Question about Beats By Dr Dre Beats By Dre Detox
My beats only work through 1 side bouth of them would sound but not at the same time help
I don't know how ,but the right side of my dre is not working
One of two things is going on. Plug your Dre beats into something else and check it out. If only one side is working, then your dre wiring is at fault. If it works fine on other equipment and consistently fails on your Ipad, then your ipad input jack is likely at fault. This is not uncommon and shops charge about $100 to replace the part on the ipad. There are some diy kits and videos for the adventurous and care need be exercised to avoid destroying your ipad.
Apr 29, 2014 | Monster Urbeats/ibeats By Dre Beats White...
Only 1 side of my dr dre detox is working
THE INTERNAL WIRE CONNECTING BOTH HEADPHONES IS BROKEN. THIS PROBABLY HAPPENED WHEN TWISTING ONE OF THE HEADPHONES TO HEAR ONLY THROUGH ONE OF THEM. TRY FEEDING EEACH HEADPHONE INDEPENDENTLY WITH ITS OWN CABLE USING ONE OF THOSE PLUGS TO SHARE MUSIC FROM SAME SOURCE.
Jun 22, 2012 | Beats By Dr Dre Beats By Dre Detox
-There seemes to be no contact between my lexmark x3470 and my pc.(w.vista) -Bouth (2007) have worked quite well together before, exept some trouble when low on ink. -Just put inn a new cartridge(1) of...
Uninstall the printer form the pc an disconnect it. Reboot and reinstall the software and wiat for it to ask for the printer to be connected. Follow the on screen instructions
Jun 29, 2011 | Lexmark X3470 All-In-One InkJet Printer
Hello my name is Karen. 2002 pt cod p1685 and somtim is start bouth run like incoreckt timing,and rpm,not shoing.Pless help.Tank you.
SOUND LIKE BATTERY BEEN DISCONNECTED THE PCM TRY RELEARN PROGRAM MORE LIKELY THE PCM HAS TO BE REPROGRAMMED.WHEN BATTERY BEEN DISCONNECTED PCM LOSES MEMORY CAUSING CAR TO ROUGH IDLE AND STALL OUT.
Jun 01, 2011 | Chrysler PT Cruiser Cars & Trucks
Hello!i put a new starter&battery in and it still sounds like the startet not ingaging.tested bouth old&new starters thay bouth pased.same with the batters.HELP ME PLEASE..thanks
Check all cables to the starter and the ground or negative cable from the battery to the engine or frame. They get old and break down between the insulation and you wont get enough current to start the car
Feb 07, 2010 | 2000 Mitsubishi Montero Sport
The pendulum stopped swinging...the clock and chimes work well
Hi
This clock short of needing a full service may simply be out of beat.
Taken from my web page located at:
http://antiqueclock.clockstop.com/CLOCK_BEAT.htm
"HOW TO PUT YOUR CLOCK IN BEAT"
-Included below is a 10-second sound <snip> of a clock both in and out of beat.
IN BEAT ////////\\\\ OUT OF BEAT
· Turn on your sound and click on the clocks above for a sound clip.
-One little known fact is that a clock does not have to be level to be in beat. I had a customer that had a mantel clock in an old farm house, it was brought in for repairs and sent back running great just one problem: I put the clock in beat on a level surface [a small problem] because the mantel it had set on for it's entire life was not level. I had to literally go to the house to put it in beat where it sat.
-I have often found most Grandfather or floor clocks are set up out of level and put in beat where they stand, This is fine.
-As I'm sure we now realize a clock must be in beat but not always level to function properly.
· Above is the verge with a slip clutch.
· Often found on Grandfather clocks and requires only a long swing to get it in beat.
-To get the clock on the right side in beat you would need to push the verge assembly to the left.
-If it must be bent to put it in beat, do it slightly, but don't bend any of the suspension parts.
R/ David
Nov 08, 2009 | Seiko Chiming Pendulum Tambour Mantel...
Not recording on sync witht the beat
Some of the Magic products just don't work well with Vista. Try setting you compatibility settings to xp using the compatibility wizard.
Oct 20, 2008 | Magix Music Maker 12 Deluxe
Pioneer DJM-600 black Professional DJ power on but not working!! i check bouth the fuses and are working i can see that is power in te mixer but no answer with any signal of leds or music signal
So you get power to the unit, but no sound coming out? How about through the headphones, do you get sound coming out of the headphones?
Are all the volumes and gains raised up? All the eq's are up? Check the back of the mixer, there is a master gain volume - where the connections are - make sure this is up also.
If nothing, then you'll need professional help at this point.
- OPTiC
DJ Equipment Repair & Service
A DJ Pro Audio Co.
Sep 23, 2008 | Pioneer DJM-600 Silver Professional DJ...
Problem with my colors on Sony KP-46wt510
Sounds like the convergence ICs are giving out its a fairly commom problem with all projection TVs. Your model uses two STK392-560 ICs but I would suggest getting a couple of the 4.7 ohm 1/2 watt convergence resistors as most times one or two of them are open as well.You can get new replacement ICs and resistors at the following link and they provide free instalation instructions with pictures so you can do the repair yourself. Here's the link.
http://servicemanuals.vstore.ca/
Jun 23, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Beats By Dr Dre Beats By Dre Detox Logo
27 people viewed this question
Top Beats By Dr Dre Audio Players & Recorders Experts
 Grubhead
Grubhead
Mike
Tom Chichester
Are you a Beats By Dr Dre Audio Player and Recorder Expert? Answer questions, earn points and help others
