Samsung 19 inch hd ready tv turns on by itself
Why dose my samsung tv keep turning itself on and off. there is no picture just the sound, its abit spooky,so i have to turn it off at the mains or it will do this all the time, if not disconected at the mains and you never know when it is going to do it,other than that it is a nice picture and sound, iv had it for two year and just put up with the spooky goings on.just thought id ask if anyone knew what/if anything to do about the problem and if anyone had the same problem,and what they did..
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
There is something wrong with its main digital board. Your TV need a through check up. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. More than Nine Lakh viewers cannot be wrong.http://electronicshelponline.blogspot.com/
Posted on May 06, 2013
SOURCE: samsung lcd tv le32r8
perchè quando collego il computer al televisore l' audio è assente?
Posted on Jan 19, 2008
SOURCE: TruTech 19" LCD TV+DVD
I have a sansui 19" LCD TV+DVD
I had to attempt multiple times turning the TV on to get a picture. The sound was fine. This kept happening when I would go to turn on the set the TV kept playing fine with picture & sound but after the 2nd attemts I turned it off & then tried to turn it back on which took multiple attempts, it kept playing for a few minutes then the picture went out but the sound was still there.
The set is not yet 2 years old.
Posted on Apr 13, 2008
SOURCE: LG TV
There is probably a bad capacitor on the power board, I had the same thing happen to my 42LB1DR after 2 years. T.V. would turn on and white power light would blink, no pictue and no sound. If your'e a diy'er, it is not that hard of a fix. Take all the covers off of the back of the tv(UNPLUGGED!!!), then look at all the capacitors on the power board. lcd_repair_4_bad_capacitors_lg.jpg
These are the capacitors, look to see if any of them appear to have a bump on the top of them. They are supposed to be flat, you can also tell if one of them has gone bad if there is an oily substance on the metal cover that was removed. If one of them is in question, carefully remove the board, and take it to an electronics store to have them sotter ?sp on a new capacitor. It ended up costing me around $40.00 to have this done. Good luck and if you are not comfortable trying this, than take it to a repair shop, but I was quoted around $450 to take the T.V. in. No Thanks
Posted on Nov 21, 2008
  • 19 Answers
SOURCE: LG 42LG5 TURN ON TV PICTURE GOES BLACK
This could be 1 of a few things here. Without opening up your set and trying to look at voltages or indiciator lights I couldn't tell you exactly without some more info.
Without looking at it myself here are my thoughts and where I would first look at.
It may be a main board because:
1) Main board processes all your audio/video signals. Bad main board means bad video processing. Could do that. Especially if the main board is not sending the right signal or a bad signal to the rest of the boards so they don't do their jobs.
It may be a power supply because:
1) Power supply is well, the power supply. If it's sending inadaquete voltage to the main board you may not be recieving enough juice to keep that main board doing your video processing or further up the line keeping enough juice flowing to your TCon board to keep it telling things where to go and what to do. The power supply sends voltages to your Ballast board(controls your lights) and to your main board through which power is supplied to your TCon board via a LVDS line and a +12/+16V signals. If the power supply isn't pumping out enough juice to keep the TCon or Main Board running, it could be a problem. By the same token it could be that your P/S isn't sending power out to your ballast board.
It could be a TCon because:
1) If the TCon is bad, you won't get your pictures. This could be the TCon board itself or the LVDS cable from your TCon to your Main. However, with few exceptions, if it's a bad TCon you're looking at a total panel replacement.
It could be a ballast board because:
1) The Ballast Board controls the lighting behind the LCD screen. If this isn't working right you won't be seeing much of anything without that back lighting. If this is bad, it's a panel replacement. These are not field replaceable items by LG.
Based on the symptoms, without more data or a eyes-on view of it, I would say you're most likely looking at a Main Brd or PSU problem.
Posted on Feb 21, 2009
SOURCE: tv keeps disconnecting from digital tv, returns within 5 seconds but highly annoying! pictue goes blank and sounds goes aswell , almost like the tv has turned off only to restart itself
It sounds like it is loseing signal, check your connections, and make sure you have the correct cable
Posted on Jun 01, 2009
Turned itself off. I turned it back on and the green power light blinks for awhile then blinks red for awhile.no picture or sound
Get rid of this TV. Had one and replaced the bulb and light engine many times. Just buy a Samsung or Vizio 50+ inch instead and be very happy. Those Panasonic projection TV's were terrible. You will find a 50 inch Vizio for around $500 bucks and it will blow your mind how great the picture looks.
Oct 16, 2014 | Panasonic PT-50LC14 50" Rear Projection...
Plug in head phones to tv/no sound
If no sound from speakers or headphone likely audio circuit issue but check to make sure main speakers not switched to off or external.
Nov 04, 2012 | Toshiba 19AV505DB 19-Inch Screen Hd Ready...
No picture
Listed here as a 22 inch LCD which means if something serious which it could be--cheaper to replace than repair--other option is to spend money to have a shop look at the TV.
Jun 14, 2012 | byD sign d:2232 22 in. HD-Ready LCD...
My samsung 50" tv
You have bad capacitors on the Power supply board. I have included a picture of what they look like. It's not an expensive repair. This pix is not your board, just what the capacitors will look like.
Jan 11, 2011 | Samsung LTP326WX/XAA 32 in. HD-Ready LCD...
Samsung LA40A550 no picture and sound
Power supply board is dead.That the board,the power a/c cord go into it.Replaced the power supply board will solved ur tv power lite LED light indicator blinking and ur tv power will be stable and work again.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jun 04, 2010 | Samsung LA40A550 40 in. HD-Ready LCD TV
I have a samsung 32 inch lcd tv,it has a mind of its own,turns itself on and off,can't alter the volume,icons stay on the screen.when its on ha ha the picture is great..
Sounds like a button is stuck? Hide the remote and make sure it's not the problem... if it persists, check and jab the buttons on the TV itself...
If it turns off, it sounds like the on/off button is the problem... and if it's jammed 'on', then other buttons wouldn't work.
Apr 20, 2009 | Samsung LA26R71BD 26 in. HD-Ready LCD TV
32 inch Samsung LCD TV has no picture
do this test, turn tv on and touch the screen if you can see light in the background it is the panel if no back light is present then it is the power board.
Mar 03, 2008 | Samsung LE32R41BD 32 in. HD-Ready LCD...
SAMSUNG 19 INCH HD READY WIDESCREEN LCD TV LE19R71BX/XEU
We will need a list of the everything you tried.
Usually, this kind of thing is caused by hookup errors.
Dec 27, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Vizio
my 50 inch vizio plasma bulb went out...still turns on with sound ..but no picture...help
Sep 17, 2007 | Vizio L6 20.1 in. HD-Ready LCD Television
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
Electro Med Services...
