Question about Measuring Tools & Sensors
Need oPERATORS mANUA, & Schematic
Engine will strt for a few seconds and then dies
  • 15,729 Answers
On what? Please post the make and model
Posted on May 06, 2013
Engin will not strt no click nothing. happened after stlling out on un level ground. Started up but died and agqin no click nothing.
When you store these machines away with Efuel in the tank, it attracts humidity which turns into water. Use premium gas without E=Ethanol.
Nov 19, 2015 | Garden
What cause the fors escape to strt an then dies off
Fuel issue. Have you checked the fuel pump? Fuel pump relays? But it sure sounds like a misfire or a fuel intake problem. Bad sensor , O2 .
Aug 06, 2015 | 2001 Ford Escape
My 2001 Monte Carlo ss won't stay running
I would need more information to give you a good answer. I need to know how long will it stay running a few seconds an hour what is it. I had a 2000 blazer that would start fine everyday and i would 10 minutes and it died sometimes i drove an hour and it died. I parked it and everytime i started it would run about 10-15 minutes and die. after it would die i would check fuel pressure which was good and spark. Well turns out there's no spark so i changed coil ,plugs, wires, rotor. I finally changed the crankshaft positioning sensor and that tuned out to be the problem so good luck.
Apr 18, 2014 | 2001 Chevrolet Monte Carlo
Jenn air model 720 0061 manuel
Jenn Air model 720 0061 LP outdoor grill manufactured 12/ 2004 serial DG-002
I have bought this second hand. Would like operating , maintenance, and parts info.
Mar 31, 2014 | Jenn-Air Outdoor Liquid Propane Lp...
93 toyota pickup 4x4 it will stay running after I turn it on to start it up, it starts up then after a few seconds it kills
if I'm reading this right...
... the engine starts and dies within a few seconds.
... you jumpered the fuel pump test connector and it will keep running.
... you smell fuel after trying to re-start when it dies.
Disconnect the plug to the cold start injector. Even if you have an issue with the engine running then dying after a few seconds after doing this, if you don't smell fuel after disconnecting the cold start injector and try to restart it, the cold start time injector time switch may be failing.
Buy a can of starting fluid and have someone start the engine then spray short bursts of the fluid around all the intake fittings. If spraying the fluid in any particular area keeps the engine running, I'd start looking for leaks around that area.
It does sound like an AFM or COR issue considering it dies after a few seconds, but the fuel smell when trying to restart the engine may be a separate issue that needs corrected / isolated first.it will keep running.
Mar 30, 2013 | Cars & Trucks
I have laptop sony viao cs110 its problem is that when ever i strt my laptop it shows one lite bt the system doesnt strt. i have to push power button again n again after 2 or 3 times my system strts....
1. Replace the RAM & test.
2. Remove components such as the hard drive, optical drive, wireless adapter, ... etc, & test each time whether the laptop will turn on or not.
3. The power button could be bad & needs to be replaced.
4. The motherboard could be bad & needs to be replaced.
Sep 17, 2010 | Sony VAIO VGN-CS110E/Q Widescreen Notebook...
I need to change the timing belt and a few more...
moz-screenshot.pngmoz-screenshot-1.pngmoz-screenshot-2.png Removal & Installation
  1. Disconnect the negative battery cable.
  2. Rotate the auto tensioner clockwise to release tension, then remove the drive belt.
To install:
  1. Install drive belt (A). Route the belt over the components in the following order: Crankshaft pulley → A/C pulley → idler pulley → generator pulley → water pump pulley → P/S pump pulley → tensioner pulley.
  2. Rotate auto tensioner arm in the counter-clockwise moving auto tensioner pulley bolt with wrench.
  3. After putting belt on auto tensioner pulley, release the auto tensioner pulley slowly.
    93581gy2.gif Accessory serpentine belt routing—3.5L engine
    42050_sedo_g0020.gif Accessory serpentine belt (A) routing—3.8L engine
Aug 20, 2009 | 2003 Kia Sedona
Tv turns off in 10 seconds or less
usually on that models its a defective Flyback they are very inexspensive and easy to change. You need flyback 259296 for your model not positive thats the problem but it usually is. You can get a replacement flyback or the service manual ITC222 at the following link. They provide free tech support to help install the parts or free tech support to help diagnose with a manua purchase which they email. Here is the link.
http://servicemanuals.vstore.ca/
Aug 10, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Measuring Tools & Sensors Logo
19 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
