Question about General Electric GSS22JET Side by Side Refrigerator
Samsung rf267aars freezer door - General Electric GSS22JET Side by Side Refrigerator
Samsung french door freezer will not open
Aha!
The Samsung wants the password.... in French! No!
Sorry.... couldn't resist....
If it's iced up then that would hold it shut until it melts.
Icing up is usually caused by a bad seal!
Sep 18, 2015 | Samsung RF217ACPN - 20 cu. ft. French Door...
Removing samsung freezer drawers
There are 3 bolts that hold the bottom of the freezer door in place, if you remove them the door will fall to the floor then youmcan pull it off then you can access the drawer
Sep 07, 2012 | Samsung RFG237AARS Bottom Freezer French...
Samsung french door freezer gets lots of frost inside - we've replaced the gasket but still get frost
Could be the rail slides not closeing correctly keeping door open slightly. Also they have made a new stronger set of rails to be used. Try going to the Samsung web site for tech info our recalls for that unit
Aug 18, 2012 | Samsung RF265AA Bottom Freezer French Door...
I need owners manuel download for Samsung refrigerator/freezer 26 cu ft French Door, Model # RF267AARS
You should be able to download this directly from Samsung's website, www.samsung.com. Just have your model number and serial number if needed.
Aug 14, 2012 | Samsung Refrigerators
Samsung rf267aars icemaker stops making ice, icemaker makes clicking noise.
unfortunately it sounds like you have a broken tooth on the drive or driven gear of the ice maker, in this case you should replace the ice maker. The good news is that you can get a new one for about 85 bucks at your local appliance parts store.
Jun 23, 2009 | Samsung RF265AA Bottom Freezer French Door...
We own a RF267AARS/XXA refrigerator. Ice maker works slow. Hardly ever makes a full tray of ice in 24 hrs. Then for no reason quits making ice for 2-3 days. I the pull the ice-tray out a couple of times...
You'll have to read my in depth review on Epinions.com for answers. Sounds like you bought the updated version that over corrects the "too much" ice which jams the mechanism to where it breaks the unit. This is my second friggen Samsung as my 1st 4 door quatro was replaced under their lemon law. Spending $2500 I thought I was buying quaility, instead I bought greif. I'm still working with Best Buy to get Samsung to fix the icemaker with it's current problem which sounds like yours. Go to the Epinions website and look me up, my username is "walkerpkw" My review was posted last year. Read both my horrifying Samsung reviews. Something is very wrong with their engineering department. You'll find my email address on my profile page. I'd be happy to inform you if the get this fixed. I'm told it's the fridges computer board and they're redisigning another?
Oct 29, 2008 | Refrigerators
Two issues
Well here is How I fixed My French Door Ice Maker, It made the same loud crashing sounds, and seldom put out much ice. To the point that it made no ice at all.
First, Make sure you can get water out of the front, if not, your water lines may be clogged.
The second thing you can do is hit the secret RESET button on the upper front side of the ice maker. See my first image for it's location, it is a soft rubber button.
The third thing.. In my case the reset button worked for a little bit. But eventually stopped. I had to remove the ice maker, and found that that several rows of ice had gotten stuck. The swinging arm that smacks the ice out would just strip the gears banging that ice to no avail. So opening the ice maker up and cleaning it out helped. I also cleaned the sensor contact with some alcohol. It is a thin metal strip close to where the gearing housing is. This I believe is ultimately where the problem starts. It allows the trays to get overfilled, and the ice can't be released. Once I cleaned out the tray of stuck ice, cleaned the sensor, plugged it back in, and hit the reset button once more, It was making loads of ice once again. If this fails, you can get a complete new ice maker online, I found a vendor on eBay selling it for a reasonable $80. You can use my pictures to see how to disassemble for repair ore replacement. My fridge by the way is the RF267AARS.
the part number is: DA97-05554A
It works with the following refrigerators
Samsung RF267AABP Samsung RF267AABP/XAA Samsung RF267AARS Samsung RF267AARS/XAA Samsung RF267AASH/XAA Samsung RF267AAWP/XAA
Oct 17, 2008 | Samsung RF265AA Bottom Freezer French Door...
General Electric GSS22JET Side by Side Refrigerator Logo
19 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
