Canon ir 400 error code e004
Hello sir my xerox mechine is cannon ir400 and it is showing that error code of e0004 and not pressing the key pad keys also what should i do for this problem please solve this problem
  • 1,326 Answers
The error code E004 deals with the fixing unit. Odds are that you may have one or all of the following parts need to be replaced > the fixing lamps or thermistor or the thermal fuse or the upper fixing roller.... Just for starters... Good Luck
Posted on May 08, 2013
Cogz
  • 1326 Answers
SOURCE: Canon iR-2016 System erro E007
The erreor code E007 has to do with the fixing ***'y upper film ***'y or roller. It is saying that the film is not moving in and out of "HP" Most of the time it means that the fusing film is torn and not moving properly. If you are getting paper jams in the fusing area and or unfixed or smeared copies. You most likly need to have the fusing film ***'y replaced. It could also be that it is out of place and needs to be readjusted. The only problem is that it's a little tricky to get to and not a bad idea to have a new film to replace the old one while you have it out. Good Luck
Posted on Mar 16, 2008
  • 2072 Answers
SOURCE: xerox error code u1-1 main motor fault
You will need to replace the main drive motor assembly.
That stepper motor is a common fail item.
You have to remove the rear cover, the MFSYS and MCU board assembly to access that motor.
Posted on Jul 09, 2008
hi how do solve this problem system error E007
Posted on Apr 09, 2009
SOURCE: Describe your canon ir 400 xerox machine error
i have duplexing problem
Posted on Jan 11, 2010
canontech
  • 1219 Answers
SOURCE: cannon ir400 error e004
Hi,for error code E004-001 or E004-002
Cause:
The SSR has a short circuit.
• The SSR has an error.
• The DC controller PCB has a fault.
The heater relay has an error.
• The heater relay has an error.
Description:
• The fixing heater remains
on.
• The fixing temperature has
increased abnormally.
The heater relay remains on.
FIRST TRY TO CLEAR ERROR:
Resetting Errors
1. The following error codes cannot be reset by merely turning off and then on the main power.
They require resetting in service mode:
E000, E001, E002, E003, E004, E032, E717
1) Start service mode, and select COPIER>FUNCTION>CLEAR>ERR.
2) Press the OK key.
3) Turn off and then on the main power.
2. Error codes other than the above may be reset by turning off and then on the main power.
n Detail Code
Some error codes offer detail codes, which may be checked in service mode:
COPIER>DISPLAY>ERR (3rd block from the right)
SERVICE MODE:
1) Press the asterisk key ' * ' on the control panel.
2) Press '2' and '8' on the keypad at the same time.
3) Press the asterisk key ' * ' on the control panel.
If these doesn helps, you need to call service to locate the fault, wich is probably bad thermistor.
Hope that helps!
Posted on Aug 19, 2010
How to go service mode Cannon ir 400 ?
Here is the error code page http://www.scribd.com/doc/56428927/iR-400-Code-List
And here is the service manual
http://www.scribd.com/doc/135167936/canon-Ir-400-Service-Manual
Looking at what the error is, getting into the service mode will not allow you to fix it; you have some parts to replace first.
Jul 20, 2014 | Cannon Office Equipment & Supplies
Tip
How to resolve Cannon ir400 Error e004
<span>Hi,<br /><br />For error code E004-001 or E004-002<br /><br />Cause:<br />The SSR has a short circuit.<br />&bull; The SSR has an error.<br />&bull; The DC controller PCB has a fault.<br />The heater relay has an error.<br />&bull; The heater relay has an error.<br />&bull; The DC controller PCB has a fault.<br /><br />Description:<br />&bull; The fixing heater remains<br />on.<br />&bull; The fixing temperature has<br />increased abnormally.<br />The heater relay remains on.<br /><br />FIRST TRY TO CLEAR ERROR:<br />Resetting Errors<br />1. The following error codes cannot be reset by merely turning off and then on the main power.<br />They require resetting in service mode:<br />E000, E001, E002, E003, E004, E032, E717<br />1) Start service mode, and select COPIER&gt;FUNCTION&gt;CLEAR&gt;ERR.<br />2) Press the OK key.<br />3) Turn off and then on the main power.<br />2. Error codes other than the above may be reset by turning off and then on the main power.<br />n Detail Code<br />Some error codes offer detail codes, which may be checked in service mode:<br />COPIER&gt;DISPLAY&gt;ERR (3rd block from the right)<br /><br />SERVICE MODE: <br />1) Press the asterisk key ' * ' on the control panel.<br />2) Press '2' and '8' on the keypad at the same time.<br />3) Press the asterisk key ' * ' on the control panel.<br /><br /><br />If these doesnt helps, you need to call service to locate the fault, which is probably bad thermistor.<br /><br />Hope that helps!<br /></span>
on Feb 06, 2011 | Cannon i70 Printer
Error e805 ir 400
my cannon ir400 xerox machine is on but no working power supply is full but not run machine
Dec 21, 2013 | Canon imageRUNNER 400S Copier
E004 (IR 400)
This is the error for the temperature of the fixing assembly not being detected or getting too hot. The thermisitors will most likely have to be replaced. First try resetting the error by pressing the additioanl function key, then press the 2 & 8 keys at the same time and then the additional function key again. The display should show COPIER - press this to highlight and the display show then show a series of keys at the top. Press FUNCTION, then CLEAR, then ERR, and then OK. Turn off the copier and turn back on again. This resets the error and if the error comes back up again then the parts will have to be replaced. Good luck.
Jul 27, 2011 | Canon imageRUNNER 400S Copier
My Canon copier, Model IR 400s, Shows the error code : E 604. What is the problem ? How can I Solve it ?
My Canon copier, model IR 400s, Shows the error code : E604. What is the problem? How can I solve it ?
Sep 25, 2010 | Canon imageRUNNER 400S Copier
Error 805 and 803
Hello sir; The error code you display 803 & 805 could be come from same problem, both all are composite board 24 volt supply problem, replace composite board will take care this problem. good luck.
Jul 24, 2009 | Canon imageRUNNER 400S Copier
E0004 on Canon NP6050
it is a SSR,heater 1 or 2 ,or thermal switch error.   Try to reset,        follow this procedure. SERVICE MODE E004 SSR O FUSER WON´T SHUT OFF
To reset this code use simulation 401
SERVICE MODE: Open front door and cheat door switch.Using an allan key of 2mm, insert it through the hole in the inner front panel and actuate service switch 850. Display will show "1". Press the mode 4 you want to use. then press "ok" . It will read 401 press "ok" use number key a change the value if "1" change to "0" press "ok" . press "clear" takes you out of particular mode turn off the machine. good luck     CE MODE: Open front door and cheat door switch.Using an allan key of 2mm, insert it through the hole in the inner front panel and actuate service switch 850. Display will show "1". Press the mode 4 you want to use. then press "ok" . It will read 401 press "ok" use number key a change the value if "1" change to "0" press "ok" . press "clear" takes you out of particular mode turn off the machine. good luck
Oct 24, 2007 | Canon NP 6050 Copier
Service manual
I want user manual for cannon imagerunner 400 / 330 series
Sep 19, 2007 | Canon imageRUNNER 400S Copier
313 people viewed this question
k24674
jasbo
jasbo
