Proview monitor it says burn in and is flashing differnt colors
    Top Expert:
  • Televison & ... Master
  • 74,496 Answers
Turn on its burn in function. To do this, you have to enter its service mode option. Refer its manual. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. More than Nine Lakh viewers cannot be wrong.
Posted on May 06, 2013
No sound , Proview 17" monitor- cannot get any sound, could it be a bad cord or something else.
Depends - it can easily be a bad cord, or you could simply have the cords reversed. Yes, I bet you have them in according to their colors, as in red to red and green to green, but it you reverse those colors from the monitor to the CPU, you might get the monitor's speakers to work.
Also, the monitor does have a speaker setting in the configuration, through the monitor's menu. Try first to Google the monitor brand and type, and if you find it, follow those instructions. Otherwise, just start looking into the monitor's menu and config system. Do not change anything until you are certain that you have found the right setting.
Then, go for it.
Jun 20, 2009 | Proview PL713S 17" Flat Panel LCD Monitor
My monitor is flashing pretty colors.
Either a bad video card or cable. Wiggle the cable at the connection points. I would think video card. If it's internal, and you are sure it's a bad internal video, a cheap video card can be a quick check. See if a tech friend has a standard PCI video card to borrow. Let someone knowledgeable install it. Must set BIOS to run video from card installed.
Jun 01, 2009 | Gateway FPD1760 17" LCD Monitor
Proview monitor fix
I did it just because the higher voltage caps would give a lower heat dissipation thus leading to a longer life this time around.
Oct 17, 2008 | Proview PL926WBi 19" LCD Monitor
Flashing Monitor
Sounds like either  a loose connection or a short in the cable going from the monitor to your computer.  Try disconnecting the monitor from the computer, and plugging it back in again.  If this doesn't resolve the issue, try bending the cable in different places.  If this causes the monitor to correct itself, even just for a little bit, it is a bad cable.  You can take it off from the monitor and the computer, take it to a store that sells cables, and get a new one.
May 29, 2008 | Proview PL926WBi 19" LCD Monitor
Screen goes dark
it indictes problem with ur crt tube in monitir
Dec 02, 2007 | Proview PL926WBi 19" LCD Monitor
Lcd monitor looks like pic negative
make sure the cables are pushed in all the way and tighten. On pick that is out of place can distort color correction. also try reseting the monitor to factory settings.
Jul 22, 2007 | Proview PL926WBi 19" LCD Monitor
MONITOR CONTRAST OR COLOR
find on the net an adjust software (eg. Nokia test), it helps you on dealing the problem...
Jul 12, 2007 | Proview PL713S 17" Flat Panel LCD Monitor
How do I fix a monitor
The age and much more power consumption and different dangerous places with high power ask for knowledge of focussing ,anode ,flyback (horizontal) and primairy rectification power on differend places , is not without danger , how to unload the display tube, and much more and in most case the line transformer flyback transistor and capacitor could be damaged. is not useful , a new monitor has more advantage and most of them are not to expensive to buy.
Sep 03, 2017 | Proview PX-986 19" CRT Monitor
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
