Question about Konica Minolta Bizhub 421 Mfp Copier/printer/scanner/fax Mode Network Webdav Lct
C 2801 Error code displayed is c-2801. Says it's an internal error. Any remedies?
5 Suggested Answers
firecontrol7
  • 6161 Answers
SOURCE: Bizhub 420 Photocopier
Have you check the Printer control board. Also does the toner bottle turn? You can force it in 47 Mode. to turn the bottle motor CW or CCW
Posted on Aug 04, 2009
SOURCE: bizhub 420 error code c-2801
konica minolta bizhub 420
error code 2801 plesce relese the code prectical met
Posted on Dec 12, 2010
  • 58 Answers
SOURCE: Error C-2801 with Konica Minolta C6501 C-2801
Remove the transfer belt unit and then remove the transfer belt. Verify all first image transfer rollers (p/n A03U 5012 00)are properly seated in their respective holders.
Posted on Mar 13, 2011
copyalbania
  • 96 Answers
SOURCE: my konica minolta bizhub 361 has an error code
In my experience you have to change the developer and the machine will be ok.Also there is a chance that you have to clean the two toner sensor that are located in the end of the toner bottle,sometimes there is the problem.please let me know.
Posted on Feb 08, 2012
My LG dishwashing machine model LD 2131 SH displays a F error. What does it indicate?
LG DISHWASHER ERROR CODES AND DESCRIPTION MODELS LD 1420W2 D1420WF LD...
ERROR CODES; FAULTS & REMEDY ERROR DISPLAY [IE]
Inlet error.
Condition: Not reached to the normal water level in spite of 10 min. water supply.
Possible causes:
  1. The Water Tap is not opened.
  2. The Inlet Hose is twisted.
  3. The Filter of inlet valve clogged by impure water.
  4. The Inlet Water Valve is normal ?
  5. The water pressure is very low. ( below 0.5 kgf/ )
  6. Inlet valve is blocked by safety device for leakage sensing.(In case of Inlet Valve).
Remedy
    • Open the Water Tap.
    • Repair the Inlet Hose.
1.Close the Water Tap.
2.Unscrew the Inlet Hose (Inlet Valve side)
3.Clean the Filter of Inlet Valve.
> Replace or repair the Inlet Valve.
> Check the water remain on the base.
1.Check the point of damages and repair or replace the related parts.
2.Disconnect the inlet hose to dishwasher to unlock the safety valve.
ERROR DISPLAY [OE]
Drain error.
Condition: Not fully drained out in spite of 5 min. drain operation.
Possible causes:
  1. The Filter clogged.
  2. The Drain Hose twistec or blocked.
  3. The Drain Pump/Motor or circuit is troubled.
Remedy
    • Clean the Filter.
    • Remove the cause of twist or block.
    • Replace the Drain Pump/Motor or repair the Circuit.
ERROR DISPLAY [E I ]
Leakage error.
Condition: The water level in Tub goes down during operation.
Possible causes:
  1. Water leakage in Hose connections.
  2. Water is leaked by damages.
  3. Impeller of the washing Pump is worn away.
  4. The Thermal Protector of the washing motor is functioned
Remedy
    • Replace the connections of Hose.
    • Check the point of damages and repair or replace the related parts.
    • Replace the washing pump.
    • Check the applied voltage.
ERROR DISPLAY [ F E ]
Excess error.
Condition: Excessive water is supplied than normal water level.(Automatically drain Pump operated.).
Possible causes:
  1. The Inlet Valve is troubled.
  2. The Air Break is troubled.
  3. The Sensor Assembly is troubled.
  4. The Controller is troubled.
Remedy
    • Replace the Inlet Valve.
    • Replace the air breaker.
    • Replace the sensor assembly.
    • Repair or replace the controller.
Jul 09, 2017 | Washing Machines
Error code 54.1103
Code Display 54.XX Error Turn off then on Description The product has experienced an error with one of the internal sensors. Remedy Turn the product power off, wait at least 30 seconds, and then turn the product power on and wait for it to initialize. If you are using a surge protector, remove it. Plug the product directly into the wall socket. Turn the product power on.
May 11, 2015 | HP Color Laserjet M451dw Printer
Why givethe Hp color laser jet cp1515n 51.23 error massage
Hi
I found this message regarding your error
Display: 51.XX Error
Description: The product has experienced an internal hardware error
Remedy: Turn the product power off, wait at least 30 seconds, and then turn the product power on and wait for it to initialize. If you are using a surge protector, remove it. Plug the product directly into the wall socket. Turn the product on.
You can also find it here:
Error Codes HP Color LaserJet CP1515 Code 51 XX
and by using the drop down menus you can find details on other errors and also other models and makes. There is also a link to get a pdf format Service Manual which may be useful to you in the future.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 17, 2014 | HP Office Equipment & Supplies
Error 0 problem
see the error +causes +remedy:God bless you
Description
Errors 00 through Error 04 check upper PCA memory locations, RAM memory locations and
EEPROM checksum during the power up test sequence. If a fault is found during the power up
test sequence, the appropriate error code will be displayed.
Possible Causes
1. These errors messages almost always indicate an upper PCA problem when they are
consistently displayed. Failures causing these error messages to be displayed are rare.
Possible Remedies
1. If the error message is consistently displayed when the unit is powered up, the upper PCA
should be replaced. It is possible to see one of these messages displayed intermittently due
to external causes. If the units A.C. input significantly dips during the power up test sequence
the test could fail resulting in one of these messages being displayed. Treadmills operating
on non-dedicated A.C. circuits may see these messages displayed on an intermittent basis.2_4_2013_5_52_44_pm.gif
Feb 04, 2013 | Proform Sport 1000 Folding Treadmill...
Xerox 560 error code 127-212
Error Codes
If an error caused the printing to end abnormally or a malfunction occurred in the printer, then an error message code (***-***) is displayed.
If an error code not described in the following tables is displayed, or the problem persists even after you have tried the following solutions, contact the Customer Support Center.
Tip
If an error code is displayed, all print data of the printer as well as print data stored in the built-in memory of the machine is discarded.
Error Code: 127-212
Error Category: Print; Other Problems
Cause: Detected an internal print check error by the FreeFlow
Print Services Controller.
Remedy: Remove and reinsert the command/video cable between the FreeFlow Print Services Controller and the printer. Power off and on both the printer and the FreeFlow Print Services Controller. If the problem persists, call the Customer Support Center.
*** extracted from my Fuji Xerox Color 560 Printer - Printing Systems User Guide
*** I assume we have the same printer
Jul 13, 2012 | Lenovo ThickCentre M58p Desktop 7479A3U
Document in ADF
None of these worked for me. Here is my FIX:
Open the part containing the rollers. You can see a white plastic part which stop the documents feeded into the adf. Lower this part and insert a page into the adf just a bit further than where it would have stopped from that white stopper. This forces the machine to feed the document and clears the error right away. You only have to do this once and from then mine worked fine.
Jan 25, 2012 | Canon Pixma MX410 All-In-One Printer
Show picture of carousel rotary for hp 2840
Carousel rotation motor error, only professionals can do this activity,, Pl submit the unit in service center,, online support not suggestible..
Nov 16, 2011 | HP LaserJet 2840 Printer
Bizhub 420 error code c-2801
Feb 08, 2010 | Konica Minolta Office Equipment & Supplies
May 06, 2009 | Konica Minolta Office Equipment & Supplies
Konica Minolta Bizhub 421 Mfp Copier/printer/scanner/fax Mode Network Webdav Lct Logo
19 people viewed this question
Top Konica Minolta Computers & Internet Experts
Lawrence Oravetz
David Payne
David Payne
Tom Chichester
Are you a Konica Minolta Computer and Internet Expert? Answer questions, earn points and help others
