Question about Pioneer PD-M603 6-Disc CD Changer
Power will not switch on
My power switch will not"click on." In other words, I push button to turn unit on, and the button will not stay on.
SOURCE: 55" PIONEER SD-P5795W REAR..
yeah, I have the same issue... The tv worked fine, and now it will not turn on... the light turns green, then turns off and goes red...
Posted on Nov 08, 2008
dunnbiker
  • 8546 Answers
SOURCE: won't power up; push power button on, hear click in back left of unti, get nothing on front display and no output from speakers; as if unit trying to operate
Disconnect the speakers and see what happens. Carefully examine the speaker cables for unwanted connections (shorts).
Take a clue from when the power problem appeared. Something was moved and made the buzz a (probable) dead short.
Posted on May 16, 2009
SOURCE: the tv will click on, and click right back off,
No solution...but mine is identical problem
Posted on Nov 13, 2010
ladywinn
  • 5138 Answers
SOURCE: accidently pushed a button and then the tv went
Check power supply board located on the Right bottom board,in the middle is a 6amp Fuse it could be blowed.
Located on the Left Hand side should be the Big Black ICs will have part number on them STK392-110 ,Bad STK ICs can cause this also.
Mats Electronic Parts 1-800-628-1118 they will have ICs ,ect...
Posted on Jul 20, 2011
Testimonial: "we are trying it now"
dduncan774
  • 760 Answers
SOURCE: standy light on but wont power up
You could have a blown channel. This will keep your receiver from turning on. It is a protect feature to keep you from damaging more components
Posted on May 02, 2012
My Samsung dvd/vhs player will not stay on. Says hello, then bye a couple seconds later
Sounds like a bad power switch. When you push the power button, it will initiate the unit to turn on, but if the switch does not keep the power on to the unit when you let go of the power switch, then the unit goes into shut down mode. Then the unit will display good bye. I would have the power switch looked at first.
Aug 24, 2016 | Samsung Televison & Video
Jacuzzi tub will not turn on button will not click on as usual
Your problem is most likely NOT the air button but the switch in the motor.
Air Switch Repair
It sounds like you have a bad air switch located in your motor.
The air switch is what the air hose connects to on the back of the motor or on the box on top of the motor. The other end of the air hose is connected to the air button on the lip of the tub.
This is a latching air switch and when you push the air button it latches to send power to the motor. When the air button is pushed again it opens the latch in the air switch and stops power going to the motor shutting it off.
Rod
US Parts Center
Apr 10, 2014 | Jacuzzi Home
Preamp stuck in standby mode
a flaslight bulb and batteries and couple of wires can be used to make a continuity tester.and also pls check the small pushbutton(power button)try the remote if theres any
Feb 04, 2014 | Adcom GFP-710 2-Channel Amplifier
Hi Frank,
Changers and Mega loaders are often with problems once they age. That is why it is a good idea to have a Technician who can work on these at bay when things go wrong. It can be a bad belt, dead motor spot or even a jammed part of the mechanism. I have unjammed many a plastic mechanism and they warp and go out of position which is why I use only single players.
Dec 21, 2012 | Technics SL-MC7 110-Disc CD Changer
How do you reset a Magellan 1700 GPS?
FAQ on your unit says this.
Depending on the power switch your unit was designed with follow the instructions below:
Slide Switch If your unit has a Slide power switch then slide and hold the power switch in the off position for more than 8 seconds.
Push Down Power Button If your unit has a Push Down Power Button for a Reset pin hole on the bottom or on either side of the unit. Take a pin or an end of a paperclip and insert it into the hole and push in until you feel it pop slightly, hold it for 10 seconds. Your unit will reset itself.
Reset Power Switch If your unit has a Reset Power Switch then it will have a three position power switch (Reset, Off, On), if this is the case slide the switch to the reset position and hold it for 10 seconds to perform the reset.
If that doesn't work, contact them direct. sometimes they have to install clean firmware.
MagellanGPS Technical Support Consumer Sales Customer Service
Apr 08, 2017 | Magellan Roadmate 1700
RV-5 will not reboot
You have a failed circuit board, you will need to have a local repair shop test it.
Apr 03, 2017 | Audio Players & Recorders
My AOpen 19" LCD Flat Screen Monitor (Model F2915) is like new and works perfectly except for one thing. The push button power switch located on the top of the monitor has broken off and fallen insid
Certainly, if you jumper the connections to see which ones turn the monitor on or off, then you can go to an electrical supply place and get a micro switch and wire it in in place of the power button, or perhaps find a type that is flat that the power button can press. What you need to determine is if it is a push-on, push -off type switch, which always stays on or off depending on position or if it is a momentary interrupt switch where the button pressed momentarily turns it on and then releases and a second press connects the circuit to turn it off. You can do this by testing with your jumper wire, attach it and if the monitor stays on when you remove it, then goes off when you attach it again, you need the second type switch, if it goes off when removed, you need the always-on always -off first type switch. .
Mar 07, 2012 | AOpen F90GS 19 inch Monitor
My power button O/I will not stay depressed...it will show code 88 when I push it, however as soon as I let go the unit turns off. HELP
The switch is possibly broken. Should click and stay depressed... If you still have the receipt, may be under warranty.. Call Intex 1-800-234-6839 for assistance..
Aug 19, 2011 | Intex Automatic Salt Water System for ...
My phone is frozen! It is stuck on this msg. "Samsung SGH-T249". No matter which button I push, nothing happens. It will not turn off, nor can I make outgoing call. The screen stays...
Press and hold the power button until the unit turns off. Sometimes it takes up to two minutes to turn off. If you cannot get it to turn off using the power button, open the back and take the battery out. Press and hold the power button for sixty seconds with the battery removed to reset the unit. Then reassemble it and turn it on. This may not solve the problem on why your screen is getting stuck but it will reset and allow you to attempt to restart it.
Aug 16, 2011 | Cell Phones
Cannot switch off the gps 350
Do you feel a light click when you push the power button?
If not the switch is probably defective, If you do feel a click, hold it there for several seconds. It should switch off.
Mar 16, 2008 | Garmin nuvi 350 GPS Receiver
Pioneer PD-M603 6-Disc CD Changer Logo
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
