Question about Haier Energy Star ESA3183 Air Conditioner
Air conditioner I have a Honeywell air conditioner unit. For the last several days it has failed to cool down to the temp I set except at night. When I came in this evening it was 87 degrees in the house. I went to the main unit in the garage and flipped the fuse buttons to off and then back on. Then I dd the same at the main fuse box for the house. (Dont ask me why I thought this would help). Now I can't get the unit to turn on at all. Any ideas?
  • 50 Answers
Yes, first turn your thermostat to the off position. Try to reset both fuse boxes again. If the ac comes back on problem solved, if not fuses and or breakers may need to be replaced. Let me know if this helps and we can go futher into why the ac is not only reaching the temp at night. Thanks
Posted on Aug 10, 2007
SOURCE:
Honeywell 97-4118/5-89
probably low on freon. i assume compressor is running?
Jan 25, 2014 | Honeywell ER150B Air Conditioner
During the day it does reach the cool ,but at night it freezes up
Temp is likely set way too high and at night unit is trying to reach that.
Aug 28, 2012 | Ruud UBHC Air Conditioner
RTH2510B thermostat Honeywell How do we adjust the temperature to cool it down. We are in Florida and it is 89 in the house. How can we set it easily for 70 all day and night?
Hi, You should be able to just push the down arrow button...
Here is a tip that tells you how to get a manual for most any Honeywell productonline...
Manual Honeywell How to Find Honeywell Manuals
heatman101
Jul 24, 2011 | Honeywell Heating & Cooling
Our carrier air conditioner failed to cool down the house last night. changed the filter and still struggling to cool house down.
is it cooling some at night but none during the day basically ? Outside unit clean also ? Good airflow ? if yes on all of these feel the copper pipes that go inside the house from the outside and once a/c has been on for a few minutes the large line should be very cool or cold to where it would condensate.. Sometimes it may take up to 15 minutes..
Aug 20, 2010 | Carrier 38CKC024 Air Conditioner
Rv ac throws the breaker when outside temp gets high, unit works fine at night when outside temp cools down
Clean evap and cond coils
Place hand on a/c if too hot during the day but cool at night
then freon is being restricted in the condensor
Cleaning coils may help days
Put a trickle of water on the condensor during the day for a test.
.If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
[email protected]
Aug 07, 2010 | Dometic Rooftop RV Air Conditioner
Ice formed around the filter area last night. Unit quit cooling.
Ice forming means you have your AC set at a temp that is too low. Of course it cannot remove the heat from the air if no air can pass over the coils. There is very high humidity in the space you are trying to cool ... slow down a little on your cooling process.
May 26, 2010 | DeLonghi Pinguino PACL90 Portable Air...
My air conditioner will kick on but will stay on and not
The thermostat is not functional, therefore its not cutting off the compressor once the room air gets cooled to the temp setting of the thermostat, also the refrigerant gas may have leaked out some but not the entire refrigerant gas(freon, CF4, etc.), keeping the compressor running contentiously to come down to the set temp..............sodeep
Aug 20, 2009 | Carrier 38CKC042 Air Conditioner
Honeywell T8112 Air Conditioner Will Not Cool, But Blower Works
make sure the system switch is in the cool position, then press run program button and allow a couple of minutes for system to cycle on, if it doesn't come on press the button for lowering the set point, set it to 72 degrees and then press the hold temperature key.
May 27, 2009 | Honeywell ER150B Air Conditioner
Haier Energy Star ESA3183 Air Conditioner Logo
118 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Jeff Waters
Jeff Waters
Level 1 Expert
theaircoguy
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
