Question about Acer Computers & Internet
Vertical ic white screen is comming
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 40 Answers
Press enter and wiggle your mouse
Posted on May 09, 2013
Where is horizontal scan out put section?
Hi Majid
Just contact any service technician to repair your TV. It will be best for you.
Gopakumar Gopalan Google
Feb 01, 2015 | Televison & Video
Why come white vertical line on my t.v screen in center?
You said "I checked vertical output line from main ic pin 23 found correct"
But the problem is "Horizontal Output Line" Try that.
Jan 29, 2015 | LG Televison & Video
White line in middle of screen on a cx32h60 toshiba tv
The vertical sweep output is absent. Check its vertical output section circuit for the fault. Check all the solder terminals of that section, and resolder them by applying a little more solder. Take special care to the solder terminals of the vertical output IC. If these do not help you, check and replace the vertical output IC.
Jul 07, 2012 | Toshiba CX32H60 TV
White line vertical run acroos the screen
hi;
there's a problem in Vertical parts of your TV, there is an IC that controls vertical alignment
of your screen, if this IC is fails the result is white line in the center of your screen
you see this IC inside the TV . you need some tecnical know how when servicing this unit
because there is a present of High Voltage inside. beter call for tv technician for repair.
Sep 05, 2011 | RCA F35673MB 35" TV
Unit has sound, no vertical deflection. caps and output ic ok. have b+ to output. nothing at pin 2 of output ic.
If there's an audio,,it might be the defective Vertical IC...but check first if there's 24v-26vdc supply coming from FBT going to Vcc of Vertical IC.
If there's no Audio,and only white horizontal line in the screen,check the Vertical out of Jungle IC.
Oct 12, 2009 | Toshiba 27D46 27" TV
My 15 year old Toshiba Televisiononly shows a narrow horizontal band in the middle of the screen. Sound OK.
Hiii fairley,
You aren't specsificly dercribe yor tv set.
For common TV horizontal problem ;i.e : White line accross the horizontal screen, horizontal band,etc..it's can solved by replacing the IC Vertical/Transistor, and olso to replace the cap nearest the IC.
For common TV Vertical Problem :i.e : White line at the center of the screen (top to bottom),Vertical band,etc...It's can cure by Replacing the Horizontal IC/Transistor,and offcurse the cap's.
Tha's what all I know....
Hope can help you to solved the problem.
Thank's
h3liax
Jun 22, 2009 | Toshiba 32A33 32" TV
Single horizontal white line on screen
This is either bad connections at the vertical IC or a defective IC. This should be a small flat IC attached to a heat sink. It will be marked LA7837 or something similar. It will have about 11 pins. If you are not sure you have the correct one, post the marking here and I'll confirm.
Dan
Nov 17, 2008 | Symphonic ST427FF TV
Magnavox with a white screen, sound, volume and channels working
dont put in back the vertical prossesor ic get a new one and solder it in see what it does.good luck.
Aug 19, 2008 | Philips Magnavox 27MS343S 27" TV
Thin horizontal line accross screen
if the screen is totally black and only white horizontal line appear on the screen, check the vertical section if there is supply voltage on the vertical IC, and if there is none check the source of some open resistor connected to that IC. if there is supply voltage check all electrolytic capacitors connected in that vertical IC and it is better to replaced them all they are very cheap. and if it is still not working replace the vertical IC. post some comments if it is still not working and let see what we can do..
Aug 11, 2008 | Televison & Video
I have a Sanyo tv with sound an a horizontal white line on the screen. Where should I start looking for the problem?
A horizontal white line on the screen means that you have problem on vertical section. It might be the vertical IC or other components near that IC.
Jul 13, 2008 | Televison & Video
Computers & Internet Logo
20 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
