Question about Dolphin Maytronics Advantage
Power supply box
Supply Power Box not responding at all. Brand new, used it for a first time cleaning, cleaned for a little bit and then power supply box will not turn on at all. No lights, no reponse, there is no fuse box for us to check. And the manual that came with this product is just about useless for any indication of what it might be.
5 Suggested Answers
john224
  • 1378 Answers
SOURCE: Does not work at all
Thank you for posting your question here on Fixya.com.
For information on getting your dolphin serviced please visit www.arrowpools.net and select the dolphin button along the bottom of the site. Complete the questionnaire and we can proceed from there. I assume by check you have verified that there is the correct output voltage across pins 2 and 3 at the socket. The remaining items are the cable and the motor unit itself. Neither is considered a do-it-yourself repair item. Providing the units serial number can help with estimating any chance of warranty coverage as well as possible repair pricing prior to sending it in for repair. If you are not in the upper East coast / mid-West area, we can refer you to a service center in your part of the country.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Apr 13, 2010
john224
  • 1378 Answers
SOURCE: Power supply Keeps blowing fuse.
It needs a new PCB and/or bridge. You can try to repair it yourself or send it in via mail or courier and we can fix it for you. For repair information or for a quote on parts please contact us thru our site at www.arrowpools.net.
John
Posted on Aug 17, 2010
briones93
  • 119 Answers
SOURCE: where can i purchase a
You can find this fuse in just about all online pool parts supply stores... When searching for the best deal..Use this info below... I would try radio shack first and see if they have the correct size/amp rating.. If not, order on-line.. One site of many is ... poolpartsonline.com???
Good luck and hope this helps...
Product Specifications Part #: 3295-023 Manufacturer: Maytronics Manufacture Code: 1930251 Product Dimensions: 0.75" X 0.25" Product Description INYO # 3295-023 MAYTRONICS # 1930251 GENERAL DESCRIPTION: THIS IS THE 2.5 AMP FUSE USED IN SOME DOLPHIN POWER SUPPLIES THIS IS A SMALL CLEAR GLASS FUSE LENGTH:3/4" DIAMETER:
Posted on Aug 27, 2011
john224
  • 1378 Answers
SOURCE: power supply light when turned
You likely cannot fix it without some special tools, parts and a scanner to diagnose where the problem lies. If you would like to try here are some steps to try:
For starters, try the tip I posted here on Fixya, found at: http://www.fixya.com/support/r3651526-dolphin_pool_cleaner_wont_start_up. If that is not enough, try our sites FAQ section on Dolphins at www.arrowpools.net. Select the FAQ button then from the drop-down select Dolphin.
If none of this helps your problem could be in the power supply, cable or motor unit. An illuminated light or lights on the power supply to not verify it is putting power out to the cleaner via the cable.
The motor unit is the most likely problem; the motor(s) inside it is probably failing. When the drive motor and/or impeller motor move you can assume the power supply and cable/electric connections are ok.
Whether the unit is in or out of warranty you can either send it to a service center (which we are one) or try to repair it yourself however it is not recommended you open the cord end that connects to the motor unit as you are breaking the seal for the submersible electronics. You should also be aware that there are no parts available for inside the motor unit. If anything inside is damaged a whole new assembly is required. The motor unit for that cleaner is about $400 and when installed by a non-service center does not come with a warranty so you are better off sending it in for a complete diagnosis and estimate.
For information about the repair and sending it to a center you can contact Dolphin direct at www.maytronicsus.com or our site at www.arrowpools.net.
John
Posted on Sep 19, 2011
Hows the best way to clean the back part of the AC when its still in the window
the best way to clean your air-conditioning by using pressure washing
step 1: Turn off your power supply or remove plug.
step 2: Pullout unit
step 3: Remove electrical box or insulate the electrical box to prevent water enter the electrical box and fan motor.
step 4: Clean the evap. and condenser by use pressure washer.
step 5: Wait unit dry the unit
Step 6: Remove insulate electrical box and fan motor
step 7: Install the unit
step 8: Plug and turn on the power supply.
step 9: Turn the unit
Aug 08, 2012 | Haier HWR06XC6 Wall/Window Air Conditioner
Processor fan is very noisy from start up to all the time I am on line.
Good day , you may need to power-off her PC, open it up, and give it a good cleaning with a vacuum cleaner. If possible, after you've got her PC open, and before you clean it, turn it back on so you can figure out which fan is causing the noise problem (many PCs have more than one fan). If it's the CPU fan, then you're going to want someone who is comfortable and experienced with removing it and replacing it with a new one, because it is EXTREMELY important to get 100% physical contact between the CPU chip itself and the cooling fan/housing that is attached to it, or the CPU is going to overheat and destroy itself within seconds of being turned back on. If the noise turns out to be from a normal case cooling fan (3-5 inches across), you can try cleaning it really well to remove any dust, and see if that fixes the problem. If not, you can buy a replacement fan of the appropriate size at pretty much any PC store for $5-$20. It takes 5-10 minutes to unscrew the old fan and install the new one, and just use the same electric wire from the old fan for the new fan.
If the noise turns out to be from the computer's power supply, you cannot repair it, so it needs to be replaced. I would recommend either replacing it yourself, or having someone who has done it before replace it for you. There's usually only 4 screws that hold the entire power supply box in the case, and then you also have to unplug the power cords that go from the power supply to the hard drives, floppy drive, CD drive, other internal peripherals, motherboard, and fans. Carefully remove the entire power supply box from the PC case, being careful to not scrape it or bang it against any of the memory cards or other internal components. Take the noisy power supply with you to a discount computer store and find a new power supply that's the same physical size and at least as many watts as the current one (usually 350-500 watts). If you go with a generic power supply, it will probably cost around $30. If you go with a name brand, high-wattage power supply, it can cost $100 or more. Hope this information help you in resolving your issue. Have a great day.
May 23, 2011 | Computers & Internet
All lights on wont shut down wont respond
Hello, maybe you have to do what i call hard reset, unplug it from the light then look round if you can locate any fuise on the print take it off, then allow it for 1hour and try again later
May 07, 2011 | HP Deskjet F2210 InkJet Printer
Power supply not staying on
Sounds like when cleaning your computer, you have also cleaned your processors heat sink and fan. right.
if you have done this then there in lies problem.
either your heat sink is not placed correctly
or you forgot to apply a new thermal interface material. because once you remove the heat sink the interface material is of no use. you must apply a new one. and check that you have placed the heat sink correctly and firmly.
Apr 25, 2009 | Silverstone SST-ST60F (SSTST60F) 600-Watt...
Shut Off
I have used several asus boards with good luck. I would say your power supply is to little or going bad. I have a power supply tester, I bought at tiger direct (very cheap) and it has saved me alot of problems. Believe it or not, memory can cause this problem. Try taking out a stick if you have two. I dont remember where you set it, but you can set the time for inactivity to turn your computer off. It sound likes your processor is under load when this happens, so maybe it is getting hot. Blow out the dust from your cooling fan and processor. Make sure your north and south bridges are clean also.
Nov 02, 2008 | Computers & Internet
POWER SUPPLY
Hi, the mA rating for this power adapter is 1500 mA !! I'm gonna give you all the specs. you need to order a new one, and I'm gonna tell you where you can order a new one at; at your preference ?
POWER SUPPLY/POWER ADAPTER TRANSFORMER FOR:(WALL PLUG IN)
BOSTON ACOUSTICS MICROMEDIA SYSTEM 7000596
2.1 SURROUND (2 SATELLITES) (1 SUBWOOFER)
MODEL # WK1201A5-1 AN (THIS IS THE MODEL # FOR THE PLUG)
I/P(INPUT) 120 VAC 60 HZ / 23 VA
O/P(OUTPUT) 12 VAC 1500 Ma
This is all the info you need to order a brand new one in the box.
Go to www.emtcompany.com and in your search box punch in the model # wk1201a5-1an. they cost 29.99 new but its worth it for a great sound system. good luck and I hope I helped a bit
steve - if you have any further questions, i will be glad to help out, you can email me bostonrox129@yahoo.com
Aug 28, 2008 | Boston Acoustics MicroMedia Computer...
The computer will not turn on
1 check supply cords.
2 check voltage on outlet of wall
3 check continuity of all wires of power supply
check the fuse box on the extension board or main board and inside the power supply box.
replace ram
display card :: clean the card pins and the plates on the card.
Jul 29, 2008 | Computers & Internet
Packard bell power supply
The motherboards short out when the box goes out most of the time, you should get a new power box, and a motherbaord.
Dec 28, 2007 | Packard Bell (190169) Power Supply
Dolphin Maytronics  Advantage Logo
52 people viewed this question
Top Dolphin Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Are you a Dolphin Pool and Spa Expert? Answer questions, earn points and help others
