Question about Canon DC330 DVD Camcorder
Yellow question marks on recorded frames - Canon DC330 DVD Camcorder
Recorded scenes show as question marks
They are recorded as something that the computer does not know what to do with. You should have a cd with that camera that can convert the files. It could also be that there is a problem with the recording.
Nov 18, 2013 | Canon LEGRIA HF R16 Camcorder
I upload video in the avi mode in the memory of my photo frame. When trying to play it the frame shows the icon with the name of the video name.avi (that is the video is in the memory) but on the icon is...
digital photo frames are not usually able to play videos...
however if the frame has this capacity, it sounds like you have an encoding issue, you should check which codecs (encoding decoding) are compatible with your "frame" and change the configuration of your video encoding/recording system to use a compatible codec
Jun 19, 2010 | PANDIGITAL (DPF802) Digital Picture Frame
I have a webcam like this and i would like to know how to record from the webcam to my computer?
Plug in webcam
Launch the logitech toolbar from your desktop icon
Click on the Quick Capture menu ( 2 film frames )
Check the picture and click 'Record Video'
Dec 17, 2009 | Logitech QuickCam Messenger Web Camera
Recorded video segment plays back in fast motion. How do i reset
This is a really simple problem and easy to solve.  Unfortunately the videos you've recorded cannot be changed back because they have been recorded in Time Lapse mode.
With the camera switched on in Video Mode turn the control dial on the back (this is the dial to the right of the LCD screen).  This will change the settings from TIME LAPSE to STANDARD.  There are actually 6 different modes but the best one for normal videos is STANDARD.  There is a HIGH RESOLUTION setting,  however these record fewer frames per second (fps) so whilst the quality is better per frame,  there are half the amount of fps so the the movie will look at bit jerky.
It's really easy to accidentally twist the dial when holding the camera,  so always check the icon in the top right of the LCD before recording to make sure its just a yellow camera in a yellow square.
This should be problem solved for all future recordings.
Jan 23, 2009 | Canon PowerShot G9 Digital Camera
Video playing in fast forward with no sound
This should be problem solved for all future recording.
Jan 05, 2009 | Canon PowerShot G9 Digital Camera
My powershot g9 is showing video in fastforward with no sound... how do I fix this?
This should be problem solved for future recordings.
Canon powershot 9
This should be problem solved for future recording.
Sep 20, 2008 | Canon PowerShot G9 Digital Camera
No sound from my e3021 pc
Then go to control panel,system ,hardware ,device manager option
There if u find any question mark or exclamation mark in yellow Color that means sound drivers are not installed properly
please reinstall sound drivers properly
or else
If no question mark or exclamation mark then check the cable connections of the speaker to the machine
or else
In control panel , select sound audio devices open it there u have
volume,sounds,audio,voice,hardware options
1)See whether it is mute
2)In audio option select default audio device and recording device
should be same
this should solve u r problem .if it is not solved please let me know u r problem briefly
or else put the model number and brand name followed by drivers search in ww.google.com
Aug 25, 2008 | Computers & Internet
CD Rom Problem
exclamation mark means no driver install driver or go to bios check devices cd roms
Feb 05, 2008 | Lite On LVW-5115GHC+ DVD Recorder
Canon SD 700 IS Movie Sound Issue
This is because of low light and low frame rates in the camera. It records the sound on time but the picture delays. In the camera's video menu, choose a higher frame rate to help this a little. Honestly though, If you want to shoot better video get a video camera.
Sep 14, 2007 | Canon PowerShot SD500 / IXUS 700 Digital...
Canon DC330 DVD Camcorder Logo
Top Canon Video Cameras Experts
Chance Miller
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
