Question about E-Machines eMachines Desktop PC
Maxtor slave hi yea i just found this computer and its asking for a password on the screen its under IDE CHANNEL 1 SLAVE : N & then im being promted for a passwrd
  • E-Machines Master
  • 27,725 Answers
EMachines is a brand of entry level, affordable computers now owned by Acer.
The computers come with the Windows operating system.
To keep your computer secure, it is a smart idea to continually reset and change your password. Changing the password will take only a moment.
Log in to your user account.
Press "Ctrl" plus "Alt" plus "Delete" simultaneously.
Click "Change Password" from the list of options.
Enter your old password.
Enter your new password twice to confirm.
Press "Enter" to save the changes.
Reset An eMachine
eMachines manufacturers a series of netbooks, desktops and laptop computers.
Certain applications and circumstances will require you to reset your computer.
Resetting your eMachine computer is a quick process that can be used to fix problems, complete program installations and access the BIOS or other Windows tools, such as Safe Mode.
Click "Start" in the Windows taskbar.
Click "Shut Down."
Click "Restart."
Normal Restart for Windows Vista/7
Click the "Start" orb in the Windows taskbar.
Click the arrow next to "Shut Down."
Click "Restart."
Change your Windows password
http://windows.microsoft.com/en-US/windows-vista/Change-your-Windows-password
Posted on May 05, 2013
What are the 2 pins in the back for? master slave configurations? If so what jumper setting makes it a slave?
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
hope this helps
dont forget to vote
Feb 06, 2011 | Hitachi Deskstar 7K160 HDS721616PLA380 160...
Is there a slave or master switch on the hard drive want to hook up a external hard drive enclosure
hope this helps
Jan 29, 2011 | Hitachi Deskstar 7K500 500 GB Hard Drive
What is the position of the link do I need to change to master/ slave etc
hope this helps
Jan 28, 2011 | BenQ CRW-5232W 52X32X52 IDE CD-ReWriter...
Ok, i had an IDE HD of Maxtor. Now i just bought a SATA one from SAMSUNG. I want to make the SAMSUNG to be the master and the Maxtor Slave. Jumped the Samsung, removed the jumper from the Maxtor. Now, to...
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to ......,press escape then press f10 to save to cmos to restart
??????????????????????????????????????????? hope this helps
Dec 27, 2010 | EliteGroup ECS 945P-A...
Hd western digital wd800jd - preciso do manual do hd. e tambem configurar jumpers. grato!
hope this helps
hope this helps
Dec 10, 2010 | Western Digital Caviar SE WD800JD SATA...
I have a maxtor quantum fireball plus as 20.5 hard drive. i want to set it to slave. how do i set the jumpers?
on maxtor drives, you will find the jumper within a cluster of 9 pins. if you look on the bottom of the drive, on the circuit board, the pins should be labeled "ms" "cs" and such. the "ms" and "cs" stand for "master" and "cable select". you rarely use the true "slave" setting anymore, more often than not' "slave" drives are set to "cable select" and are attached to the middle, slave position on the ide cable. in "cable select" mode, the cable decides what device is master and what is slave, depending upon the devices' position on the ide cable.
to set the drive to "slave", set the jumper so that it only has 1 pin under it, and doesnt actually jump any pins, or just take the jumper out. only use the "slave" setting if the "master" device on the same ide cable is actually set to "master".
if the master device is actually set to "cable select" then you will have to set the slave device also to "cable select" and the middle position on the ide cable will set it automatically to be a slave. , instead of using the jumper to make it the "slave".
to set the drive as "cable select", which is what i would recommend, use the jumper to connect the 2 pins which are labeled "cs", the 2nd position from the bottom position on most older maxtor drives, and attach this hard drive to the middle connector of the ide cable.
Nov 25, 2010 | Quantum Fireball Plus AS (QMP20000AS-A)...
Take Three: I have an older Maxtor Hard DriveTake Two: I have an older Maxtor Hard Drive (Model 90645D3). I need to transfer some files from it (Win98SE) to new hard drive (WinXP Pro). I asked earlier and...
Jumper off will set the drive to slave. If you can connect both drives to the same ribbon cable with the master on the end & the slave to the second connector. Look at your bios as win is booting up to see if shows the drive as slave, you will not be able to copy windows as a operating system off of the drive, but should be able to copy files.
Good luck on your endevors.
Lee
Nov 12, 2009 | Maxtor Hard Drive
How to detect the hardrive?
setup the first drive as slave ( sometimes No Jumper ) then the furthest away drive as Master.
If this fails, and you have 2 IDE Slots on the motherboard. ( Primary/Secondary ) Put 1 drive on primary as Slave. And DVD Rom As Master ( same Cable ) Then put second drive On Secondary IDE Slot. ( Set As Master Or Slave )
If none of these solutions Work For you, check to see if Both Channels are activated in the Bios.
Thankyou For Using Fixya.
Mike @ compurepair.
Jan 28, 2009 | Maxtor Hard Drive
Jumpers
You can only have TWO (2) Devices in IDE - Master and Slave.
For example
Cable 1 (ide channel 1)
Master - HDD
Slave - Tape Drive
Cable 2(ide channel 2)
Master - CD/DVD drive
Slave - HDD
Do you have a diffrent type of cable?
Oct 08, 2008 | HP DDS-4 20/40GB (c5683-00255) DAT Tape...
Setting up a Computer to install Windows XP Professional.
Pedro -
I'll assume each of these is an IDE device, meaning each has a wide connector versus a narrow SATA connector commonly found on newer hard drives.
Your motherboard should have two IDE channels, labeled IDE 1 and IDE 2, Primary IDE and Secondary IDE, or something similar. Each IDE channel can support two devices.
For best performance between the drives, you will want to have the Hard Drive connected as Master(Drive 0) on the Primary IDE channel; The CDROM should be connected as Slave(Drive 1) on the Primary IDE channel. Connect the DVDROM as Master(Drive 0) on the Secondary IDE channel, and the ZIP Drive as Slave on the Secondary IDE channel.
When connecting the drives, make sure you set the jumpers correctly; Both the Hard Drive and the DVDROM should have their jumpers set to Master, the CDROM and Zip drives should have their jumpers set to Slave. An alternative is to set the jumpers for every drive to Cable Select(CS), allowing the physical connection of each drive to determine whether its a Master or Slave device.
*Note*
If your Hard Drive is a SATA device, connect it to the '0' or '1' SATA connector on the motherboard. Have the DVDROM set up by itsself as Master on the primary IDE channel, the CDROM as Master on the Secondary IDE channel, and the ZIP as Slave on the Secondary IDE channel.
Hope this helps!
-thinstatic
Jun 11, 2008 | ASUS P4S8X-MX Motherboard
E-Machines eMachines Desktop PC Logo
56 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
