Question about Garden
Everride warrior pto wont engage
Everide warrior pto mower wont engage cutters
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 79 Answers
Most likely the engagment switch, usually yellow knob. the seat safety shuts the mower off so if the mower is still running it is not the safety under the seat.
Posted on Jun 10, 2015
  • 11 Answers
SOURCE: john deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
Posted on Mar 11, 2009
  • 97 Answers
SOURCE: lawn tractor engine dies when pto unit is engaged
Check safety switches especially the seat switch.
Posted on Mar 24, 2009
  • 33 Answers
SOURCE: motor stops when the pto or cutting blades are turned on or engaged.
you most likely have a bad safety switch. there is one under your seat,one on engagement lever for blades,and probably one or two more in other places.start with the one under your seat by unplugging it and then going ahead with normale start up and implement engagement. you will have found the bad switch when everything works as it should.replace switch if you feel its necessary or just leave unplugged. it will not affect performance or longevity of the tractor
Posted on May 02, 2009
  • 61 Answers
SOURCE: pto clutch will not engage
ck fuses, and switch, for 12 volts
Posted on Sep 07, 2009
mickey813
  • 472 Answers
SOURCE: John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
Posted on Oct 02, 2009
PTO wont engage
Check your fuses
check the PTO switch
insure all of your safety switches on the mower are working correctly.
You can use a voltmeter to check all of these switches
if all of this checks out you need to replace the PTO clutch.
May 25, 2016 | Cub Cadet Garden
Fuse keeps on blowing when I engage the cutter deck
Check that a wire has not been cut. Check the PTO clutch wires as well.
Sep 28, 2015 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Tractor pto grinds and wont engage,but if I disconnect the cutter. it works engage fine
Sounds like there may be a problem with the cutter.
Sometimes the drive/spindle connections get damaged (especially if you've been mowing rocks like I sometimes do).
Tell us what machine you are working with and we'll try to help.
Jun 26, 2015 | Garden
Why will the cutter blades on scag SW36A not engage?
I am thinking this is a 12 volt PTO system that does not have a battery... this is where you need to check the wiring, especially the big white plug on the right side of the mower... It might also be a mechanical engagement system, if this is the case, suspect the belt popped of or is way out of adjustment
Sep 12, 2014 | Garden
Why wont john deere stx 30 pto wont engage
Most of these mowers have a safety switch between the PTO switch and clutch. A safety switch or relay is most likely the problem. Hope this will help ya.
Jul 19, 2014 | John Deere Pto Clutch For Stx38 And Stx46...
Why does my Craftsman Garden Tractor # 917276022 that runs but when I engage the pto it dies immediately?
well usually when this happens it;s a safety switch that's defective or misadjusted but your sure these are good Id try dropping the mower deck and try enguaging pto if it still runs you got a deck problem ,I have seen spindle bearings lock so tight that it'll stall a 46 hp tractor but that was a brush cutter deck
May 07, 2014 | Garden
PTO WONT WORK on myCub cadet ride on mower LT 1045
i seems you already found the cause its a electrical problem look at all the wires you have a loose connection some ware the wires also like to break where they go into the clutch
Jun 28, 2012 | Cub Cadet Garden
I have a Countax K14 ride on mower the cutter deck
Hello ianh_2007:
Usually this Problem is Caused by a Blown Fuse or a Bad PTO Ground.
1-The Following is a Basic File I Made for Checking the PTO (Blade Engagement).
>>The Most Common Cause for this Problem is the PTO Ground. >>A Quick Ground Check is to Use Another Wire and Ground the PTO at the Harness Connection Nearest the PTO.
>>Be Careful and Do Not Ground the HOT Wire. Use a Multimeter and Locate the Ground Wire.
>>Clean the PTO Ground and All the Connections for the PTO Wiring Harness.
>>If you have an Ohmmeter, Disconnect the Wiring Harness from the Front of the Clutch and Check the Resistance of the Clutch. You should have around 4 or 5 OHMs. If at or near Zero, the Coil has Shorted.
2- >>The Following is a Basic File I made for Setting the PTO Clearance. Any Input is Appreciated. **Some of the Newer PTOs cannot be Adjusted.
>>If you can Get a Blade Style Feeler Gauge between the PTO Magnet and Clutch, then Set the Clearance at .015in. The Newer PTOs have the Same Set Up as the Older PTOs, except there is No Adjustments.
>>I Suggest also that you Rig a 12 Volt Light for Testing the Current Flow to the PTO while Operating the Mower. If the Light Blinks During Operation, then you have a Bad Connection somewhere to the PTO Clutch.
>>If the Light Stays Steady and the PTO Still Kicks in and Out, then it is the Adjustment.
>>You can Also Try Turning the Spring Loaded Adjuster Nuts 1/4 Turn and Operate the Mower. Do Not Adjust Over 1/2 Turn.
>>If you have Adjusted to 1/2 Turn and the Problem is Still Present and you Know the Voltage to the PTO is Steady, then Replace the PTO.**
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 12, 2009 | Garden
John deere 2010 tractor. pto grinds and wont engage
Mar 11, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Open Questions:
Garden Logo
323 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
