Question about Pioneer Audio Players & Recorders
Pioneer vsx-522 no power
No power. When I press and hold the power and advanced surround buttons it comes on, but then shuts down again 3 sec later.
5 Suggested Answers
SOURCE: Connecting a sub-woofer to Pioneer VSX-453 surround reciever
I got the same issue. But, I go ahead hooked it up two banana plugs on teh VCR outlet. It works fine on my Cerwin Vega Sub.
Posted on Apr 19, 2009
dragster301
  • 12 Answers
SOURCE: Pioneer VSX-918V-K Standby Light Flashes but will not turn on.
unplug it and press the power buton and then hold the power button, and while your holding the power button, plug it back in
hope it worked!!!
Posted on Jul 31, 2009
  • 4 Answers
SOURCE: Pioneer VSX-816
With the receiver off, press ENTER + ADVANCED SURROUND keys continuously for 2 sec. and it will tell you the fault it encountered. Even if it has a short, it will still protect the speakers; however, it is still a good idea to disconnect all speakers before doing this.
Posted on Aug 12, 2009
SOURCE: Pioneer VSX-1019 with a flashing red MCACC
you can "release" the error by pressing the "down arrow" and the "zone 2 on/off" for 2 seconds.
Posted on May 23, 2010
Won't turn on
try holding the 'advanced surround' and power buttons. It should turn on. If it turns right back off, then you have a problem in the amp that needs repair
Aug 08, 2014 | Pioneer Vsx-522-k A/V Receiver
HDMI light is flashing
The unit is in protect mode. Try pressing and holding the 'advanced surround' and power buttons. It should power up. If it shuts down again right away, there is a problem with the amp that needs to be repaired.
Mar 25, 2014 | Pioneer VSX-823-K
While watching TV (all audio ran through my Pioneer VSX-516), the receiver shut off by itself, so I powered it back on. Then it powered off again a couple mins later, and wont power up at all now. I...
Try holding the "advanced surround" and "enter" buttons and see if it turns back on. If it shuts off again, disconnect all speaker wires and try it again. If it stays on, you have a bad speaker or wire. If it still shuts down, the amp is blown and needs to be repaired.
Mar 29, 2013 | Pioneer VSX-516-K
Error code 5200 - What does it mean and how can I fix it?
It means that yo have a problem in your cartridge here are some steps how to reset your printer cartridge.
  • Power off the printer
  • Hold the stop/reset button then press and hold power (for 5 secs)
  • Hold Power and release the stop/reset button
  • Press the stop/reset button twice
  • Release power button
  • Wait until the power button lights a steady/still green, press the stop/reset button three times with a 3 sec space between each press.
  • On the 3rd press the inicator should be orange.
  • Press the power button to set data
  • To set data remove cartridges then replace.leave for 20 or 30 secs
  • Press the power button again to shut down
  • Then press power button to power up.
  • The printer will feed one piece of paper through then set language and counrty.
Then ink should be reset
Good Luck..
Jul 29, 2011 | Canon PIXMA MP180 All-In-One InkJet...
My pioneer vsx 815 amplifier has a flashing blue standby light. Have tried resetting by pressing enter and advanced surround keys. All it does is flash a few other LEDs and then goes back to the flashing...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Pioneer-VSX-815-K-Receivers-manual/id/385dj989/t/2/
"enter and advanced surround keys"? I don't see that documented as a special function in the manual.
BTW: other than the Flashing light, is there a malfunction?
Page 72 describes how it REALLY resets...
Resetting the main unit
Use this procedure to reset all the receiver's settings to the factory default. Use the front
panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the TONE button, press and hold the STANDBY/ON button for about three seconds.
3 When you see RESET? appear in the display, press ENTER .
OK? shows in the display.
4 Press SYSTEM SETUP to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default
settings.
Mar 04, 2011 | Pioneer VSX-815-K Receiver
My vsx-819h shut down and wont turn back on
hold "Advanced Surround" button, press "Standby" button for 3 seconds, unit will power back.
Jan 17, 2011 | Pioneer VSX-819H-K A/V Receiver
After replacing the ink cartridge printer still shows cartridge levels at 0%
Hi
You have to reset the cartridge
To Reset the HP Cartridges Works 100%
On the 3rd press the indicator should be orange.
Thanks
Aug 15, 2010 | HP Office Equipment & Supplies
Replaced ink cartridges but monitor still displays "ink low".
Hi, this fix worked for me (i've been wasting few hours on mp150 the first time, so if it soesn't work at the first attempt, don't give up and try at least few more times)
  1. Power off the printer
  2. Hold the stop/reset button then press and hold power (for 5 secs)
  3. Hold Power and release the stop/reset button
  4. Press the stop/reset button twice
  5. Relase power button
  6. Wait until the power button lights a steady/still green, press the stop/reset button three times with a 3 sec space between each press.
  7. On the 3rd press the inicator should be orange.
  8. Press the power button to set data
  9. To set data remove cartridges then replace
  10. leave for 20 or 30 secs
  11. Press the power button again to shut down
  12. Then press power button to power up.
  13. The printer will feed one piece of paper through then set language and counrty.
Then ink should be reset.
Good luck, Peter
Aug 08, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Twice now my Pioneer VSX-819H has shut down. Can not get any power to it. The first time I'm sure the phono pre-amp caused a surge. I no longer have it hooked up. The servicer said nothing was wrong and...
I found this for the VSX918, 818. Perhaps it's similar.
The power does not turn on. • Disconnect the power plug from the outlet, and insert again.
• Make sure there are no loose strands of speaker wire touching the rear panel. This could cause the receiver to shut off automatically.
The receiver suddenly switches off and the power indicator
blinks.
• After about a minute (you won’t be able to switch the unit on during this time), switch the receiver back on. If the message persists, call a Pioneer authorized independent service company.
Use this procedure to reset all the receiver’s settings to the factory default. Use the front panel controls to do this.
2 While holding down the ADVANCED SURROUND button, press and hold the
seconds.
3 When you see RESET? appear in the display, press ‘
ST –’. OK?
4 Press SOUND RETRIEVER to confirm.
OK
appears in the display to indicate that the receiver has been reset to the factory settings.
Mar 02, 2010 | Pioneer VSX-819H-K A/V Receiver
How do I reset printer after putting ink cartridge in
To Reset the Canon Cartridges Works 100%
Relase power button
Please rate my rsponse!!
Jan 29, 2010 | Canon PIXMA MX310 All-In-One Printer
1,586 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
