have a grounding problem, does the headlight on the left seem dimmer than the right? Check the ground wires and the light sockets for corrosion.
Mar 27, 2010 | 2003 Chevrolet Venture Passanger
Hi, i have jbl 1201.1 running 2 audiobahn aw1200v subs, i used to have 2 jl audios but the amp blew them, when i turn up to about 32 volume the subs cut out, they come on and off, amp doesnt go into...
well first off the cap should be reading 14.00 volts not 12 but check on ur settings maybe its to high if that dont work then ur amp or amps is way to powerfull for those sub or theres not enough watts from the amp to the sub causeing the amps to under power the subs but let me no if u got it im all wayz here to help
Apr 04, 2008 | Car Audio & Video
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
