Question about Lenovo ThinkPad Computers & Internet
MP2T8F3 I WANT KNOW ALL DETAILS ABOUT CPU MODEL RAM MODEL AND ORGINAL CAPACITY AND HRD DISK MODEL
  • 3,799 Answers
Go to the manufacturers website. You will need to look for the correct model number. The only sure way to know the HDD model is to look at the drive itself. And the only sure way to know the exact original spec is to ask the manufacturer and supply them with the serial number.
Posted on May 05, 2013
Will Mercury 810e motherboard support 1.0 GB (512 MBX2) SD RAM?
I cannot directly answer that question because you did not supply the motherboard model number. You will have to look this up yourself, here is the url for Mercury support
http://www.mercury-pc.com/downloads.php
The model number is usually printed on the motherboard, find it and you can download the manual, specs and drivers.
Mar 06, 2017 | Q-Lity 810E-T (P3810E-T) Motherboard
Just want to know if what is the maximum size of ram of my motherboard conroe presler fsb 1066 dual core cpu? i have a 1gb ram and i cant watch hd movies i have a dual core 2.8 ghz processor is the lack of...
Without the brand and model, I can tell you for sure the 4 GB at a minimum. With the exact make and model, I can give more details or you can go to www.crucial.com and run the system scanner, it will give you the specs for your system. (Including how many ram slots and the max you can install)
Jan 16, 2011 | Computers & Internet
I have 2 questions:- 1. I have a hard disk of 80GB capacity.I want to augment my storage capacity with an additional Hard Disk of 500GB in the second slot of my CPU.Will my motherboard support that.My...
The motherboard has 2 memory slots with each slot allowing up to 1GB modules of DDR PC2700, DDR PC3200, DDR2 PC2-5300 with a maximum of 1GB per slot. Do not mix RAM speeds.
As for hard drives, the board has the capacity of:
PATA (Parallel) - 2 x ATA100 4 Dev. Max
SATA 1.5 Gb/s - 2
I would assume that the 500GB drive you have is a SATA drive. and the 80GB as PATA. If that is the case, then the two drives would be on different controllers and would work in the system. Typically, it is recommended that the SATA drives is the main hard drive holding your OS.
As always, you would need an open bay in your computer case as well as adequate power to the PWS to complete the installation.
Nov 19, 2010 | ASUS P5VDC-X Motherboard
Intel (r)celeron (r)m Cpu 440@ 1.86ghz, 0.99gb of
open link and download driver .....
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=3765001&prodTypeId=321957&prodSeriesId=3764997&swLang=8&taskId=135&swEnvOID=1093
Oct 19, 2009 | HP 530 Notebook PC
Component details
ZENITH NOTEBOOK, Z-NOTE 425Ln+, CPU 80486DX 25MHZ, 8MB RAM, 1.44MB FLOPPY DISK DRIVE, 200 MB HARD DISK DRIVE, 9 PIN SERIAL PORT, 25 PIN PRINTER PORT, PS/2 MOUSE PORT, VGA MONOCHROME VIDEO LCD, EXTERNAL VGA CONNECTOR, AC ADAPTER, WEIGHT 8 LBS,
You can install Windows 95, I'm not sure about Windows98
Aug 25, 2009 | Computers & Internet
Memory ram
According to SiS® official document, SiS® 748 chipset has limitation DDR supports:
CPU at FSB 200MHz mode, it will NOT support DDR400
CPU at FSB 333MHz mode, it will NOT support DDR200
CPU at FSB 400MHz mode, it will NOT support DDR200/DDR266
Depends on chipset http://www.asrock.com/mb/overview.asp?Model=K7S8XE
Jul 22, 2009 | Computers & Internet
RAM of 512 MB
look speed depends more on condition and cache of hard disk and size, and how much it is loaded with data and how fragmented are ur files ,
Ram does make a difference but only when booting OS and Loading different programs opening them after windows boot as ms word or other office application u will find smooth running of apps no waiting time and hangups in performance if u are enuff with ram like if u use XP 1 Gb is more than enuff but Vista needs 2 GB to work smoothly
but i will again say tell em ur problems in detail i mean where u are getting slow performance i can solve it for u anmd suggest later after diagnosis what is best for ur system i have experience in this
Pls rate me Fixya fo rhelp ! or ask for more help !
Apr 15, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Acer Travelmate 290 model CL 51 How much Ram can I put in and continue to see a marked improvement in speed? It has 500 MB at the moment.
What operating system are you running?
If it is Windows XP you can go up to 4GB. More with Vista.
However 2 GB should be sufficient and you will notice a spike in performance and load times.
Jan 24, 2009 | Computers & Internet
I want to increase the storage capacity my Hard disk.
hi,
You can use SATA hard disk.
you said you already have 40gb. so, your pentium 4 mother board can work with full performance with upto 80 gb.
My suggestion for you is to get another 40 gb and install it ,so it makes 80 gb as total.
Other option is , There are external hard disks available for reasonable cost. you can go for it.
Your RAM is ok too.
Hope my info helps you.
Bye.
Sep 25, 2008 | Computers & Internet
ORGINAL PARTITION DETAILS
When you say 80gb, then the correct disk capacity is 80gb that may be partition if you want (40x2, or 20x4 etc). When the disk(s) are ready, install operating system first and then the setup drivers.
May 16, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Computers & Internet Logo
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
