Question about Gilmour Bp4 4.5 Gallon Back Pack Sprayer
Manual Changing pump angle
4.2 diesel patrol motor rebuilt 60000 km ago new injector pump after market turbo 3 inch exhaust has flat spot before changing gear blows black smoke changing fuel air filters makes no difference
turbo problem-check actuator to change blade angle in the exhaust side to the turbo that assists with directing exhaust gas flow onto the turbine wheel
could be problem vacuum vose or control module
Apr 15, 2017 | Cars & Trucks
Steering
No
The whine is the steering pump
The cause is most likely a failing steering
rack & the added pressure shows up in pump noise
I would flush the power steering fluid first
Use the factory recommended fluid
The use about 8 oz of LUBEGARD for power steering
It is a US product, out of Washington State
The company has a web site
International Lubricants or just type Lubegard
for transmissions
Get the regular additive,they make a purple bottle
just for hondas also
Some dealers have a similar product or it could very well
be lubegard in their bottles
Mar 30, 2014 | 2007 SsangYong Musso 290S
Changing computer
I recommend you take your vehicle to a holden dealership and get them to put tech2 on it and check for diagnostic trouble codes.
Possible cause could be a crank angle sensor.
Fuel pump
computer problem
May 04, 2013 | 1999 Holden VT
Horizontal Angle reading on 56-CST205 tOTAL sTATION NOT CHANGING
if your horizontal angle reading is not changing, then either you have the horizontal hold on, where you can rotate the station and the angle readings remain the same, or You have a problem with the horizontal encoder or main circuit board, probably the main circuit board. If it's a hold button then just press it and things should go back to normal. If not then you'll have to bring it to a service shop. You might be able to get CST to sell you s new board, though most likely not since they were bought by Bosch, but the encoders need realigning. That requires an o-scopes to bring the encoder reading in line.
Mar 19, 2013 | Cars & Trucks
Tw200 throttle bogs the engine when upright, but, on the kick stand i can hit the throttle as much as i want, kicks in smooth
Hi, seems to has trouble with changing angle. Open the float chamberand check if the float and the needle is swinging smoothly. Page 5-6 in service manual
May 28, 2012 | 2001 Yamaha TW 200
Refueling problem
Try changing the angle of the pump fuel nozzle or don't push it in quite as far. It has to vent out air in order to let fuel in. Also could try pumping a little slower.
Apr 03, 2012 | 2000 Ford Mustang
F05 water will not go Indesit washing machine
F05 - Pressure switch jammed on full - Book a washing machine repair.
Was what the manual said. But then I found this write up from another source:
Drain machine by running the outlet pipe into a bucket at floor level or run the outlet pipe out of the back door if it'll reach. Check the filter unit for blockages. Filter generally located behind a panel at the foot of the machine.Some are obvious like little square hatches and some are hidden behind the trim panel at the foot of the machine. Once panel is removed the filter should be visible. Its generally a circular plastic fitting which unscrews in an anticlockwise direction. Some hotpoint, indesit and ariston filters are located in the big black sump hose (the one that leaves the bottom of the outer drum and connects to the pump). Remove the back cover, locate hose, remove the tensioner clip by squeezing the tabs together with a set of heavy pliers or vise grips, remove the hose, take out filter and clean. Be prepared for spillage of water. May help if the machine is tilted backwards at an angle.
If problem persists, check pump and pump hose. Pump removal: power off, drag machine out onto the floor, remove back cover or tip machine up at an angle, locate pump, (attached to other end of drain pipe).undo 2 wiring connections, 2 hose connections, and pump mounting screws. Remove pump chamber - some are held in with screws, others clip into place. Check for foreign objects round the impeller. If pump chamber is clear, may be a fault with the pump motor - in which case, replace the pump.
Repair and service your own washing machine. Go to www.2ndwave.co.uk/manual.html
Jun 06, 2011 | Washing Machines
Worn gears
I would just buy a new one.
parts could cost almost as much.
don't forget the rest of the grinder is just as worn out too
Jun 24, 2010 | Bosch 1375A 412Inch Angle Grinder
When changing the fuel pump on a 1999 kia sephia, do i need to drop the tank, or can it be done from under the back seat?
If there is a access panel under the seat ,then u replace the pump through that, when u remove the pump and replace it with the new one BE CAREFUL NOT TO BEND THE GAUGE FLOAT ROD if u do your fuel gauge will be wrong. you have to lift and then turn at a angle and reverse to put the new pump in.
Apr 11, 2010 | 1999 Kia Sephia
Citroen zx relfex 1.9d
try changing the glow plug relay box located to the side of the battery ... easy fix if not then maybe a solenoid
Mar 31, 2009 | Peugeot 505 Cars & Trucks
Gilmour Bp4 4.5 Gallon Back Pack Sprayer Logo
47 people viewed this question
Top Gilmour Garden Experts
Mike
Andrew Taylor
Andrew Taylor
Are you a Gilmour Garden Expert? Answer questions, earn points and help others
