Question about iPhone Apps
Charge phone It's hard to charge my iPhone I have to keep playing with it to charge I'm not sure if its the charger or the phone. Please help...
Not sure but nothing that could not be. Charge phone - 5_6_2013_10_53_01_am.png
Posted on May 06, 2013
Why won't my iPhone 5 charge?
if the charger is working and connected properly , it will charge with out the phone being switched on
check the charger with another phone or it could be a bad battery not accepting a charge
Sep 20, 2015 | Apple iPhone Smartphone
Does wireless chargers harm phone? Any charger that not do harm?
Choetech wireless chargers doesn\'t harm the phone. It automatically switches off when your phone is 100% charged.You can get wireless charger for your Samsung Galaxy 4s in following address.It is of high quality and really good brand.And it is really affordable.Choetech wireless chargers are in high demand these days because of their wide range and high quality. You should buy one for yourself as well
Feb 11, 2014 | Microsoft Xbox 360 Wireless Controller and...
Iphone will not charge..... message says charging is not supported with this accessory.
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Oct 21, 2012 | Apple iPhone4 4G iPhone 4
Why is my iPhone 3GS not charging?
First Option:
Second Option:
Aug 09, 2012 | Apple iPhone 3G
Iphone 4 wont charge
If you're attempting to charge your iPhone using a USB cable on your computer, check that your computer is not in a power-saving mode. Computer states, like Sleep or Hibernate, do not supply enough power to the iPhone to charge it. Keep the computer turned on and in an alert state to ensure that power is flowing through the USB charger to the iPhone.
Apr 28, 2012 | Apple iPhone4 4G iPhone 4
I have had my iphone less than a week- i did not expect it to have problems so soon. .... i have iphone 2g my battery ran out now it wont recharge or turn back on? .... but it doesn't turn on, it...
If your iPhone's battery runs very far down, the iPhone won't turn on. That's because it's using its remaining battery life to preserve your data and settings.So, your iPhone could be refusing to turn on because its battery doesn't have enough juice. In that case, plug your iPhone into a wall charger or into your computer (plug it directly into the computer; some USB ports on keyboards don't have enough power to charge iPhones). Let it sit for 10-20 minutes. If it was low on battery and needed a charge, when it's got enough juice to power the screen, it will turn on and show you its charging status, starting with the red battery icon.During this process, you may also want to make sure there's no lint packed into your cable or the iPhone's dock connector. This isn't a hugely common problem, but a lot of pocket lint could interfere with the iPhone getting a charge.
Jun 28, 2011 | BoxWave Corporation Apple iPhone 2G...
Iphone 3g proper charging
Once you purchase the iphone,dont use it yet.Instead of using it right away,kindly charge your IPhone with the wall charger for 3 hrs.Please dont use the Iphone while charging.Kindly check always if the battery is full.Once its fully charged then that's the time that you can use the iPhone. Once fully charged, let the iPhone's battery fully drain.Please keep the iPhone off for 2 hours.Fully charge your iPhone and allow the battery to rest in the fully charged state for two hours. (You may use your iPhone during this time as long as the iPhone is plugged in).Repeat the third and fourth step a maximum of three times if you feel your battery indicator is inaccurate.
Here are some tips for your everyday charging for your IPhone:
#1 - Charge your iPhone throughout the day when available. Charge EVERY night, regardless of charge level. This will keep your battery active, which is healthy for the iPhone's battery.
#2 - Use a wall charger or car charger w/ rated output 5V 1A. Computer chargers might not charge when the computer is in standby mode.
#3 - You cannot overcharge your iPhone. You don't need to disconnect the iPhone from the charger after it's done charging. Once fully charged, the iPhone will run strictly off of AC power and will not damage the battery.
#4 - Every two months, make sure you fully charge and fully drain the battery, in one cycle. This calibrates your battery indicator. If you fail to do this, your indicator will become inaccurate. Calibrating your battery does not improve battery life.
#5 - If you ever need to store your iPhone for any reason, make sure your battery is stored @ roughly 50% and in a cool environment.
#6 - Always charge your iPhone out of its case (assuming you can easily remove the case). Charging your iPhone inside your case will make the iPhone hotter, which is bad for the battery.
#7 - Charge your iPhone in a cool location. Charging your iPhone in a cool environment has a tremendous impact on your battery's lifespan. The colder the location you use to charge, the more charging cycles you can complete without your battery deteriorating. Avoid charging in direct sunlight.
#8 - Use properly rated chargers. Using chargers that are not properly rated will have a huge impact on your battery's lifespan. Make sure your car charger has the same rating as the official Apple charger.
The official Apple wall charger is rated as follows:
Input: 100 240V ~ 50/60 Hz 1.0A
Output: 5V 1A
Thanks!
Apr 15, 2011 | Cell Phones
IPhone will not charge by wall charger or USB into PC. Tried hard boot and only see red battery with a charge symbol. Any ideas
  • Try a different USB to iPhone cable
  • Make sure there is no dirt in the iPhone power connector (blow with compressed air)
  • Try a hard reset:
Hard Reset:
Switch the mute switch 4 times (up, down, up down)
Now press home and power for 6-10 seconds
Apr 05, 2011 | Apple iPhone Smartphone
Got to my phone this morning and the battery was in the red but still had charge. i put it on the charger and went to sleep. when i woke up it was off and nothing i seem to do gets it back on! please help?
Hold the sleep/hold button on the top and the Home button on the bottom for as long as it takes for the iPhone to reboot.
Check your charger and make sure your actually charging the iPhone. also use a an A/C wall charger, not a USB data cable to charge the iphone.
Oct 03, 2010 | Apple iPhone Smartphone
3gs Iphone will not charge
get a toothbrush and some methylated spirits, and clean the charging jack on the iphone, as it is most probably corroded. make sure the phone is off first. and just scrub it for a good minute.
good luck\\
nick
Jan 02, 2010 | Apple iPhone (16 GB) Smartphone
iPhone Apps Logo
81 people viewed this question
Top Apps Experts
Lesley Cameron
Lesley Cameron
Are you an App Expert? Answer questions, earn points and help others
