Question about Vehicle Parts & Accessories
I have just installed a rebuilt 1.3 L engine in my 1986 Suzuki Samurai and need to know how to set my distributor and time it.
  • Vehicle Part... Master
  • 16,194 Answers
Bring the number one cylinder to TDC that means either use the timing marks on the crank or feel for pressure coming out the spark plug hole. Figure out which plug wire goes to the number one and set the rotor to that plug. Stab the distributor into the hole without turning it. It may be better to mark the rotor position on the housing and make sure it does not move. Take the number one wire and put a timing light on it and crank the engine to see if it is close to being on time. Put all the plugs in and wire them.
Posted on May 06, 2013
Have 1988 Suzuki samurai the distributor is getting hot and when get up to high speeds misses if it sits running long enough it will cut off just does new distributor coil plugs cap rotor timing good have...
there 2 issues, here.
first all dizzy get hot , 180F is the engine temp and the dizzy
will get near that temp. its unavoidable. that fact.
or worse parked and hot soaked,
the ignitor is bad.
a rebuilt dizzy from CARDONE , is about 1/2 the price of the internal bad parts. (VR sensor and ignitor)
need a link to the part?
you get to find out early or late
see ignition choice.
http://www.cardone.com/find-parts/vehicle-parts-listing?make=Suzuki%20Trucks&model=Samurai&year=1988
allstores in usa can get this part., all.
if not , avoid them. like zoned. avoid.
i think rockauto.com sell em. but that takes time.
Aug 18, 2014 | 1988 Suzuki Samurai
What is the firing order for a 1986 samuti engine?
same as all non boxer 4 bangers.
1,3,4,2.
next is distributor rotor rotation, then timing, and well RTM yet>
read the manual.?
it's free...
Samurai. its called in usa, but jimny others places.
see the 3 manuals? its all there.
http://www.fixkick.com/sammi-stuff/index.html
Jun 17, 2014 | 1986 Suzuki Samurai
What is the engine firing order for a Suzuki
firng order is 1-3-4-2 see diagram of distributor cap below.
Jul 23, 2010 | 1986 Suzuki Samurai
1987 suzuki samurai Distributor problems
First, kick his ***. 2nd,, kick your **** for allowing him to mess with your car.. LOL 3rd, Grab a drink for both of you and tackle this together. Remove the spark plug on cylinder #1. Rotate the engine till you get it coming up on the compression stroke. You can hold your finger over this to do it. (Don't be using the starter) Pull the distributor cap and mark on the distributor itself where the #1 wire should be. Now. Put something like a straw into the spark plug hole and continue rotating the engine until it reaches the top. Now look at the distributor and see where the rotor is pointing.. Your BUDDY, should know what to do next. The reason it is currently running is because the timing is too late. Whenever disassembling anything on an engine, notes should always be taken.
Feb 06, 2010 | 1988 Suzuki Samurai
1987 suzuki samurai distributor problem
check your plugs...one might be faulty or installed wrong.
Jun 17, 2009 | 1987 Suzuki Samurai
From frontto back how are the cylinders numbered?
It usually is the cylinder closest to the crankshaft pulley, if your standing front of the vehicle it should be the one closest to you
Apr 30, 2009 | 1986 Suzuki Samurai
How do I change my clutch on an 1986 suzuki samurai
I have found it easier to remove the engine to replace the clutch on my 1986 Samurai it you have the proper tools to pull the engine it took less time than pulling the transmission in my experence.
Nov 29, 2008 | 1986 Suzuki Samurai
Vehicle Parts & Accessories Logo
83 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
