Question about Ford Tractor Grill 2600 3600 4600 5600 6600 7600
2600 injector pump leak repair - Ford Tractor Grill 2600 3600 4600 5600 6600 7600
Injection pump leaking.ford escort 1.8 td 1999
you need 'tractor tire' injector ring seals
Feb 17, 2015 | 1999 Ford Escort
Kubota M 5030 2.8 6 cyl. Diesel in oil sump. Why?
Diesel gets in the sump from an seal leaking in the fuel pump through to the drive gear and out into the sump. If it has an inline pump( one where the injector lines are in a row at the top of the pump) the fuel will be leaking past the plunger elements and into the pump sump which then drains back tot he engine sump. IF it is slight but consistent sometimes injectors will dribble when shut down and the fuel will by pass the piston rings into the sump. Talk with a diesel pump and injector repair specialist for any faults particular to the Kubota fuel system
Apr 03, 2013 | Cars & Trucks
How do ya fix codes p0320&p0340
Ford Crown Victoria, Mercury Grand Marquis, Marauder, Lincoln Town Car 1999-2005
4.6L V8 - Auto 2
Print
Trouble Code: P0201
Cylinder 1 Injector Circuit Malfunction
Possible Causes:
Injector 1 connector is damaged, open or shortedInjector 1 control circuit is open, shorted to ground or to powerPCM has failed (the injector driver circuit may be damaged)
Trouble Code: P0202
Cylinder 2 Injector Circuit Malfunction
Possible Causes:
Injector 2 connector is damaged, open or shortedInjector 2 control circuit is open, shorted to ground or to powerPCM has failed (the injector driver circuit may be damaged)
Trouble Code: P0203
Cylinder 3 Injector Circuit Malfunction
Possible Causes:
Injector 3 connector is damaged, open or shortedInjector 3 control circuit is open, shorted to ground or to powerPCM has failed (the injector driver circuit may be damaged)
Trouble Code: P0204
Cylinder 4 Injector Circuit Malfunction
Possible Causes:
Injector 4 connector is damaged, open or shortedInjector 4 control circuit is open, shorted to ground or to powerPCM has failed (the injector driver circuit may be damaged)
Trouble Code: P0205
Cylinder 5 Injector Circuit Malfunction
Possible Causes:
Injector 5 connector is damaged, open or shortedInjector 5 control circuit is open, shorted to ground or to powerPCM has failed (the injector driver circuit may be damaged)
Trouble Code: P0206
Cylinder 6 Injector Circuit Malfunction
Possible Causes:
Injector 6 connector is damaged, open or shortedInjector 6 control circuit is open, shorted to ground or to powerPCM has failed (the injector driver circuit may be damaged)
Trouble Code: P0207
Cylinder 7 Injector Circuit Malfunction
Possible Causes:
Injector 7 connector is damaged, open or shortedInjector 7 control circuit is open, shorted to ground or to powerPCM has failed (the injector driver circuit may be damaged)
Trouble Code: P0208
Cylinder 8 Injector Circuit Malfunction
Possible Causes:
Injector 8 connector is damaged, open or shortedInjector 8 control circuit is open, shorted to ground or to powerPCM has failed (the injector driver circuit may be damaged)
Trouble Code: P0219
Engine Over-Speed Condition
Possible Causes:
Engine operated in the wrong transmission gear positionExcessive engine speed with gear selector in Neutral positionWheel slippage due to wet, muddy or snowing conditions
Trouble Code: P0230
Fuel Pump Primary Circuit Malfunction
Possible Causes:
FP or FSV circuit is open or shortedFuel pump relay VPWR circuit openFuel pump relay is damaged or has failedPCM has failed
Trouble Code: P0231
Fuel Pump Primary Circuit Low Input
Possible Causes:
FP or FSV circuit is open or shorted to groundFuel pump relay VPWR circuit open or fuel pump relay failedPCM has failed
Trouble Code: P0232
Fuel Pump Secondary Circuit High Input
Possible Causes:
Fuel pump relay contacts always closedFuel pump ground circuit has high resistanceFuel pump secondary circuit is shorted to powerLow speed fuel pump relay damaged or related circuit problem
Trouble Code: P0297
Vehicle Over-Speed Condition
Possible Causes:
The code indicates the vehicle was driven at very high engine speed (rpm) for too long. The PCM temporarily prohibits high engine speed by disabling the fuel injectors with this code set.
Trouble Code: P0300
Random Misfire Detected
Possible Causes:
Base engine mechanical fault that affects two or more cylindersFuel metering fault that affects two or more cylindersFuel pressure too low or too high, fuel supply contaminatedEVAP system problem or the EVAP canister is fuel saturatedEGR valve is stuck open or the PCV system has a vacuum leakIgnition system fault (coil, plug) affecting two or more cylindersMAF sensor contamination (it can cause a very lean condition)Vehicle driven while very low on fuel (less than 1/8 of a tank)TSB 03-14-4 contains repair help for this code for COP ignition
Trouble Code: P0301
Cylinder Number 1 Misfire Detected
Possible Causes:
Air leak in the intake manifold, or in the EGR or PCM systemBase engine mechanical problem that affects only Cylinder 1Fuel delivery component problem that affects only Cylinder 1 (i.e., a contaminated, dirty or sticking fuel injector)Ignition system problem (coil, plug) that affects only Cylinder 1TSB 02-16-2 contains repair help for this code (LS & T-Bird)TSB 03-14-4 contains repair help for this code for COP ignition
Trouble Code: P0302
Cylinder Number 2 Misfire Detected
Possible Causes:
Air leak in the intake manifold, or in the EGR or PCM systemBase engine mechanical problem that affects only Cylinder 2Fuel delivery component problem that affects only Cylinder 2 (i.e., a contaminated, dirty or sticking fuel injector)Ignition system problem (coil, plug) that affects only Cylinder 2TSB 02-16-2 contains repair help for this code (LS & T-Bird)TSB 03-14-4 contains repair help for this code for COP ignition
Trouble Code: P0303
Cylinder Number 3 Misfire Detected
Possible Causes:
Air leak in the intake manifold, or in the EGR or PCM systemBase engine mechanical problem that affects only Cylinder 3Fuel delivery component problem that affects only Cylinder 3 (i.e., a contaminated, dirty or sticking fuel injector)Ignition system problem (coil, plug) that affects only Cylinder 3TSB 02-16-2 contains repair help for this code (LS & T-Bird)TSB 03-14-4 contains repair help for this code for COP ignition
Trouble Code: P0304
Cylinder Number 4 Misfire Detected
Possible Causes:
Air leak in the intake manifold, or in the EGR or PCM systemBase engine mechanical problem that affects only Cylinder 4Fuel delivery component problem that affects only Cylinder 4 (i.e., a contaminated, dirty or sticking fuel injector)Ignition system problem (coil, plug) that affects only Cylinder 4TSB 02-16-2 contains repair help for this code (LS & T-Bird)TSB 03-14-4 contains repair help for this code for COP ignition
Trouble Code: P0305
Cylinder Number 5 Misfire Detected
Possible Causes:
Air leak in the intake manifold, or in the EGR or PCM systemBase engine mechanical problem that affects only Cylinder 5Fuel delivery component problem that affects only Cylinder 5 (i.e., a contaminated, dirty or sticking fuel injector)Ignition system problem (coil, plug) that affects only Cylinder 5TSB 02-16-2 contains repair help for this code (LS & T-Bird)TSB 03-14-4 contains repair help for this code for COP ignition
Trouble Code: P0306
Cylinder Number 6 Misfire Detected
Possible Causes:
Air leak in the intake manifold, or in the EGR or PCM systemBase engine mechanical problem that affects only Cylinder 6Fuel delivery component problem that affects only Cylinder 6 (i.e., a contaminated, dirty or sticking fuel injector)Ignition system problem (coil, plug) that affects only Cylinder 6TSB 02-16-2 contains repair help for this code (LS & T-Bird)TSB 03-14-4 contains repair help for this code for COP ignition
Trouble Code: P0307
Cylinder Number 7 Misfire Detected
Possible Causes:
Air leak in the intake manifold, or in the EGR or PCM systemBase engine mechanical problem that affects only Cylinder 7Fuel delivery component problem that affects only Cylinder 7 (i.e., a contaminated, dirty or sticking fuel injector)Ignition system problem (coil, plug) that affects only Cylinder 7TSB 02-16-2 contains repair help for this code (LS & T-Bird)TSB 03-14-4 contains repair help for this code for COP ignition
Trouble Code: P0308
Cylinder Number 8 Misfire Detected
Possible Causes:
Air leak in the intake manifold, or in the EGR or PCM systemBase engine mechanical problem that affects only Cylinder 8Fuel delivery component problem that affects only Cylinder 8 (i.e., a contaminated, dirty or sticking fuel injector)Ignition system problem (coil, plug) that affects only Cylinder 8TSB 02-16-2 contains repair help for this code (LS & T-Bird)TSB 03-14-4 contains repair help for this code for COP ignition
Trouble Code: P0315
Unable to Learn Crankshaft Variation
Possible Causes:
Inspect the CKP sensor for damageInspect the CKP sensor for debris on the rotorInspect the crankshaft pulse wheel for damaged teethInspect the crankshaft pulse wheel for wobble (loose condition)
Trouble Code: P0316
Misfire in the First 1000 Revolutions
Possible Causes:
Check for CMC DTC P0136, P0156, P0171, P0172, P0175, P1130 and P1150. Repair these adaptive fuel and HO2S codesCheck for any other CMC in memory. Repair these codes first!Ignore P1000 codes that set during KOEO and KOER Self-Test
Trouble Code: P0320
Ignition Engine Speed Input Circuit Malfunction
Possible Causes:
Inspect for problems with an Aftermarket 2-way radioInspect for signs of "arcing" at one or more of the ignition coilsInspect the Profile Ignition Pickup (PIP) unit inside distributor (check for damage or corrosion at the PIP sensor connector)PIP sensor is damaged or it has failed (distributor models)Ignition control module (ICM) has failed (Distributorless models)Trouble Code: P0340
Camshaft Position Sensor Circuit Malfunction
Possible Causes:
CMP sensor circuit is open or shorted to groundCMP sensor circuit is shorted to powerCMP sensor ground (return) circuit is openCMP sensor installation incorrect (Hall-effect type)CMP sensor is damaged or CMP sensor shielding damagedPCM has failedTSB 02-22-1 contains repair information for this trouble code
Nov 16, 2012 | Ford Cars & Trucks
Gas leak from top of fuel pump
it deprnd on wher the leak is if its from were the elbow mee the plate at top of pump you may be able to pull pump and sotter or braze it othereis ur looking at sending unit replacement
Sep 26, 2012 | 2004 Volkswagen Jetta
My isuzu truck mixes diesel and engine oil. what is the cause?
the injector are along top of engine , the lines all run back to a pump usually attached to engine side, only unit with multiple metal tubes running out to engine top, removal of injectors requires some special tools. this requires good diesel knowledge and tools to repair either one.
Jun 09, 2012 | Isuzu Cars & Trucks
I sent repair the diesel pump to experts "Rotto Diesel" for my John Deere 450 B Crawler. When I mount it, I look blank smoke and piston sounds. Also, I look leak diesel from the line that supply...
Well, fix the leak, but it sounds like the injector pump may not be timed correctly. This timing is critical and the unit will run poorly if out just slightly. Connect with the guys at Rotto Diesel and get directions on how to time the pump.
Mar 15, 2011 | Garden
Honda Excell 2600 no pressure and water is leaking from the pump. i believe it's the unloader but can i fix it myself. i'm handy with tools and repairs but do no have the manual.
a manual will not tell you how to replace the unloader if you have the same unloader you will need a pressure gauge to adjust it at 2600 psi and your spike pressure should not exceed 3100psi and the leak at pump you need to check your oil make sure is not milky and if not you will need seals also
Aug 23, 2010 | Garden
I have the exact same problem with my HZJ75, have had injectors and pump reconditioned, checked glow pluga and pre-heater timer, all ok...yet still a struggle to start?? PLEASE CAN ANYONE HELP.
I thing you repaired old injection pump and injectors
Have you check the pressure from the pump can open the injectors?
I-loose the all injector main pipe from the injection pump only injectors side
2-try to crank the engine just start while engine moving if you see diesel pressure where you loose means injection pump looks good, try to fixed all the pipes while engine cranking if the engine refuse to star injectors needs to resit correct opening pressure.
3-check the injectors pressure follow instruction manual book.
4-Check is any leaks all connections.
5-Check engine compression.
good luck
Feb 04, 2010 | 2001 Toyota Land Cruiser
Same Problem !!!!!
hi...im vijay from chennai...i run a autorised car service centre in chennai india...we get a lot of fiat palio's with the same problem...but the real trouble is in the sensors located inside the fuel pump...those malfunction and require replacement...we have successfully solved lot of problems related to fuel pump in our workshop...you can conact us for any issues...but only request is to bring the car over to our place and get it repaired...what ever we do will be covered under a warranty of 1 year...so no cause of worry...our contact details are 98840 93900...baw.mytvs@gmail.com
Jul 21, 2009 | 2007 Fiat 124
Diesel Fuel leak of of large nut in backside of injector pump
do yourself a favor and take the truck to a fuel diesel injection shop the larger nut is just a cover but the smaller one is an adjustment if you remove either on you could damage the pump
Jun 01, 2009 | 1986 Dodge Ram 50
Ford Tractor Grill 2600 3600 4600 5600 6600 7600 Logo
103 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
donald boissonneault
fordexpert
Are you a Ford Garden Expert? Answer questions, earn points and help others
