Question about Dell Wireless Keyboard Optical Mouse w0147
Microinv com The wireless mouse is not connecting with the wireless receiver.what do I do.
  • 79 Answers
Hi you can try unplugging and replpugging the wireless receiver, or reinstalling the driver (if theres any), check also the battery of the mouse. Hope this can help. Cheers
Posted on May 07, 2013
I need instructions on removing the cover to replace the battry.microsoft wireless notebook laser mouse 7000.
  • Press the "button with the star symbol" while prying up the top cover of the mouse's body to replace the batteries. If the batteries have power, the LED on the underside of the mouse will illuminate.
  • 2 Plug the receiver component into an open and working USB port on your computer. Your computer should make a noise when the receiver is connected, and the system tray will show that you have connected new hardware. Some USB ports may not be compatible, so it is important to try several ports to find one that works.
  • 3 Press and hold the "connect" buttons on the underside of the mouse and on the receiver for several seconds to refresh the connection. An interrupted connection will cause jerky or inconsistent on-screen performance of the Microsoft Wireless Laser Mouse 7000.
  • Read more: How to Troubleshoot the Microsoft Wireless Laser Mouse 7000 ' eHow.com http://www.ehow.com/how_6803319_troubleshoot-wireless-laser-mouse-7000.html#ixzz1K9LY5L4u
    Apr 20, 2011 | Computers & Internet
    Wireless mouse not working
    Mabey its old try new battiers and the reciever in a new usb port
    Jul 16, 2010 | HP Wireless Optical Mouse
    The microsoft wireless mouse stopped working after a power failure. I get a message that says the USB device is not there. But I cannot navigate my computer w/o the mouse
    The Microsoft wireless mouse comes with a wireless receiver, right? Before you do anything, the first thing that you can try is to replace the batteries with fresh ones.
    If same problem occur, try to connect the wireless receiver into different USB ports of the computer. Then check if your wireless receiver and mouse has a connect button. If it does have connect buttons, briefly press the connect button on the receiver, then hold down the connect button on the mouse for 5 seconds. Then release the connect buttons.
    If you get the same problem, hold down both connect buttons (receiver and mouse) at the same time for 5 seconds.
    Last, try to connect the wireless receiver into different computer. If you get the same problem, send the receiver and mouse to the manufacturer for repair.
    Thank you and good luck!
    Jun 15, 2010 | HP Computers & Internet
    Wireless USB works, but mouse itself doesn't
    Sir/Mam good day,
    Is your mouse device also wireless? you need to resync it with it's receiver,
    you may follow the methods below to make your wireless usb mouse works.
    You need to press the button on your wireless mouse receiver, and make sure that the light on your wireless mouse
    receiver blinks. But you need take note that some newer model of microsoft devices are permanently fixed to their receiver
    and can't be reset. If your devices don't have a button, here's what to do:
    If a dialog box appears on the screen in how many seconds, you need to follow the instructions from it. Or else, you need
    to do this:
    press and release the connect channel button on your wireless mouse, and make sure that the light from your receiver works
    and the status on it's light is steady. If this happens then the synchronization is successfu. But if the problem is still
    the same you need to repeat the previous steps once again.
    As for the wireless mouse for notebook, this problem come out when the micro switch on the underneath of the mouse was not
    released. You can use a pencil or anything with a sharp point to released it.
    There are a lot of options why your wireless mouse receiver won't work, and a lot of solutions. Here's some of them:
    *Try different ports on your computer, if the connection to some usb ports are not working you can connect to other ports
    and see if it will work.
    *And also the cables that are included with the wireless receiver, try to use another cables if the
    device is still not working.
    *If you're device is connected to a usb hub, disconnect it from the usb hub and directly connect it to
    the available ports on your pc and see if it will work.
    *When fixing this type of problem you need to have only one usb device
    connected to your computer, which is in this case, your usb wireless mouse.
    *When you have other usb devices, you need to
    plug it out.
    *If the methods mentioned previously still won't work, you need to reinsert your
    wireless mouse batteries or install a new one.
    *Another possible remedy to this problem is checking the interference, your wireless
    usb mouse together with its receiver should be a distance away from anything that
    transmits signals such as cellphones, radios or other similar devices. And also
    any metal objects. because such things might interfere with the signal of your
    wireless mouse.
    * If the problem persists after doing all of the above steps, maybe it's time to update
    your wireless mouse drivers, For installing latest driver update with your wireless
    mouse, see the documentation that is included in your wireless mouse.
    * If all of the methods above did not solve your wireless mouse problem. You can
    connect your wireless mouse to another working computer to see whether the problem
    lies with your wireless mouse or to the computer which your wireless mouse is
    connected.
    Final instruction:
    If all of these methods fail, you better have your wireless usb mouse be check
    by a professional computer technician in order not to further damage your device.
    Hope this helps. Good luck and God bless
    http://online-pcrepair.blogspot.com/
    Jan 11, 2010 | Silver Jeans 1660-13SL Mouse
    I have an hp wireless mouse, and it doesn´t work!! Tried everything...
    Wireless device like the mouse needs a wireless connectivity to a computer like a bluetooth or a wireless receiver. Make sure that your mouse batteries are all working and the wireless receiver is properly plug into the USB(Universal Serial Bus) port of the computer. The wireless receiver don't need battery so you don't have to worry about it. The two both have a push button, press both buttons to activate the connection. Wireless connections has limit in distance so make sure that you are not too far away from the receiver while using the mouse and that is 9 feet or 2.7 meters so keep that in mind. When the cursor moves when you move the mouse, you have connected the mouse properly. If the cursor doesn't move, try repositioning the receiver. If it still doesn't work, you may need to restart your computer (if you haven't already) or reconnect everything.
    Hope this could help you a lot..:-) Thanks..
    Dec 27, 2009 | HP Wireless Optical Mouse
    Replaced Microsoft Wireless Optical Mouse 2000 doesn't work
    I would have suggested opening up your old mouse and cleaning the right click button first.
    Generally, wireless devices have a connect button that finds the frequencies of the devices. On the receiver press this button, then press the button on the bottom of your new mouse. the receivers lights will stop flashing once connected.
    Jul 21, 2009 | Microsoft Wireless Optical Mouse
    PD7250lSR Drivers
    http://drivers.microinv.com/PD7250LSR.exe
    This worked for me.
    Nov 24, 2007 | Micro Innovations PD7250LSR Wireless RF...
    Dell Wireless Keyboard Optical Mouse w0147 Logo
    32 people viewed this question
    Alun Cox
