Question about Emerson Jumbo Universal Remote Control
Zennox remote i want to put it in a input, but i don't know where the start/ok button is. can you help?
Magnavox input change
If the remote is its original one, there should be a button marked 'TV/AV'. Press this button to select inputs.
Jun 21, 2013 | Magnavox Televison & Video
Can't change input - don't have remote
Unless there is a source or input button on the set you need the original remote.
Dec 18, 2012 | Toshiba 30HF84 30" TV
I need to change the input on my tv but I don't
It's a westinghouse......you better get the model number off the back, then find a universal remote at walmart.....it'll give you a cpl different options for your tv....so read carefully the instructions that come with the remote you buy.
Apr 27, 2012 | Televison & Video
Want to record VHS to DVD on my Toshiba DVR620KU but do not want to connect to my TV set. Is this possible? My TV is older and does not have the input/output jacks. I just want to put in a VHS tape and a...
If the entire VHS is full then you can easily transfer the VHS contents to the DVD. The video will play while it is recording onto the DVD, but you don't have to have it hooked up to any TV for it to record. Now if you don't know how long the VHS content is that you want to record to DVD, then you will have to hook up the player to a TV so that you can press stop when you reach the end of the content you want recorded. At least this is true in the way that I use to transfer VHS to DVD:
1) Turn on the unit
2) Insert VHS tape
3) Insert DVD-+R or DVD-+ RW
4) Using remote, press VCR
5)Using remote, press play then pause the tape where you want to start recording.
6)Using remote, press DVD
7) Using the remote, press DUBBING. The VHS should start to play and the DVD should start recording
When using this method, don't hit the RECORD button!
I hope this helps!
Sep 05, 2011 | Toshiba DVR620 DVD Recorder/VCR
Got used car 1996 and it has a 10 cd changer in it . Was installed at time of purchase of new car. Have noidea how to use it. Don't know if it works, or not. No light goes on, no buzzing, Someone told...
These changers are capable of outputting to several bandwidths (like 93.5, 103.5, etc.). Does it have a wired remote mounted somewhere on the dash? If it does, it's likely the type that uses FM modulation. If that's the case, put disks in the cartridge, insert the cartridge, and hit play on the remote.
If it doesn't have the remote, it runs directly off the stereo in the dash, in which case you change inputs by pushing the Input or CD button on the stereo in the dash, then control it from there.
Let me know which it is, and I'll try to help you further. Also, a brand and model number would help in finding an online owner's manual for you to peruse.
Jul 04, 2011 | Car Audio & Video
I'm trying to connect my Wii console to an old magnavox tv my aunt gave me. I don't know how to connect it because it doesn't have the tv/video button on it. I've tried reconnecting...
U have the tv original remote?Look for a button said Input,used that button push it to goes into video mode 1 or 2.Don't have the tv original reomote.Try website like Remotes.com to buy the tv original remote.
May 08, 2011 | Televison & Video
My TV lost image, but has sound. I`m out of warranty, what should I do? (PS: I`m a woman, so please explain it nice and slow :) )
Please read all before starting!
I'm a woman too. The first thing you have to do when your tv no longer has a picture is to determine whether or not the television needs to be repaired. The way to determine this is to perform some troubleshooting. The easiest thing to do is to turn the television on and turn the volume up and down on the television remote while looking at the screen. Do you see the volume bar going up and down as usual? Or is the volume of the tv set going up and down, and you can hear the volume increasing and decreasing but you cannot see any volume bar as usual? Also you can press the menu or display or info button (whichever of these your television remote has) and see if any writing whatsoever appears on the screen. I am asking you to use your television remote at this point, which is the one that came in the box with your television (not your converter box or cable box or satellite tv receiver or surround sound remote--I am speaking of your actual television remote).
I do understand that some people don't use their television remotes and disregard them putting them in a drawer or somewhere else and can't get to them. So if that's the case you can use the buttons on your television itself. There should be a volume up and a volume down button but DON'T push the channel buttons or the source/input button.
Ok if you see the volume bar going up and down or some menu or display information that is good. That means the television is ok (most likely). Then the problem would be with the stuff that you've got connected to your television or with the stuff you're connecting it with. Just try connecting something else to your television with the same cables, and then if there is no picture with new stuff connected try connecting the new stuff with a new cable. Remember that when you are connecting stuff to a television you have to select a corresponding input/source on the television in order to view it. The back of the television is labeled. If you plug something into video 2 or input 1 then you have to select that on your source/input button on your tv remote or tv panel.
If you isolate your problem to your cable box or satellite receiver or your cable service then you can contact the cable company or satellite company directly. Your box may need to be rebooted or replaced by them. It might also be a setting in the box. If you can do some of the troubleshooting and get back to me I can help you further when something has been ruled out or a problem has been isolated.
Apr 13, 2011 | Televison & Video
Zennox USB turntable not being recognised by Audacity
you will have to tell the software which input you are using.
first try audacity with the jack input maybe with an ipod or a mic.
Aug 17, 2009 | Computers & Internet
Emerson Jumbo Universal Remote Control Logo
70 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
