Question about Garden
Chainsaw Will Not Start
Will not started
  • Garden Master
  • 14,363 Answers
First,replace plug,clean filter,use new gas and mixture. push primer 4 times ,put on choke,pull till it sounds like it wants to crank then remove from choke and pull cord,make sure throttle is locked.
Posted on May 06, 2013
Instruction on how to start a stihl chainsaw model 014 AV
this is a picture of a 014
looks basic..older model .. no safety features
starting all depends on
carby idle hi /low set correctly
air filter clean
clean fuel....fuel /oil mix
good spark
new spark plug if required
chain oil in oilier section
correct chain tension on the cutting bar
being a two stroke
and the engine has good compression
crank casing seals are in good condition
never have your body in line with the chain
it could run off the bar at startup ..flick .onto your arm or face
choke on
trigger lock on
hold the handle and pull cord handle ..firmly
let the weight of the chainsaw start itself
let the chainsaw go downwards till motor splutters
choke off
trigger lock on
drop the chainsaw downwards a few more times
and it should start
other way is put foot in the foot plate of the handle
and start sequence is the same
if not something is out of adjustment or needs servicing
Oct 14, 2016 | Stihl Garden
Cant get enought gas
repair - What should I check if my chainsaw fails to start ...
diy.stackexchange.com/.../what-should-i-check-if-my-chainsaw-fails-to-s...
Feb 26, 2013 - Does anybody have any idea what I can do to get my chainsaw started?... Clean carburetor and fuel lines, especially if it may contain old fuel. ... that prevents it from generating enough current to sustain repeated firing of the spark plug as the engine turns. ... Your muffler is pluged up your saw can't exhaust.
Stihl Chainsaw - starts but won't run - GardenWeb
forums2.gardenweb.com > Garden Forums > Tool Shed
Aug 9, 2006 - Re-chocking (once until it kicks) gets it running again for another 20-30 seconds ... carb body was not letting enough gas through to contunue running the saw at full speed ..... MY STIHL 029 CHAIN SAW BLOWS GAS BACK OUT OF THE .....Can't imagine why shaking the saw around would keep it running. Chain saw won't start
Feb 8, 2012
homelite xl chainsaw
Sep 4, 2009
Husqvarna chainsaw wont start?? HELP
Oct 15, 2006
chainsaw starts then after few cuts shuts down
Mar 30, 2006
More results from forums2.gardenweb.com
chainsaw won't start - any ideas? [Archive] - Straight Dxxe ...
boards.straightdope.com > ... > Main > General Questions
21 posts - ‎11 authors
Jan 31, 2016 | Garden
My chainsaw wont start
Check to see if it is getting fuel into the cylinder. Does the sparkplug get wet when trying to start?
Jul 18, 2014 | Husqvarna Garden
Toro snowblower troubleshooting
FOLLOW this steps and fix it. Merry Christmas
Spark Plug
Every chainsaw relies on a spark plug to ignite the air-fuel mixture for proper combustion. Over time the electrode on the spark plug will burn away and the engine does not start. If the engine does not start, remove and inspect the spark plug. If there is any doubt that the plug is working properly replace it.
Enter your model number to see parts for your chainsaw.
Carburetor
If the chainsaw won't start, the carburetor might be clogged or have bad fuel in the float bowl. If old fuel was left in the chainsaw for a long time some of the volatile ingredients may have evaporated, leaving a thicker, stickier product that is more like varnish or shellac. This sticky fuel can clog up the small jets and ports in the carburetor and it can be difficult to burn making it hard to start the engine. The only solution is to drain the old fuel from the float bowl and thoroughly clean the carburetor with carburetor cleaner. If that isn't effective, replace the entire carburetor.
On - Off Switch
Chainsaws are equipped with an on/off switch. If the chainsaw does not start, this switch might be defective. Check the switch for continuity. In the on position the switch should have continuity.
Safety Switch
If the chainsaw does no start, the safety switch - or throttle control switch - might be defective. If the switch isn't engaging with the throttle it won't provide enough fuel to the engine and the engine does not start.
Ignition Coil
If the chainsaw engine does not start the spark plug may not be getting voltage. Power to the spark plug is provided by the ignition coil. The ignition coil is mounted next to the flywheel. As the flywheel spins an electrical current is induced by the ignition coil. If the ignition coil is defective it will need to be replaced, it is not serviceable.
Rewind Spring
The recoil starter assembly has a rewind spring which spins the pulley backward to rewind the starter rope. If the rewind assembly is broken the rope will not rewind and the engine does not start.
Recoil Starter
If pulling the recoil starter assembly handle doesn't engage with the engine and the engine does not start. Repair or replace the recoil starter assembly.
Recoil Starter Pulley
The recoil starter pulley winds up the starter rope when not in use. If the recoil starter pulley is broken or stuck it may not rewind the rope and the engine does not start.
Dec 19, 2013 | Toro Garden
Need to know what the compression should be for a 2150 poulan chainsaw
the compression on a chainsaw can be checked by simply holding the crank rope by itself, it should chug down the rope very slowly.
Apr 03, 2013 | Poulan Oregon Chainsaw Chain For Chainsaw...
Poulan 18" wildthing chainsaw wont start
have you tried spraying Starter fluid into the Carb to see if it will at least try to run and verify you have good spark?
Dec 05, 2012 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan 2 cycle gas chainsaw 18 inch. Was real
no bar oil should just hurt your chain and bar. remove them and try to start saw. if it still won't start you have other problems you may have to buy a new bar and chain
Feb 02, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Ran chainsaw with brake on and chainsaw will not start now
Hi
Too much fuel at the sparkplug.The fuel accumulated in the cilinder because of brake left.Put the button in off position,remove the sparkplug and dry it,pull the starter for a while until the fuel is out from the cilinder.Put the sparkplug and start the engine.
best regards savumihai71
Dec 19, 2008 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
