Question about Frigidaire FRT17G4B Top Freezer Refrigerator
Refrigerator does not get cold
The top freezer gets cold, but the bottom refrigerator part gets semi-cold.
  • 1 more comment
  • Anonymous Nov 09, 2007
    i am having daewoo refrigerator. top freezer portion is getting cool. but down refriegrator is not getting cool.
    kindly give me service centre in chennai, india
  • Anonymous May 04, 2009
    i have the same problem, only my refrigerator is maytag
  • Anonymous May 13, 2009
    The freezer works but the fridge will not get cold. It is only two years old but warranty ran out after one year.
The refirgerator is not as cold as usual. But My freezer is really cold and working jus find... what do I do?
Posted on Jan 31, 2009
    Novelist:
  • 159 Answers
Ou need to check to make sure the evaporator fan is working. If it is remove the freezer back to look at the evaporator to make sure it is not frozen over. If it is you have a defrost problem. when the coils on the evaporator get all frosted over air can not move over the coils for the fan to circulate the air through out the compartments so the fresh food section will get warmer while the freezer will be cold. you will need to defrost the evaporator to be able to check the treminator and the heater. to do that you will need to turn the timer thats is located in the fresh foo section usually in back of the thermostat. there may be a removable plug to expose the dial to turn it manually. use a flat blade screw drier to do that. it will only turn one way. as soon as you hear a click stop. the compressor and evaporator fan should stop running. now you can check to see if the heater will come on. if not you will need a volt meter to check the terninator heater and to make sure the defrost timer is all good. you should have 120v at the heater. if you do ohm out the heater to make sure it is ok. most times if it is a defrost problem check the terminator first thats the round disk with 2 wires on it. if it is not closed the heater will not come on.check it out and you should find if there is a problem with the defrost cycle. if you turn the timer untill you hear it click again and the fan and compressor should be running. when you remove the freezer cover and you find the coils are only frosted at the top or just a verry little, you may have a leak in the sealed system and that would be why there os por cooling. you would need to call for service if that is the case. hope this help you some
Posted on Aug 10, 2007
The fridge itself cools by cold air coming from the freezer. There is a hole for the cold air to reach the fridge from the freezer, usually on the top side. Often, this line becomes clogged with ice. In effect, you would hear your fridge constantly running, and the freezer would get very cold, but the fridge only semi-cold (coldest near where the freezer air comes out).
Defrosting helps, but if the line is really iced off, it melts MUCH slower then frost in the freezer. (Note: if you have a FROST FREE freezer, this problem is even more common). A fairly simple way to clear this up is to remove the panel over the fan in the freezer (usually just two bolts over the back wall of the freezer on the inside) and run a blow dryer into the hole that goes from the freezer down to the fridge until it is totally clear of ice. Check to clear away ice on the panel, as well.
Of course, always unplug he unit before working on it, and keep the blow dryer clear of water.
Posted on Sep 05, 2009
    New Friend:
I got a frigidaire side by side top half not cold bottem on bothsides are cold ?????? only 3 to 4 years old took good care of
Posted on Jan 31, 2010
    New Friend:
Remove the back check for ice on the coil this often the cause for this fault
Posted on Sep 06, 2010
    New Friend:
Fridge will only come on when you turn the temperature up,the fridge then turns on but will not come back on until you turn the temp all the way off then on,just put a new defrost timer on it and still same problem please help thank you.
Posted on May 16, 2012
2 Suggested Answers
SOURCE:
  • 34 Answers
SOURCE: Refrigerator Not Cold
You are not moving air between the freezer and refrigerator sections. This may be due to a defective fan motor or a frozen evaporator coil.
Posted on Aug 13, 2009
The freezer gets too cold and the bottom doesn't get as cold anymore
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 25, 2011 | Kenmore 64802 Top Freezer Refrigerator
Top too warm bottom too cold
heatman101
Jan 22, 2011 | GE Profile PDS22MHR Bottom Freezer...
Kenmore refrigerator top works but bottom doesnt get cold
heatman101
Dec 08, 2010 | Kenmore 64802 Top Freezer Refrigerator
Refrigerator is cold in the freezer, but the top of the frig is not cold. Is there are fan to cool the top part of the frig?
heatman101
Dec 05, 2010 | Amana ABB1927DE Bottom Freezer...
Bottom freezer working great, top not cold
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Oct 16, 2010 | Amana ABB1927DE Bottom Freezer...
Problem with the Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator Clicking, buzzing, compressor too hot, thawed out freezer, fridge is semi cool
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Oct 10, 2010 | Amana Easy Reach AFD2535DE Bottom Freezer...
Bottom is freezing properly but, the top refrigerator is not getting cold
heatman101
Oct 03, 2010 | Amana ABB1927DE Bottom Freezer...
Refrigerator in not cold
IF THE FREEZER IS SEMI COLD CHECK THE FREZER FAN IF ITS FROSTED UP IT MAY BE A DEFROST PROBLEM, ALSO CHECK THE CONDENSOR IS IT DIRTY
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 13, 2010 | Kenmore 18.3 cu. ft. Top Freezer...
Aug 09, 2009 | Whirlpool ET4WSKXS Top Freezer...
GE Side By Side top portion of fridge and freezer not cooling
heatman101
Jan 28, 2009 | GE Hotpoint Top-Freezer Refrigerator
Frigidaire FRT17G4B Top Freezer Refrigerator Logo
8,518 people viewed this question
Top Frigidaire Refrigerators Experts
Steve Allison
Steve Allison
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
